The Fenix-Store
Page 5 of 28 FirstFirst 12345678910111215 ... LastLast
Results 121 to 150 of 811
Thread: Surefire Lego?
  1. #121
    Flashaholic* bigchelis's Avatar
    Oct 2008
    San Jose,CA
    Default Re: Surefire Lego?
    This is my newest experiment. It is E1e with 700 Lumens. Yes, I have the AW 16340 protected cell, Malkoff P7, and EtoC adaptor. I currently use the P7 in my Pentagon PX1, but will soon add it to an E1B
    With my cr123's it ran for 15 minutes with no drop in output.
    At around 17/18 minutes the output droped and I stoped at 20 minutes.
    Still very impressive runtime. Next, I will try it with my AW16340's.
    Surefire 6P with Malkoff M60 simple, bright, efficient.
  2. #122
    Flashaholic* mudman cj's Avatar
    Dec 2005
    Where corn and pigs are grown unimpeded by trees
    I have only recently started buying Surefire lights, but I have taken a liking to the E series.
    Below from left:
    1) KL4 head modded with MC-E 5A on custom heat sink and stock circuit. Currently attached to an E1L body with Z57 tailcap and holding an IMR16340.
    2) FM 18500 clicky body
    3) E2E body (bored for 17670) with Z57 tailcap
    4) FM 18650 clicky body
    5) KL1 head modded with Seoul high CRI 4000K CCT LED at 750mA and IMS20 reflector above an L4 body (bored for 17670)
    6) stock bezel
    So, I can use the stock setup or put in the IMR16340 cells with my soon to arrive LF IMR-E2 for 350 bulb lumens.
    Then come the LED combinations. Either the KL1 or KL4 can run from a single IMR16340, 17670, 18500, 18650 or two CR123 and the KL1 can also run on two RCR123. I'm not sure what would happen with the stock KL4 circuit on two IMR16340 cells. Add to this my Art Of The Hide holester that perfectly fits any of these heads and you have quite a lot of EDC options.
  3. #123
    Flashaholic* DaFABRICATA's Avatar
    Jan 2007
    Michigan
    Quote Originally Posted by mudman cj View Post
    Running the KL4 on 2 X RCR123's will make it go .
    Thats my experiance anyway.
    "I have to go return some video tapes." -Patrick Bateman
  4. #124
    Flashaholic* SureAddicted's Avatar
    Jan 2008
    Sydney, Australia
    Quote Originally Posted by bigchelis View Post
    The Malkoff P7 @ 700 lumens, isn't that with 2 cr123's?
    EDIT 600- 700 lumens with a 18650 or 17670...wondering how you fit one of them inside a E1E.
  5. #125
    Oct 2008
    San Jose,CA
    The P7 runs on a single cell whether it be a cr123 or an 18650. As long as the cell can handle the 2.8amp draw. There will be differences in runtime. As long as you use an E to C adaptor you can put any 6P head on any E series body.
  6. #126
    Jan 2008
    Sydney, Australia
    So you can get 700 lumens from one cr123?
    According to Gene, the P7 is only suitable for 18650 and 17670 rechargeable cells.
    I think this is a similar case to the L4 and TW4. With 2 cells you get 100 lumens, in the one cell configuration you get half of that, I'm guessing.
  7. #127
    Flashaholic* gswitter's Avatar
    Apr 2006
    California
    It should run fine on a CR123A, but with reduced output.
    For full output, you'll need a 2.8A @ 3.6-4.2v - so either a high current Li-ion/LiPo cell (AW "C", 18650, 17670, IMR16340, etc) or 3x NiMH cells.
  8. #128
    Jan 2008
    Sydney, Australia
    Thanks gswitter.
  9. #129
    Oct 2008
    San Jose,CA
    Quote Originally Posted by gswitter View Post
    I ran it with ebay version 16340 and it ran with no drop in output for 15minutes, but by 20 minutes it was probably about half the output. I also have AW16340, which are designed for this 2.8amp draw safely.
    For practicality I use it with a single 18650. For pure amazement I use it in a single cell 16340 (3.6v-4.2v) set-up/lego and although it's amazing the runtime is compromised.
  10. #130
    Apr 2006
    California
    Still a work in progress, but here's the first cut of my E-series, L6 Porcupine homage... The Pineapple Killer
    • Assault bezel ring from a SolarForce A001 bezel
    • SolarForce L2 bezel (I'd rather it was a 6P bezel)
    • Vital Gear E2C
    • Peu Pineapple
    • McGizmo McTC...
  11. #131
    Flashaholic* Superdave's Avatar
    Nov 2007
    Quad Cities, IA
    Nice!
    yah, it's too bad the Solarforce crowns have a finer thread than the SF ones.
    Too many lights.... Not enough darkness.
  12. #132
    Flashaholic* KDOG3's Avatar
    Aug 2004
    Sea Isle City, NJ
    This thread is sick. Just sick I tell you...
    FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
  13. #133
    My EDC
  14. #134
    Nov 2007
    Quad Cities, IA
    Here is my new EDC Lego..
    Of course the SF switch failed yesterday.. this is the 2nd one i've had go bad on my U2.
  15. #135
    Flashaholic* Stillphoto's Avatar
    Mar 2005
    Orange County
    Nice legos Superdave. Man what is it with those U2 tailcaps? I guess the intricacy of the build is a bit fail prone?
    We can just call those Vista tailcaps
    Time flies like an arrow, fruit flies like a banana.
  16. #136
    Nov 2007
    Quad Cities, IA
    thanks!
    Not sure.. I have a few that i've repaired in the past but this one is stubborn. It's even the newest style white plastic one.
    I guess it's now just a twisty
  17. #137
    Well, I think I've started to hit the motherlode with this whole Surefire Lego thing.
    I threw my BC8 and my SC1 in there just for S&G.
    The top one is a G2, with a Z59 clicky, and a P60L dropin, and the combat hook.
    The bottom one is a 6PL, with an A19, FM35 red filter, and a combat ring.
    Any ideas on some REALLY high powered LED stuff? I'm looking at the D26 LED by LF, but I'm not sure if it will be bright enough.
    Thanks much!
    No.... Maybe a 2nd job.... But that's about it. - Monocrom
  18. #138
    Flashaholic* tx101's Avatar
    May 2008
    London UK
    A pair of sharp pointy things
  19. #139
    Quote Originally Posted by tx101 View Post
    ...picture cut...
    ooooooh, I like the bezel on the left one. Esp. the look of the heatsinks. What's it called?
  20. #140
    May 2008
    London UK
    Quote Originally Posted by flash_bang View Post
    It came off a Spiderfire light
  21. #141
    Flashaholic* DHart's Avatar
    Jan 2009
    Pacific Northwest
    Surefire "clones" allowed? No "actual" Surefires were injured or dismantled in creating my first Surefire "clone" lego...
    Fivemega 18650 body, Solarforce crenulated head & clicky tail, Malkoff P7 lamp assembly, AW IMR 18650 cell.
    Wonderful, brilliant, "wall of light", great for general indoor use and for "in-your-face" defensive encounters.
    After seeing Bigchellis' wonderful P7 blasters, I'm inspired to dismantle my old E2...
  22. #142
    Aug 2006
    NYC
    Quote Originally Posted by DHart View Post
    Ironically, you created something that I had toyed with.... A light put together from different aftermarket, Surefire-compatable, parts.
    Must admit, you ended up with a better one than what I had envisioned creating.
  23. #143
    Flashaholic* Eric242's Avatar
    Jul 2006
    [-Mad in Germany-]
    I always wanted to use a FM18500 body but wasn´t quite sure what else to attach to it. Inspired by DHart´s "roomsweeper" I built my new EDC lego today:
    Surefire 6PD head + FM 18500 body + SW01 slim knockoff I took off my G&P Scorpion R500 (replaced it with the Solarforce switch DHart´s using on his light).
    The bright part is a LumensFactory 3.7V R2 LED dropin. I have two Novatac EDC clips coming from lighthound and one will go on this lego.
    Unfortunatelly there´s a small gap (~2mm) with the dropin installed. So I´ll try a file on this one. [Edit: Now the gap is gone!]
    I wish I´d have some modding skills! I´d mod the KL3-BK with a newer LED and make it my EDC light. I like the look of the KL3 much better than the 6PD head on this lego:
  24. #144
    Enlightened coyote223's Avatar
    Aug 2008
    Oregon
    Just a few spare parts.
    Surefire M2/M60, 6Z/M60LL, G2/M60F, 6P, E2E, Nightcore NDI, Nightcore Extreme, Fenix TK11, LOD. Milky L1, Milky L2, Milky CREEmator, Milky RoomSweeper.
  25. #145
    Jan 2009
    Pacific Northwest
    Quote Originally Posted by Eric242 View Post
    I wish I´d have some modding skills! I´d mod the KL3-BK with a newer LED and make it my EDC light. I like the look of the KL3 much better than 6PD head on this lego:
    Eric... cool little blaster! I like it... especially with the KL3 head. Nice pics too!
    I, like you, would like to have the skills and knowledge to do some modding rather than just play lego. Well.. you can always send that KL3 head to someone like Milky to have it just as you want it!
  26. #146
    Jan 2009
    Pacific Northwest
    Here's my latest lego... sure love this combo... really brilliant light with a great beam and the little E1e body is so nice!
    TLS Cree Q5 Head on E1e body
    No SF parts here, but I guess this could be called "clone-lego"
    TLS Cree Q5 Head w/Fivemega E1 body & Clickie
  27. #147
    Jul 2006
    [-Mad in Germany-]
    Wow, the TSL head looks really good on the E1e body . Pretty good colour match too.
  28. #148
    Jul 2006
    [-Mad in Germany-]
    Btw., is that a plain bezel or impact bezel on your TLS head?
  29. #149
    Aug 2006
    NYC
    Definitely plain bezel. Impact bezel on the TLS heads are very aggressive in style.
  30. #150
    Flashaholic herbicide's Avatar
    Feb 2006
    Worksop, UK
    I don't seem to have actually posted this here. Shocking, I know.
    [E1e head, LF EO-E1R, E1 body, McTC]
    [Here it is in bits]
    Clicky to see it in it's stock form.
