Acebeam
Results 1 to 4 of 4
Thread: Maximum possible RGB lm/W?
    Flashaholic LightForce's Avatar
    Jan 2006
    EU, PL, MMz
    Default Maximum possible RGB lm/W?
    Hi,
    Please explain me why RGB LEDs are claimed to have maximum theoretical limit of 400 lm/W?
    I've heard that continuous white light source which emits all the energy between 400 - 700 nm can achieve only 245 lm/W.
    How many theoretical lm/W can RGBA LED have?
    How to calculate it?
    D.
    True Mag T5 45W HID is here
    Default Re: Maximum possible RGB lm/W?
    You'd have to ask whoever came up with the estimate. It's possible that they looked at how many electrons you can move with one watt of electricity and produced a figure for how many photons those electrons could be converted into.
    This figure ought to vary depending on what technology you use to produce that continuous white light.
    No clue. I understand that inefficient green LEDs are holding back this technology. You'd have separate figures for best we have and best we think possible.
    Don't know how you'd calculate it, but I do know how to measure it. You would look at the total energy going into the unit in watts and the total light coming out in lumens, and you would have a lumens per watt figure, same as any other electric light.
    *Flashaholic*
    Nov 2003
    Flushing, NY
    The best explanation of this is here. See pages 9 through 12 (sections R1.6-R1.7). Also, the entire document is a very interesting although lengthy read.
    In short, you can get up to 400 lm/W using three sources by giving up a little color rendering (a CRI of 80). You can get a nearly perfect CRI of 98 using 5 sources with a maximum possible efficacy of about 325 lm/W. Even an expert would be hard-pressed to tell a CRI 98 source from a much less efficient broadband source. In the real world we'll never reach these numbers, but I'd be willing to bet we'll eventually get to at least 75% of them, perhaps even 90% on the outside.
    That's an excellent article jtr. In it, it says "Recently, LumiLeds and Philips announced a 610 nm (orange/red) LED with a luminous efficacy of 100lm/W; and LumiLeds has reported green InGaN-based LEDs having luminous efficacies in the range 50 lm/W." Is that backwards or did Lumileds really achieve 100lm/W in red/orange?
    Quote Originally Posted by jtr1962 View Post
