I am surprised there hasn't been much mention of these new batteries. I found this interesting thread from a R/C site:
http://www.rcgroups.com/forums/showthread.php?t=768729
They have all sorts of info, plus a link for the specs:
http://www.elektromodely.sk/A123/APR18650M1_2007-05.pdf
It is especially nice that they are widely available (lower price) and presumably have a proper charge and any protections necessary for safe use. I have been staying away from Li based batteries due to safety issues and sticking to NiMH.
They discovered that they are made by A123, the same company making car batteries for GM Volt (gm-volt.com) and other power tool brands. Therefore, they are very tough!!!! No NiCd or NiMH can come close to it. RC people seem to be pushing them to 10C and beyond, yet they survive.
Standard charge is over 1C, so very quick to recharge. From that PDF:
"Maximum continuous discharge 30A" which is about 27C!!!!!
Operating temp range is also great. The last chart, lifespan @100% DOD is simply astonishing (however no mention of rate of discharge, so assume benign 0.1C) - about 2K cycles using 80% of original capacity rule!!!!
Am I not interpreting these numbers correctly? Is A123 is know to exaggerate like others? How much would you believe these specs?
I did know that Li chemistry can live a long life. Still I never heard of a Li chemistry cell handling many-C discharge rates AND living for well over 1000 cycles. Then again I don't know much about them.
So open question. What do you think/know of these new VPX power packs? What do you think/know of A123's cells for consumer market (power tools and such)?
Personally if this info is correct I would be very happy to switch to them for all higher current applications provided safe charger and operation (no explosions and such).
My latest power tools packs are 19.2V NiCd and cannot complain too much but: 1) heavy, 2) performance quickly tanks at higher rates (tougher jobs)
Even handheld vac drains its NiCds very quickly (not to mention slow charge rate kills cells over time).
