Page 1 of 2 12 LastLast
Results 1 to 30 of 57
Thread: Blue CREE Aspherical Mag
    Default Blue CREE Aspherical Mag
    This emitter
    This driver
    This 50mm x 35mm aspheric lense
    This blue glow in the dark powder
    This HAIII heatsink
    2 x AW Protected LiIon "C" Cells with a 1" PVC adapter
    and a 2D blue MAG-LITE:
    Blue after glow:
    Close range wall beam shots:
    Outside beam shots:
    Outside beam shots (long range):
    Thank you for looking
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    MA
    Default Re: Blue CREE Aspherical Mag
    First different colored Aspheric Mod I've seen, I'm guessing the beam is quite visible at night.
    Yes it is, I really didn't think it would be like that, but the beam is surprisingly visible at night.
    Flashaholic* LukeA's Avatar
    Jun 2007
    near Pittsburgh
    Very nice.
    You know you can focus it tighter? You lose the die projection, but get a tighter, brighter spot.
    A little madness never hurt anybody.
    Aug 2004
    Sydney, Australia
    FULLY freaky appearance on those walls- it looks like it sits in space, not on the building wall!!!
    I guess that's blue light for ya'.
    Thanks for the look!
    Kind Regards
    David
    Flashaholic* TorchBoy's Avatar
    Jan 2007
    New Zealand
    Please don't forget to keep pics to 800 pixels wide. Thanks.
    No, a torch does not always mean flames.
    Ian.
    LED Driver List - now database driven and with new search features.
    Quote Originally Posted by TorchBoy View Post
    Done. Sorry about that
    Quote Originally Posted by LukeA View Post
    Very nice.
    Will try that, I didn't play much with it's focus actually.
    Quote Originally Posted by ICUDoc View Post
    You're right, it does look like it's in mid air before the building
    UncleFester's Avatar
    Apr 2004
    Desert Hlls,AZ
    Do yourself a favor and DON'T look into that beam unless you're at least a 100 yards away. I built a royal blue AA minim@g for a friend and thought it'd be interesting to see what effect the beam had. Immediately afterward I was concerned I had permanently hurt my eyes. This is with a MadMax Lite sandwich, 2 AA alkaline, and a 20mm reflector.. That LiIon powered Aspheric might be dangerous at close range.
    I believe LukeA is right. If you loosen the head until it almost falls off, the light now going into your spill goes into the beam. You do lose the picture of the die though. As you turn the head out, the picture sort of comes back but it's never clear like your pictures.
    Have fun with it.
    Ask not what Flashoholics can do for you, but what can you do for Flashoholics
    Thats really amazing. But why blue? Glow Powder ok, Maglite ok, but why the LED?
    Did you have to machine the head, or the lens?
    Please post some pics with the highest concentration and a loong distance!
    Gruß td
    May 2005
    Finland, Helsinki
    Based on how the LED chip looks that seems to be previous generation Cree XR LED and not the XR-E. With blue XR-E it would be over twice as bright
    Newb question, what did you mix with the glow powder to get it to stick?
    I gotta try this, thats awesome!!
    Flashaholic* Aircraft800's Avatar
    Apr 2007
    DFW Texas.
    WOW! That ROCKS! You can scare the kids with that one
    Great FUN light! (Now if you can only get it to project the Bat Signal)
    Jan 2007
    New Zealand
    Man, that's nice. I presume if you shone it on a red coloured/illuminated building there'd be even more of a 3D effect. If you could get Cree to make the die in the Batman logo shape instead of square...
    If a tri-colour LED was used would it just project the three dice next to each other?
    Ian.
    Jun 2007
    near Pittsburgh
    The center could be in focus, but the portions of each die nearer the outside would probably end up somewhat blurry.
    Quote Originally Posted by UncleFester View Post
    Thanks for the tip, I didn't know blue light isn't good for you. Anyway, I didn't look into the beam and have no intension of doing it. Actually I rarely use this light as it not very practical.
    Quote Originally Posted by traildesaster View Post
    Gruß td
    Well, I bought the LED out of curiosity and had a spare Mag, spare Aspheric lense etc., I never even planned this mod.
    I didn't machine anything, just shaved the reflector's lips so the Aspheric lense will get deeper in the head.
    I will try to take more pics when I can. I have this mod for some time and the reason I didn't share it here was because I didn't have good outside shots and I eventually decided to settle for those ugly building pics.
    Quote Originally Posted by crackerkorean View Post
    I used 2 ton clear weld 30 minutes epoxy glue. I mixed approximately 1/3 glow powder and 2/3 epoxy.
    Flashaholic* Nake's Avatar
    Oct 2006
    Cleve. OH
    It says "custom order" for the emitter on KD. Did it take long to get it?
    That is very cool.
    May 2007
    Melbourne, Australia
    I'm making a 1C version with a red cree... I broke the dome off though, so i'm awaiting the arrival of another
    Quote Originally Posted by Nake View Post
    I don't remember waiting too long for it and I had other things in that order too. I thing it took maybe a week more than usual.
    Quote Originally Posted by KrisP View Post
    What driver do you use to run the red CREE? I know that red (and green) CREEs VF is about 2.2V (maybe even up to 2.6V?). I used this driver to run a red CREE for a while, it was very nice but while experementing with it something went wrong and it was eventually fried.
    May 2007
    I tested the red cree with two DX boards, one was the 700mA driver with the AMC7135 regs, I measured the output current and it was around 660-670mA. I also put a 5-mode 1000mA driver in parallel after the 700mA board to get multi-modes which worked well The 5-mode has three AMC7135 regs, so I plan to just desolder one and see how it goes as a 700mA multi-mode driver, when my new LED arrives
    Jan 2007
    New Zealand
    I also put a 5-mode 1000mA driver in parallel after the 700mA board ...
    What does that mean?
    Ian.
    May 2007
    Sorry, I meant the 5-mode 1000mA driver was wired in parallel to the 700mA regulator board.
    So:
    Battery -> switch -> 700mA reg board -> 5-mode 1000mA board -> LED.
    The first board just limited the current to 700mA so the 5-mode board would only have a max setting of 700mA rather than 1A. Since the red LED Vf is so low, the voltage drops of the two boards didn't affect the output at all.
    Jan 2007
    New Zealand
    KrisP, I think that's better described as the first board is driving the second board, not that they're in parallel to each other. It seems like a good way to do it for a low voltage LED.
    Ian.
    May 2007
    Ahhh... Yes, because they're not coming from the same supply, one is actually supplying the other
    Jan 2007
    New Zealand
    Now that I think about it, why not just disable one of the AMC7135s from the 5 mode board?
    Ian.
