G2L + AW Protected 17670 (+ Ultrafire WF-139) + BOG Cree Q5?
adamlau
Los Angeles
Are there voltage regulation concerns that I should be aware of? I am assuming that the regulated BOG replacement would handle voltage-related issues...
jbviau
MD
Unfortunately the BOG drop-in won't run regulated with a single li-ion rechargeable battery as far as I can tell. The BOG's input voltage is listed as 4.5-9v, which a single 17670 can't supply since it's more or less limited to 3.7v. The light should be dimmer as a result compared to running on primaries or 2 rechargeables. Can anyone who's tried this confirm?
kavvika
Chicago
I've heard that as well, but I can't confirm it, as I don't have one. The only module I've come across personally that is regulated on one 3.7v cell is DX #1343.
harddrive
Australia
If you want regulated with a single 17670 I'd say you have either a wolf-eyes or the Dereelight drop in modules.
I have some of the first Wolf-Eyes modules and they are very well made and fit in surefire or wolfeyes bodies very well.
I decided I wanted a brighter module with a Q5 in it. I have just ordered the Dereelight 1S module driven at 1.2A and fully regulated on a single 17670 or 18650. Should be very bright.
http://www.dereelight.com/module-list.htm
http://www.cpfmarketplace.com/mp/showthread.php?t=170818
Mercaptan
Any idea how long this setup will run? I'm contemplating this for a Z2 setup, the 1.2 A module + 17670...
Anyway, should probably last longer than the Wolf-Eyes on 2xRCR123s, right?
:help:*screams out for answers and help*:help:
divine
Virginia
I don't have a 17670, so I took one of my 3.6 volt RCR123's out of mine and used a screwdriver to close the contact and it is about 30% dimmer and it flickers. :shakehead
harddrive
Australia
Well Dereelight say the S1 driven at 1.2A runs for for 90mins with a 18650.
Considering a 17670 is just over 2/3 the capacity of a 18650 I would guess just over an hour.
Not sure about the WE and 2xRCR123s. The WE drop ins I have are both 3.7-6v so they only get used with 18650 or 17670.
adamlau
Los Angeles
The upcoming WE HO D26 is rated at 3.7-13V and should work with either 17670s, or RCR123s.
