Results 1 to 8 of 8
Thread: Remora + Shark + Shark + ... ?
    Default Remora + Shark + Shark + ... ?
    Wayne (or anyone of more knowledge than I), would it be possible to wire a single Remora to more than one Shark? Similar to that of an analog pot.
    -DF
    KineticParadox ...a personal web space with my CBA Battery Testing and my LED Bin Coding Charts.
    Unenlightened
    Nov 2007
    Default Re: Remora + Shark + Shark + ... ?
    Quote Originally Posted by DFiorentino View Post
    -DF
    I kind of thought !
    first SHARK with bridge, second SHARK without bridge, ...
    Mono
    Quote Originally Posted by Mono View Post
    I kind of thought !
    Mono
    Exactly!!!.
    Wayne
    Flashaholic* LED Zeppelin's Avatar
    Sep 2005
    Great Lakes
    Mono, your post belies your postcount!
    So is it possible to run say 8 sharks of one remora? If so how would it be wired?
    Mac
    www.macscustoms.com
    *Note* Shipping Insurance must be requested.
    Wire the third, fourth... just like the 2nd one in the diagram above.
    Wayne
    I kind of thought !
    Mono
    I'm still a bit confused on how to do this.
    I still remove the trimpot from both sharks and bridge the gap of the to 2 pads correct?
    Led + and LED - from both boards wired together to the LEDs?
    Vin and Vout from battery connect to both boards?
    And the ONLY connection I need between remora and the SECOND blue shark is PWM?
    In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
    Shorty C/D M*glites
    Actually, according to my experiments, you do not necessarily have to remove the trimpot from a (Blue) Shark in order to be able to use it in conjunction with a Remora!
    I was having the problem that the current was too high for my LEDs in the most powerful mode of the Remora, and was looking for a way to reduce it, without changing the sense resistor.
    I then found out that by leaving the trimpot in place, while still connecting the Remora in the prescribed way (see pictures earlier in this thread),
    the trimpot gave you a possibility to raise and lower the current output of the Shark in all three modes of the Remora.
    Wayne, can you confirm this?
    I made my experiments with a Blue Shark only, so I cannot guarantee that this will work with a Buck Shark as well, but I suppose so.
    It should also work in the two Sharks, one Remora configuration described in this thread (the trimpot of the second Shark should of course still be removed and its two pads should NOT be jumpered!).
