brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
PELICAN M6 UNDERWATER TESTS
Static test: 1 Hour
More out of curiosity than great expectation, I turned on one of my M6's, placed it in the sink, turned the cold water on full, and let the sink fill while the M6 was buffeted by the intense stream which gradually calmed as the sink filled to its full eight inch depth. I returned after one hour.
Dynamic test: 15 minutes
This was a much more demanding test. I submerged the M6 and clicked it on/off at different speeds 450 times. I also banged it against the sink bottom with mild-moderate force multiple times.
Results: Static test
The light was still burning dimly when I hauled it out of the water, dried off the exterior, took the light apart and closely examined it. I was surprised to find that the interior was bone dry without even the slightest dampness anywhere within the light.
Dynamic test
The M6 never failed to light. After drying the exterior and opening the light the interior proved to be just as dry as in the first test.
Conclusion
This particular Pelican M6 proved to be fully and functionally waterproof at shallow depth. I don't have the time or patience to test my other M6's, but I would expect their performance to be at least similar to this one.
Brightnorm
Static test: 1 Hour
Dynamic test
Conclusion
Brightnorm
