rdhfreethought
- Joined
- Nov 11, 2007
- Messages
- 12
I cant believe these things do not exist. Peter white and Nordicbike only talk about dynamos as not producing enough wattage, then they say the typical cyclist can only make 125 watts of power and even a 3w generator would add a noticable amount of lag, and a 20w would be undesirable. http://nordicgroup.us/s78/dynamo.html
First off Lance does 493 watts http://www.tdfblog.com/2005/06/inside_armstron.html
So that means the rest of us are probably going half as fast, so 200-250 watts. 1% is hard to measure subjectively.
Second, who ONLY rides at night. Plus, if you didnt start during daylight hours, you COULD start with a charge battery at half the mAH. If you were to use a 3W efficient generator to charge a battery, you could burn at 6W for twice as long, or use half the battery size. That would make you faster and make up for the weight of the generator.
So why do people try to use complicated dynamo stop circuits. Why not just charge a battery and use the juice to keep things charged on long trips like: http://www.greatdividerace.com/
Seems like burning fat not fossil fuels is the way for us to charge our batteries...am I wrong somehow???
