I see that there is an incandescent and an LED version of the 6P.
Is the LED version of the 6P a Cree LED?
The 6P original can last for 60 minutes (battery life).
Does anyone know how the battery life will be affected if I were to use a Cree Drop-in from LightHound http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2605
Would it be as near the 11hours of the 6P LED version?
Would a 9P with a Cree dropin (3X CR123:9.0V) be significantly brighter than a 6P with Cree dropin (2XCR123:6.0V)?
Would the 9P with a Cree dropin last significantly longer than 60 minutes (Original incandescent 9P says 60 minutes battery life)
Thanks.
edit: Does anyone know what the difference is between a 6P and a G2? They seem the same. Which would you rather have, given the price difference, 6P or G2?
Thanks.
