Originally Posted by
DM51
There was a previous thread where someone actually used an aspheric lens with an incan, but I can't find it. In the same way as with the LED pattern, there was a clear projection of the actual shape of the filament.
An aspheric lens is designed to work best with a point source of light. The principle is similar to using an accurate reflector – it will work best with small sources of light, which is why the best-throwing pencil-beam lights are those with short-arc bulbs (for example, the Maxa Beam).
Because of the critical importance of focus, it would be necessary to use an incan bulb with as small a filament as possible, and more importantly a horizontal filament rather than a vertical one. The more powerful hotwires, with longer/vertical filaments, would not be suitable.
Just looking at the WA 1111 & 1185, these are both fairly small and horizontal and would probably work OK. The 5761 is small-ish and horizontal, but the coil of the filament is larger, ~1.5 mm in diameter, and focus needs to be very accurate with an aspheric – 1.5 mm might sound small, but with this application it might be too large.
With an incan, you would get an enlarged and fairly precise projection of the filament’s shape, which would look quite weird and because of the artifacts it would have a pretty limited use, apart from wowing people who saw it.
LEDs are also very much more directional than incans. Even the widest-angle LED doesn’t emit light behind it, so it will throw at least 2x as much of its output forward compared to an incan bulb, where the beam is pretty well omni-directional (spherical) until directed by a reflector.
A reflector is in fact useless when used with an aspherical lens, as the lens only works with a point source. Any light hitting the lens via a reflector will still come out, but this will be in a random direction as spill.
Depending on the diameter of the lens and its distance from the light source (a factor of its focal length) the useful focused light from an incan might be as little as ~15% of its output, while with a LED which threw most of its light forward in a fairly tight cone anyway, like a Cree XR-E, the figure might be even better than the ~66% you get with a reflector.
I think for these reasons, LEDs will have a significant edge over incans with aspheric lenses.
