Read Lambda's posts on spraying reflectors to add beam smoothing texture. Search the "Homemade..." forum using the word "krylon".
I've tried it several times and it is a worthwhile improvement. It doesn't reduce overall light output as much as WriteRight, but still requires a fairly well-centered filament to get best results.
Might want to practice on old or cheap reflectors to get the hang of it. (Replacements for the Mag are less than $4)Very short, light blasts from a distance (kind of like "overspray") blur or blend minor artifacts but don't eliminate them.
Multiple applications to build an "orange peel" type heavier texture will require one last "wetting" application to change the dull frosted appearance to clear and reflective again. Mine turned out much like the PT40 relector.
I suggest using the high heat engine enamel type clear, rated for 500 deg.
WriteRight probably smooths a little better, but does reduce output and "whiteness" more noticeably.
FWIW - John
