JimmyM
Sold.
It's an FM 2.5 (ish) Nickel C body with head finning and body machining with a lightly crenelated bezel. It was originally made to accomodate 2x18650s
It has a charging jack in the side below the switch.
I've turned it into an ROP-Hi, Lithium Edition.
It has 2x AW protected Lithium C cells.
Here's the really neat part. It has the only (as far as I've found) MOSFET modded C body switch.
Because of the way the MOSFET is wired, focusing is by thread travel only, the "quick focus" doesn't work. Contact between the aluminum reflector and bulb post would turn it on. I've fixed the height so screwing the head all the way down doesn't turn it on, but does allow the focus to go past "tight" to slightly flood.
I've fitted it with every resistance fix I can find.
It also comes with a MOP/HOP reflector and borofloat lens.
ADDED: 1 package of Bulbs (High and Low) to go along with the HOLA bulb that's already in it.
Asking $235. Includes shipping in CONUS. International shipping to be arranged per buyers choice.
