Klarus
Results 1 to 15 of 15
Thread: What does "CR123A" mean?
    Flashaholic* Fallingwater's Avatar
    Jul 2005
    Trieste, Italy
    Default What does "CR123A" mean?
    I get it that "23A" means "two thirds of an A-sized cell", but what about the 1?
    I thought maybe CR1 was a type of cell or something, but the other CR1 cylindrical cells I can find are CR13N (1/3 N) and CR12AA (1/2AA), with only two numbers.
    Flashaholic* Sinjz's Avatar
    Oct 2003
    six blocks from ground zero - WTC/NYC
    Default Re: What does "CR123A" mean?
    One 2/3's of an A sized battery. There are also 223 batteries that have two 2/3 A sized batteies next to each other. Battery experts can confirm or correct it, but that's what I always thought.
    Jan 2003
    Oakland, CA
    What is an A sized cell?
    Flashaholic* matrixshaman's Avatar
    Jan 2005
    Outside the Matrix
    The C stands for Can't
    The R stands for Really
    The A stads for Ask
    Easy as 123 ...
    So you Can't Really Ask without getting stupid answers like this.
    Seriously though - I don't think I ever pondered the CR designation - just accepted that's what some battery wiz chose for it. I'd guess SilverFox might know.
    Or just a guess because these were used in CameRA's ?
    There is no important work, there are only a series of moments to demonstrate your mastery and impeccability. Quote from Almine
    Oct 2003
    Guess wrong on what CR means. See below.
    Flashaholic FRANKVZ's Avatar
    Jul 2004
    Western PA
    From wikipedia: IEC CR# series: Denotes lithium-manganese dioxide chemistry. Since LiMnO2 cells produce 3 volts there are usually no alternate chemistries for a CR# coin battery.
    Also the actual name: CR17354
    Oct 2003
    Quote Originally Posted by FRANKVZ View Post
    Looks like you're right. Just did a quick search on CR and came up with this page
    http://www.maxell.co.jp/e/products/i.../cr/index.html
    Guess CR denotes the battery chemistry. Who knew!
    Flashaholic* lctorana's Avatar
    Jun 2007
    Melbourne, Australia
    Default Re: What was an "A" Cell?
    An A cell is 17mm in diameter and 50 mm long. Only ever seen rechargeables, and 18500 Lions.
    A B cell is 20mm in diameter and the same length as a D cell.
    Only ever seen primary cells - and those only in the 4.5v "flat" cycle lamp battery. "BF" cells were about 35mm long and marketed by Eveready as the 927, or in pairs as the No8. A protected 18670 is a reasonable, if higher voltage, substitute for the latter.
    C and D you know.
    E cells were the same diameter as a D cell, but intermediate between a D and F cell in length. Again, only ever seen primary cells, were used in the Eveready 701 3v cycle lamp battery, and the English 126 4.5v battery.
    Completely obsolete.
    F cells are the same diameter as D, but about 90mm long. Primary cells used in lantern batteries, rechargeable cells are big enough to use as traction batteries. Oh how I wish they were cheaper.
    Nov 2006
    Wisconsin
    Li-Cfx coin cells are a valid replacement for almost any Li-MnO2 coin cell, and have a wider working temperature range.
    Flashaholic* Manzerick's Avatar
    Dec 2004
    Boston, Massachusetts
    Quote Originally Posted by matrixshaman View Post
    The A stads for Ask
    Easy as 123 ...
    Flashaholic* sysadmn's Avatar
    Feb 2007
    Between keyboard and chair.
    Quote Originally Posted by lctorana View Post
    C and D you know.
    What he said.
    Wikipedia has more than you wanted to know.
    Common uncommon battery sizes.
    Obscure battery sizes.
    Currently Swamped - use email to contact me.
    Using the Internet to deliver useful information and downright nonsense since 1980.
    Feb 2007
    Here's a NiMH F for $10.50. I bet shipping to AUS really ups the cost, though.
    Batteryspace has one with 1/3 more capacity (13000) for 1/3 more cost:
    http://www.batteryspace.com/index.as...OD&ProdID=1243
    Jun 2007
    Like I said, mate, I wish they were cheaper.
    I would love seven or eight of these to make a rechargeable "Big Jim" battery, but the price scares me.
    Feb 2007
    Ah, I was thinking 6v lantern battery. $40+ for four cells sounds like a lot, until you realize a good alkaline primary lantern battery runs $5-10. It it paid for itself in 4-8 recharges, it's almost practical.
    Jun 2007
    Certainly. I would love to do exactly that, as 4F lantern batteries list here for A$13, minimum.
    But - as you say, shipping is the killer. US online shops charge vast amounts of money for shipping.
    However, it's the 7xF to fill an 8F lantern battery, with the extra space to hold a NTC and perhaps a headlight relay. That's what I want, but it may be an impossible dream.
