sure but no quick answer
http://safetravel.dot.gov/index_batteries.html
If you're planning a trip, bring your laptop computer, cell phone, camera, personal digital assistant, or other battery-powered device along. These items are safe to fly with!
Batteries pose little risk contained in the devices they power. Taking the battery out of the device does not enhance safety. To be safest, carry the device with you, not in your checked baggage. Do not remove the battery!
Carry your battery-powered devices or spare batteries in your carry-on baggage. In the passenger compartment, flight crews can better monitor safety conditions to prevent an incident, and can access fire extinguishers, if an incident does happen.
Finally, if you must carry a battery-powered device in your checked baggage, package it to prevent inadvertent activation. Cordless power tools, for instance, should be packed in a protective case, with a trigger lock engaged.
Many travelers like the convenience of readily available spare batteries. It's safe to travel with spare batteries, as long as you follow these simple spare battery tips
http://safetravel.dot.gov/tips.html
prohibited items list TSA
http://www.tsa.gov/assets/pdf/Prohibited%20and%20Permitted%20Items_printerfriendly_3-16-07.pdf
i see no TSA restriction
so todays assessment for the above data is carry it where you can tell if anything is going wrong, dont put it in your cargo hold baggage.
UPS ground shipping would be best, then take a few spares, the regulations of all sorts are carried out by HUMANS at the location, you could end up donating a case to the TSA, if some person thought that it was a "shipment" of batteries and not a few "spares"
