Page 1 of 9 12345678 ... LastLast
Results 1 to 30 of 243
Thread: Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    Flashaholic* MillerMods's Avatar
    Mar 2005
    Columbus, Ohio
    Default Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    ...continued from here.
    Sign-up list for the MillerMods high power Arc AAA Cree XR-E mod is here
    Jun 2005
    Maryland
    Default Re: Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    Does anyone know if there is an updated list? The list sill says "updated to post #563".....figure Eric has his hands full.
    You don't know the power of the dark side! That's why I need lights!!!!!!
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by DarthLumen View Post
    I'll need to compile an updated list here. Hopefully I'll be able to take care of it this week.
    Here are some shot's comparing an LOP SE on high w/ an SV1H Lux I (Left), the Cree monster at 1 watt or ~320mA (center), and one of my Luxeon Arc mods w/ an SWOH Lux I driven at 1.5 watts or 470mA (right). The lights are about 1 foot from the wall.
    Both using freshly charged NiMH Rayovac Hybrid cells:
    Arc Cree (P3-WG) on high (3/4 watt, 800mA draw from the cell) left, Fenix L0D CE on high right.
    Arc Cree (P3-WG) on high (3/4 watt, 800mA draw from the cell) left, Fenix L0D CE on low right.
    Arc Cree (P3-WG) on high (3/4 watt, 800mA draw from the cell) left, Fenix L0D CE on medium right.
    Arc Cree (P3-WG) on low (50mA drive to the Cree) left, Fenix L0D CE on high right.
    BTW, I think the WG has a nasty greenish tint to it. It's the only one I have on hand that's assembled.
    Here's some photo's of my first trial runs.
    LOP SE on high (stock driver w/ an SV1H Lux I) vs. Arc AAA head w/ Cree XR-E (P3 brightness). The lights are about 6 feet from the wall.
    Arc Cree @ 180mA
    Arc Cree @ 240mA
    Arc Cree @ 350mA
    Here are the options for the high setting and approximations for the Cree X-RE and my driver output on high:
    3/4 watt = ~240mA drive 50-70 minutes runtime to 75% intial brightness
    1 watt = ~320mA drive 30-50 minutes runtime to 75% intial brightness (This power level can be run continous but will get fairly warm.)
    1.25 watt = ~390mA drive 25-35 minutes runtime to 75% intial brightness (This power level can be run continous but will get warmer than the 1 watt.)
    1.5 watt = ~480mA drive 15-25 minutes runtime to 75% intial brightness (It's best not to have the 1.5 watter on for more than a few minutes at a time. It can get hot.)
    * Runtimes will vary because of both the temperature of the light and capacity and quality of the NIMH cell used.
    * I'll try to get more precise about the temperature soon. I have an IR themometer I plan on using for testing.
    With a P3 bin the output estimates go as follows depending on Vf and other factors:
    3/4 watt ~240mA ~45-60 lumens
    1 watt ~320mA ~60-75 lumens
    1.25 watt ~390mA ~75-85 lumens
    1.5 watt ~480mA ~85-95 lumens
    With the Q3 bin the output estimates go as follows depending on Vf and other factors:
    3/4 watt ~240mA ~65-80 lumens
    1 watt ~320mA ~80-95 lumens
    1.25 watt ~390mA ~95-105 lumens
    1.5 watt ~480mA ~105-115 lumens
    Options for low level output are 25mA, 50mA, or 75mA drive.
    Runtimes on LOW power for all models (tested using a 900mA NIMH cell):
    25mA drive = 7 hrs @ ~4 lumens, 50mA drive = 4 hrs @ ~9 lumens, 75mA drive = 2.5 @ ~14 lumens.
    The price is $120 with 2 stages and $110 with one stage for a complete head and body. The head by itself will be $15 less. The price for the Q3 premium Cree's (when they are available) will be $20 additional (this price will lower as they become more available). If you have a Cree you want to send to me for use in your mod, subtract $5. Standard Cree to be used will be the P4 brightness bin.
    Parabolic cut and polished reflector are standard and the only available options for the reflector for this version of the Arc AAA mod. The lens on the Cree is made of glass, not plastic.
    Shipping costs are $5 for Priority w/ delivery CN, $2 for First Class w/ delivery CN, and $5 for international airmail shipping
    Big THANKS! to Erasmus for doing a groupbuy on the P4 WH's
    Here is the current sign up list:
    WAVE_PARTICLE P4-WH, 240mA (0.75 watt), 25mA (paid)
    FlashInThePan 50, 1.50, P4-WH (confirmed)
    coyote 25, 1.50, Q3 (WD tint prefered) in for 2
    russtang 25, 1.00, P4-WH (confirmed)
    baylisstic 25, 1.25, P4
    BeamJunkie 50, 1.5, P4-WD or highest bin available (head only) (confirmed)
    Manzerick 25, 1.25, Q3
    cqbdude ?, ?, Q3
    gjg 75, 1.50, Q3
    marcdilnutt 25, 1.50, P4-WB (confirmed)
    cy P4-WH, 1.25, 50mA (paid)
    Thujone 50, 1.25, Q3
    quantile P4-WB, 1 W on high, 50 mA (paid)
    Nell Q3 (will specify specs. later)
    Sharpy 50, 1.25 Q3 and 75, 1.50, Q3 (both heads will be provide by Sharpy)
    fasteddie 50, 1.00, Q3 and 50, 1.25, Q3
    Trashman 75, 1.50, Q3
    kazu 50, 1.25, Q3
    Carpe Diem 50, 1.25, Q3
    masakame 25, 1.50, Q3
    iocheretyanny 50, 1.25, Q2 or Q3
    Miciobigio 50, 1.50, Q3
    Luff 50, 1.25, P4 & Q3
    AndyTiedye 50, 0.75, Q3
    AuroraLite 50, 1.00, P3 or Q3
    Scottiver 2 P4's, both 2 stage 50, 1.25 watts (one head and one complete)
    TENMMIKE 25, 1.00, Q3 or most premium for 4 of the same (may want moved down on the list)
    mcrich 50, 1.25, P4 or Q3
    MrMimizu 50, 1.25, Q3 or may provide Q3 (See post #672)
    ydna 50, 1.25, Q3 or P4
    Newf-llb 50, 1.25, Q3
    drews1 50, 1.00, Q3
    grift 50, 0.75, Q3 & 50, 1.00, Q3
    FlashMike 50, 1.00, Q3
    rob_e 50, 1.50, Q3
    Codeman 25, 1.50, Q2 or Q3
    LouRoy for 2, 50, 0.75, Q3 and 50, 1.25, Q3
    d'mo 25, 1.50, Q3
    Chao 50, 1.00, Q3
    Roboholic 50, 1.50, Q3
    UncleFester 25, 1.50, Qx
    Nuutaro 75, 1.50, Q3
    VerbalK 75, 1.25, Q3
    LEDninja 50, 0.75, P3
    lightrod 50, 1.25, best bin available
    FsTop 25, 1.25, best bin available
    bwm 50, 0.75, P4 WH
    Justone 50, 1.25, Q3
    CodeOfLight .25, 1.25, P4
    ProofTech 50, 1.25, emitter supplied
    Varriano 75, 1.25, Q3
    bexamous 50, 1.25, P4
    dtlent 50, 0.75, P4 (head only) and 75, 1.25, Q3 (head w/ body)
    daz 75, 1.25, Q3
    Straightedge 50, 1.25, Q2 or Q3
    Bobdrus 75, 1.25, Q3
    vetkaw63 50, 1.25, Q3
    ScarabDrowner 50, 1.00, Q3
    eltel999 50, 1.25, Q3
    Jeweler 75, 1.50, P3 or Q2
    BVH 50, 1.25, Q3 (head only)
    aiouem 50, 1.00, Q3
    pryan 25, 1.25, Q3
    Amorphous 75, 0.75, P4 for 2 ( now )
    Amorphous 75, 1.25, Q3 for 2 ( when available )
    esunnycpf 50, 0.75, Q3
    liteMANIAC 50, 0.75, Q3
    pinepoint ?
    Kevski 50, 1.00, Qx
    blitzlicht65 50, 1.25, Q3
    alanhuth 25, 1.25, Q3
    iNDiGLo 25, 1.50, Q3
    JnC 50, 1.25, Q3
    tuna 50, 1.25, Q3
    stevevh 25, 1.00, P4
    jefft 50, 1.25, Q3
    DaveNagy 50, 1.50, Q3
    Siegfried 25, 1.00, Q3
    jki 50, 1.00, Q3 for 2
    mudman cj 50, 1.50, Q2
    tsask ?, 0.75, Q3
    pdm 50 ,1.50, P4
    frankr 50, 1.25, Q3
    carlsjrman 25, 1.25, P4
    Zionxem 50, 1.25, P4 or best available
    svolich 50, 1.25, Q3
    AustinEd 50, 1.25, P4
    RIDE 50, 1.25, Q3 or best available.
    JohnnyDeep 50, 1.25, Q3
    Clickie 25, 1.00, P4 and a Lux mod on provided Arc
    cpfx 50, .75, Q3
    cocoa 50, 1.25, Q3
    Koz99 50, 1.25, Q3
    tsask ?, 0.75, Q3
    Bright 50, 1.00, Q3
    Lenny 50, 1.25, Q3
    Navistar 75, 1.00, Q3
    DrizzitT 50, 1.00, P4
    Gypsy 50, 1.25, Q3
    Per Arne 50, 1.25, Q3
    copykat 25, 1.50, Q3
    kry81 75, 1.50, Q3
    dansperry 50, 1.00, Q3
    gswitter 50, 1.25, P4 (WD prefered)
    kashmir 50, 1.25, Q3
    millerje 50, 1.50, Q3
    gefff 50, 1.25, Q3
    rdh226 25, 0.75, P4, WH/WJ/WD tint (whatever I can get "sooner"), 25, 0.75, Q3, WH/WJ/WD tint (whenever...), & 50, 1.25, Q3, same tint as unit above.(I have three unused Arc AAAs I can provide for upgrade.)
    Daekar 25, 0.75, Q3
    Ozniot 75, 0.75, Q3
    Ned 50, 1.00, Q3
    wuhair 50, 1.00, Q3 (WD)
    Groundhog66 1 - 50, 1.25, P4 (WD) (and when available): 1 - 25, 1.0, Q3 or Q2? and 1 - 50, 1.5, Q3 or Q2?
    Gointothelight 25, 0.75, P4 (WD)
    zumac99 50, 0.75, P4 (WD)
    racer7 50, 1.00, P4 (WD)
    Pyros
    ananddev 1 - 50mA 1.25W p4 (is WD the whitest?), 1 - 50mA 1.25W Q3 (When they become available)
    Rustrel 50, 1.25, Q3
    Freyth 75, 1.25, Q3
    yoyoteen 50, .75, P4 HEAD ONLY
    AustinEd 5mA?, 1.25 best Cree available, white XO tint
    Austin 50, 1.25 Q3
    FRANKVZ 50, 1.00 Q3
    WTH 50, 1.00 best bin available
    err0r 50, .75 Q3 WD
    slaps 25, .75 best bin available
    THE_dAY 25, .75 best bin available
    GregY 25, .75 best bin available
    Kraid 25, 1.5 Q5 or best bin available
    xoltri 50, .75 ,2 LIGHTS best bin available
    DarthLumen 2 LIGHTS, both single stage 50mA
    nugget 75, 1.25 best bin available
    Dizos 50, 1.25 Q3
    dd61999 50, 1.25 Q3
    yaesumofo no specs, best bin available
    bfly 50, 1.00 best bin available
    crazyglockman 25, 1.5 Q3 or best available
    updated to post #
    I'm still good for a 25/1.50 Q3 complete.
    Ray
    Good people need to be there for each other. It's the only way to stay sane in a sometimes insane world.
    Unenlightened
    Sep 2007
    Philadelphia, Pa
    I know I'm late but I'd like to sign up for one of your lights 25/1.5/Q3 or whatever is left. Thanks,
    Charles
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by crazyglockman View Post
    Charles
    I plan on building these for a long time. I don't really have a limit on how many I will supply, it's just a matter of time until I get them all built.
    I added my name to the list (#683) but am now curious about a different emitter. After comparing my Fenix L2D CE to my new P2D Rebel 100 I am much impressed with the Rebel 100 emitter. I like the warmer color of the Rebel. Is it possible to use a Rebel 100?
    Nov 2003
    sfv, california
    hi MillerMods, i've continued the list from your last list update, post #563:
    Austin 50, 1.25 Q3
    FRANKVZ 50, 1.00 Q3
    err0r 50, .75 Q3 WD
    FsTop 25, 1.25 best bin available
    Dizos 50, 1.25 Q3
    dd61999 50, 1.25 Q3
    there were also a few members changing orders from previous list, mainly to upgrade emitter to best available.
    i guess you can deal with that when you get to them.
    i hope that helps.
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by THE_dAY View Post
    i hope that helps.
    Thank you much! That helps me out a lot. I just haven't found the time lately.
    Jun 2005
    Maryland
    Austin 50, 1.25 Q3
    FRANKVZ 50, 1.00 Q3
    err0r 50, .75 Q3 WD
    Dizos 50, 1.25 Q3
    dd61999 50, 1.25 Q3
    i hope that helps.
    I'd like to chage my order....Hopefully, this won't cause too much of an issue or a headache....my apologies.
    25, .75 (1 light)...Q3 or best bin available (rebel 100 if possible)
    Thanks!!!!!!
    Banned Groundhog66's Avatar
    Jan 2007
    Bay Area, CA
    Please change my order to 1 light 50, 125, w/best available emitter
    Thanks
    Tim
    With the improvements available in emmiters, please modify my order to 25mA low, .75W high, best bin available with a neutral to warm tint.
    Many thanks!
    Apr 2004
    Northern Calif.
    I already mentioned this back in the first thread, but just to be extra clear:
    My current order is: DaveNagy 50, 1.50, Q3
    Please change it to: DaveNagy 50, 1.50, <best available bin>
    Thanks! I guess I'm a neutral-tint kind of guy, if it turns out that I have a choice in the matter.
    Is there any way to know just how far down the list we are currently?
    Rolleye11 Re: Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    Two for Wolfgang_Ludwig 50 1.25 best available
    Flashaholic* coyote's Avatar
    Dec 2002
    eastern oregon
    folks, from what i understand and from what Millermods said in post #621, everyone will get a chance to upgrade their LED to what's available at the time their light is made.
    here's what eric said in that post:
    "I haven't made any big purchases of stock so I don't mind if orders change. Instead of updating the list all over again however, I'll just change the order/specs when I contact the next person in line to see if they are still interested..."
    so don't worry about getting the best available LED, from what i gather, you will!
    (ps: on the personal side- while i'm already signed up for two of the current units, i'd also love to see my name added to the end of the list for two additional units with the future R4-bin LED which probably won't be out for at least a year. proudly i was the first to request them back in post #610)
    Mar 2002
    nebraska
    Put me down for (two) 50, 1.00, and best available emitter, although I guess that is not necessary. These look very cool, I am way behind the times. Doug Um, how does the two stage thingy work??
    Grateful friend of Bill W.
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by dtsoll View Post
    The levels are changed from low to high by twisting the head further down. I use a simple hand made switch. It has proven to be a very reliable switch design.
    25, 1.25 - best bin available
    Thanks.
    Jan 2003
    Oakland, CA
    I guess it would be foolish to not request the best bin available. Please update my order to best available.
    Eric,
    Please update my order from: JohnnyDeep 50, 1.25, Q3
    to: JohnnyDeep 50, 1.25, Q5 - or best available bin
    Aug 2005
    Hessen, Germany
    Hi,
    i`m in for a q3; 1,5 W; 50mA.
    PM with some questions sent as well!
    Gäb es nur eine Krone, wohlan ich schenkte sie, der Tapferkeit zum Lohne, der deutschen Infantrie!
    Sigh Re: Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    WAIT A MINUTE - I seem to have slipped way down the list:
    - On the original signup pre-order list, I am #46 on the list
    - On the list in this thread, I've been demoted to 132
    What gives - all I did was to ask to modify the original order for a Q3 to request best bin available, in post #631 of the original thread?
    PLEASE put me back to 46th, instead of 132...
    Regards,
    Rick
    Nov 2006
    League City, TX
    I have a Q5 in hand waiting. Please change mine to a supplied Q5.
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by FsTop View Post
    Regards,
    Rick
    Oops, I meant to click the quote button, not the edit. Anyways,
    You're still on the list at 46th position, it was just a duplicate when you revised your order. I just copy pasted the addition to the list.
    Thanks - had me worried...
    Rick
    LEDninja's Avatar
    Jun 2005
    Hamilton Canada
    Quote Originally Posted by MillerMods View Post
    The pre-order list for my Arc AAA Cree XR-E mod is here
    I think you need to update here. Still points to the original thread.
    Mar 2005
    Columbus, Ohio
    Quote Originally Posted by LEDninja View Post
    Oh yeah... Thanks
    Jun 2005
    Maryland
    Thinking Re: Sign-up thread for the MillerMods high power Arc AAA Cree XR-E mod (Part 2)
    Regards,
    Rick
    Where are you going (link) to see a numbered list? Figure I'm doing something wrong. I've asked before, so forgive me. I just can't seem to ever find the right link.
    Thanks.
    The signup lists are not numbered - I copy/pasted it into Word, to get a count of the number of lines.
    Jun 2005
    Maryland
    Ok.....thanks.
