jlomein
So today I received my AW incan smart driver and Philips 5761 bulb so I could assemble it into my 2C Mag.
I used all the shims for the driver/switch and still had a terrible unfocused spot when using a FiveMega VLOP reflector. I took the head off and was going to pull the bi-pin bulb out a bit to see if it made a difference. I had been using the cellephane bag that the bulb came in to touch it with instead of my hands. Unfortuntately when I did this it melted onto the bulb due to the heat!
So now I have a 5761 bulb with melted plastic on mostly the top. What should I do? Is there any way to reclaim the 5761 bulb without destroying the special coating on it?
