RMSK, Inc.
Page 4 of 5 FirstFirst 12345 LastLast
Results 91 to 120 of 149
Thread: Replacement of carbide lamps by LED lamps
  1. #91
    Flashaholic gillestugan's Avatar
    Nov 2007
    Nora, Sweden
    Default Re: Replacement of carbide lamps by LED lamps
    Ledil is coming up with a new lens that looks quite interesting. Twiddle. It has a tiltable diffused lens and will be available in a wide version, but there is no specs of the wide on their website. I emailed them and asked but they said it will take a few weeks until they have the specs, but tefficiency will be over 85%. It probably will be too narrow, but the combination of a tiltable head and diffused lens caught my attention.
  2. #92
    Flashaholic* Barbarin's Avatar
    Jul 2001
    Pamplona- NA- Spain
    Quote Originally Posted by Tobias Bossert View Post
    I will complete the test report. Gottfried, the tester of test device_2 ('Bucherl'), took some photos. With the link you can compare Scurion P4, Petzl Ultra and my test device_2 (Tobi) side by side.
    http://www.hirlatz.at/lampenvergleich.html
    "Anmerkung 1:" = Note 1
    "comparison of light distribution 1
    left: "Scurion P4" flood on level 3,
    right: "Tobi 1" work-light low
    The light of Scurion decreases strongly with distance, with Tobi's worklight you can see more far. This is achieved by the light-up with smooth transition."
    "Anmerkung 2" = Note 2
    It is the same text but comparing Scurion P4 maximum flood (level 4) with Tobi's work-light high.
    (Comment: Please realize that level 4 of Scurion is about 1A to the LED, but my work-light is 295mA + 91mA only.)
    The room in the cave is covered with very dark loam, absorbing a lot of light. The caver stands immediately beside a wall (left to him). The floor decends slowly, increase again a little bit and - in a distance of about 15m - falls again and thus is hidden. The wall at the other side of the large room is far away. With the adapted eye you can see it with each light ghostly, but in the photos with fixed exposure it seems to be totally black - with the exception of my shaft-light.
    My personal conclusion from these photos is, that it is NOT possible to use a two-LED construction with fixed beams! For normal use as a work-light, a relativly narrow beam makes no sense - even when combined with a diffuse light: You need a very soft transition from beam to flood and the beam should not reside in the centrum of the flood.
    I'm verry interested in Javiers two-LED solution with zoom - but I'm jet not convinced that the transition of the superposition of both parts would be smooth enough to use it round the clock. I'm not shure whether the two-LED solution will be easyer to construct and will have lower weight as the three-LED solution with fixed diffuse/medium-beam/extra-narrow.
    But never the less, I'm very eager to see some photos from Javier dealing with this. He is experienced in manufacturing and he also convinced me with his zoom-light: Much better than all I have seen in the past.
    I agree with the schematic drawings of Javier completely: That's what we need.
    At the moment I'm still looking for spherically domed front glass with diameter 18 to 20mm and dome height of 4 to 5 mm (spherical cap with 90 deg opening) to make some experiments with domed diffusers. This diffused light would be need to avoid glaring anyhow, whether we end up with a two-LED or with a three-LED solution.
    Tobias
    Great job!!! Makes my comparison to look like a child work....
    This weekend there will be more real cave testing, so I hope to publish pictures by Monday. This time we will test the TWO LED configuration, with different levels of zooming.
    Regarding your concerns about blinding your own friends, I think that won't happen with low level pure flood, even with a non diffused CREE... and when it comes to "work light" it is near impossible to avoid if you look at their eyes. I just believe that warmer colors, with less "bluish-greenish" tints should help to reduce the glaring effect, as those colors are the real scotopic vision killers. So according to this, what do you preffer?
    1. Use cool white (high lm/watt) and diffusers (efficiency lose) to reduce glare.
    2. Use warm white (lower lm/watt) no diffuser. You get better higher CRI, but you need more energy to get the same light.
    3. Cool white, no difusser. On a cave efficiency is the priority, above CRI. Less weight, more light. Glare is unavoidable anyway, so will try to not look directly to my friends when work light is on.
    What do you think, guys?
    Javier
  3. #93
    Flashaholic Tobias Bossert's Avatar
    Oct 2007
    Germany, Munich
    I just found a sherical diffuser (Khatod PLJT 35 and PLJT 35/02) which I will try to modify:
    http://www.optomarket.com/jsp/index.jsp?p_gadgetURL=pagemapping.jsp%3Fid%3Dcatal og_illus&p_contentTopic=&pocs_bnav=yes&p_container Topic=0000121203&p_Navigator=0000043212|0000043244 |0000121203
    It is just a hemisphere made from poly carbonate, outer diameter is 30.4mm and inner diameter is 24.4mm, so the material is 3mm thick.
    There are two types. One is extremely milky (PLJT 35) and the oher one (PLJT 35/02) they call "transparent". I will test both of them.
    The modification will be lathing (or sanding) it down to a hight of about 6..7mm remaining a spherical cap with an opening angle of about 90 deg, an inner diameter of 17..19mm and an outer diameter of 23..26mm.
    I guess the milky type diffuses much to strong.
    In case the "transparent" one diffuses to weak, I will sand blast it at the inner surface.
    Unfortunately the register page of Optomarked.com doesn't work propperly at the moment, so I emailed them.
    I will post whether this ends up in an improvement against the plane edtched glass lense.
    I'm still convinced, that changing another tint will not solve the glaring problem sufficiently. The 'diffus-light' of test device_2 does the job very well, but to the expense of about 20...30% loss of overall luminous flux depending upon the "etchedness" of the lens.
    Tobias
  4. #94
    Jul 2001
    Pamplona- NA- Spain
    Tobias
    Hi Tobias,
    A small exposure to cyanocrilate glue vapours is enough to "frost" slightly almost any transparent plastic. Faster than mill, and easier to test different exposure times.
    Javier
  5. #95
    Oct 2007
    Germany, Munich
    Quote Originally Posted by Barbarin View Post
    Hi Tobias,
    Javier
    Hi Javier,
    thanks, that's a good idea!
    I always tried to wrap with a solvent moisten cloth, but the result was very irregular, even when the cloth was nearely dry. I will play around with vapour, this is very easy to apply for freezing the inner side of a dome: just put a small drop of glue on a plane surface and place the dome over it.
    Tobias
  6. #96
    Flashaholic* uk_caver's Avatar
    Feb 2007
    Central UK
    Frosting from cyanoacrylate does seem to be particularly likely if the dome has a tiny amount of grease from normal fingerprints on the inside.
    It also seems possible to wipe the frosting off from at least some surfaces, just using a paper tissue.
  7. #97
    Nov 2007
    Nora, Sweden
    Yes, I also have experience of "frost" that is quite easy to scrape it off, but as long as it is sitting on the inside it will be protected.
    Just a thought, but is it better to have it on the outside? Most frosted lenses are frosted on the outside and not the inside. Is there a reason?
  8. #98
    Quote Originally Posted by gillestugan View Post
    I would recommend having the frosting on the inside. Caves are dirty, and a frosted lens would be very hard to clean. Perhaps there are additional considerations. Also, look into diffusing filters for photography or theater lighting. I would expect that you could get performance data for such products.
  9. #99
    Jul 2001
    Pamplona- NA- Spain
    Off-Topic.
    This is and extraodinary thread. I'm really happy with it because there is an active discussion about many facts related to portable lighting, reconsidering it from a starting point created one century ago.(carbide lamps)
    There has been, there are and there will be billion threads about "tactical" and "notsotacticalbutgadgety" lights, basically handheld lights. But this one is being discussed from a perspective focused on real usage and real users which are not flashaholics, considering visual field, CRI, output, angle... Surprisingly no one has asked or insisted on the importance of a strobe setting (or five of them) and cavers are exposed to real dangerous situations. (IMHO it can be usefull, but not on every flashlight).
    Well, as I said an extraordinary thread on every sense of the word. Thanks for starting and following it.
    Javier
  10. #100
    Feb 2007
    Central UK
    The upside is that for experimentation, excess frosting may be reversible.
    I don't know enough optics to be be able to guess, but could there possibly be a small difference in light transmission for a given amount of frosting?
    That is, if the outside surface is frosted, might some fraction of the light reflected back from the frosting into the lens be internally reflected off the inside of the lens and have a second chance at making it out through the front?
    The intuitive feel is that optical setups should tend to be 'reversible', but that's maybe more appropriate to point-to-point systems (tracing light paths through lenses) than the kind of more random ('dirtier') point-to-spread setup involved in diffusers.
  11. #101
    Nov 2007
    Nora, Sweden
    Quote Originally Posted by uk_caver View Post
    That sounds likely.
    I have been looking at the Ledil wide optics. They have this kind of tiny bubble texture on the top that works almost as good as a frosted diffuser in reducing glare, but with higher efficiency. I have ordered a pair for some testing. Will also test them on the MC-E as the larger die area tend to make the beam even wider. Using a MC-E is of course more expensive, but you can gain a lot in efficency from driving each die with 1/4 of the current.
    I have also ordered a carclo 10403 which I will try to frost slightly.
    Here is an overlay comparision of some wide lensens. Of course it doesn't tell the whole story, but it can give a hint. I would have liked to include the carclo 10170 reflector, but couldn't find a graph for it.
  12. #102
    Feb 2007
    Central UK
    Is having a wider spread than a 'naked' LED (like the Carclo 10403) actually useful underground?
    Typically, when moving roughly horizontally, a caver is looking along a passage, or across a floor.
    Objects lit up by the centre of a flood beam are typically relatively far away - many times further away than the floor by the caver's feet, and possibly much further away than nearby walls.
    Also, despite the fact that eyes can move, typically a caver will tend to turn their head if there's anyuthing of particular interest.
    Peripheral vision, being more biased towards non-colour receptors can probably get away with less light than central vision needs.
    Personally, I find a more centre-biased flood to be a more useful beamshape - having a little more throw, it has less need for supplementation with a spot beam, while still giving the benefits of a smooth flood.
    I can see that there's a use for flat-flood optics like the Carclo 10403 for building lighting, giving a ceiling light with less of a hotspot underneath than a naked LED, but that's for applications where the LED is lighting a flat perpendicular wall, not lighting the inside of a tube or angled shallowly across a floor.
  13. #103
    Oct 2007
    Germany, Munich
    I agree with with uk_caver: there should be as much light going to the center of the viewing area. Since no visible edge is comfortable, the spill should reach outside of the viewing area.
    I like the pattern of XR-E very much, it is much more adopted to our needs than that of P4 - but I don't like its artefacts!
    I have made some test in my cellar with some light distributions. First we start lightning a plane wall. The light is oriented rectangular to the wall giving a circular 'spot' on the wall. The following diagramm shows some pattern. The X-axis is the ratio of the distance from the spot center and the distance of the light source from the wall.
    So '80%' means e.g. for a light that is 1m apart from the wall, that this point was measured 80cm away from the center of the spot.
    'reflector' means Carclo wide angle reflector 10170. SSC P4 as well as Cree XR-E were measured as bare emitter, with the reflector pressed directly against the starboard and with the reflector clicked into an appropriate holder.
    As you can see, the reflector does a very good job when used with P4 and its holder. Very good for architectural lightnings - not for caving, because we don't have a plane wall in front of us most time.
    The reflector works well for us with XR-E increasing the flux inside of our viewing area. I took the combination without holder as a startpoint for my 'diffuse-light'. There is a sharp edge with this reflector - not good for using round the clock. But that's no problem, because we need a diffuser anyhow to reduce glaring.
    The pattern given in the first diagram has no sense for walking in the cave. Therfore I calculated the spatial pattern out of it.
    As a next step I used different diffusers with the combination XR-E and reflector direct. Until now I have made tests with plane diffusers only. They reduce glaring strongly, they do not reduce the 'beam' on-axis so strong and they nicely smoth out the edge. But with increasing off-axis angle the loss increases dramatically. Therefore I decided to study domed diffusers next. I'll come up with those results...
    Regards
    Tobias
  14. #104
    Nov 2007
    Nora, Sweden
    Beautiful!
    Makes me want to delete my posted overlay as your post makes it look like child-play (which it really is in comparison).
    May I ask how you were able to create those diagrams?
    I too don't think Carclo 10403 or a similar optics will be of any use. Im mostly curious. Was able to get free samples, so why not try them. They will probably be less than half as bright in the centre as a bare XP-E, and even less when diffused.
    A flat-flood glare just as bad to the sides as to the front, so it is better to have more centre-biased for less problems with the glare. That is without a diffuser of course.
  15. #105
    Oct 2007
    Germany, Munich
    Revised diagrams in post #103 now
    In post #103 I explained the different scaling of X-axes of the diagrams but not the scaling of Y-axis and how I measured it.
    I compared a SSC P4 USXOI with a Cree XR-E Q5 WC at 100mA. So the overall luminous flux may be different too, probably the XR-E delivers about 10% more than P4. Manufacturer specs state 91..118lm@350mA for P4 U but 107..114lm@350mA for XR-E Q5. So the ratio XR-to-P4 could have taken any value between 0.9 and 1.25 (luminous lottery). Im not able to measure real overall luminous flux in my cellar.
    I put the light source 50cm apart from a plane wall. I measured every 10cm from center of beam along the wall covering -60cm to +60cm. I allowed Excel to spline the curves. I did not normalize the values, its just the reading of my lux-meter.
    I now have changed the vertical scaling of the diagrams in post #103:
    All values are now normalized to P4 center-value = 1,0
    I hope this clarifies the diagrams.
    Regards
    Tobias
  16. #106
    Oct 2007
    Germany, Munich
    Revised and translated comparison now!
    In post #84 I gave a link to Bucherls comparison of cave headlamps.
    This was German.
    Now we prepared an English version:
    http://www.hirlatz.at/lampenvergleich_en.html
    The explanations are extended now and a switchable comparison mode was added in 'detail 1'.
    The original link to German page
    still works and has the same extended explanations too.
    Tobias
  17. #107
    Oct 2007
    Germany, Munich
    Testing diffusers
    Post #103 dealed with various combinations of LED-types and wide angle reflectors. I came to the result, that the combination XR-E and Carclo 10170 without holder (bond to the board directly) give the best distribution to start with tests of diffusers.
    The diagrams in this post here are normalized to the brightness of the bare emitter in the center (black curve). As in post #103 there are two different diagrams.
    The first one shows the normalized brightness of all the eight combinations tested on a plane wall. The light source was 50cm spaced from the wall. The distance along the wall is given as percentage of this spacing; 0% means on axis and 100% means 50cm away from the center (this equals 90 deg full width angle).
    The second diagram shows the according angular pattern.
    Both diagrams show the pattern of the bare XR-E without any optics (black curve as a reference). The pattern of the bare XR-E is very suitable for illumination of the whole viewing area - but a bare LED glares extremely.
    For each of these eight curves i took a photo with identical camera setting. The camera was 125cm apart from the wall with wide angle optic. The bearer will never encounter such a situation, because the patterns cover a very wide angle. You can see the linear distance along the wall at the folding rule (hard to read at 800x800) and the full witdth angles on the yellow labels (30deg, 60deg and 90deg).
    This photo is for bare emitter and belongs to the black curve 'bare emitter':
    The 2nd curve (light blue) is the combination XR-E and Carclo 10170 without holder (reflector bond to the board directly) similar to that one described in post #103 but with a plane clear uncoated glass lens in front of it.
    This photo is for XR-E with Carclo 1070 and glass lens and belongs to the light blue curve 'clear glass':
    The flatness on a plane wall is nice, but not suitable for walking in a cave. The edge is much too sharp and artefacts are visible. And the glaring is the same as with bare emitter.
    Domed diffusers
    I tested a Khatod PLJT 35/02, which is nearely clear. I cut it down to a spherical cap with 6,5mm hight. the remaining diameter is about 24mm. This cap neither reduces the glaring nor improves the light distribution dramatically. I was astonished, that this dome provides some collimating effect and concentrates the brightness to the center!
    This photo is for XR-E with Carclo 10170 and clear PLJT and belongs to the reddish long-dashed curve 'clear PLJT':
    I made many experiments with PLJT 35/02 and vapor of different bonding agents (also cyanocrylat), but it was not possible to get a defined and homogeneous mat finish. I also tied to sand the internal surface - not good. The best result was achieved with a cleaner polish as used in the household. With this domed diffuser no glaring is left, the light source is about 300mm.
    This photo is for XR-E with Carclo 1070 and clear PLJT and belongs to the reddish short-dashed curve 'sanded PLJT':
    Plane diffusers
    Next I tested three commercial and one home made plane diffusers.
    First I tested XR-E with Carclo 1070 and L2optics OPTX-1-DIF8, which is a clip-on device for their 26mm optics. I bond it with the polished side onto a clear glass lense with epoxy to achieve a stable front lens. So the light enters at the rough side, quite the other way round than intended use. The glaring is reduced but still annoys, the light source appears 10mm subjectively.
    The photo belongs to the greenish long-dashed curve 'OPTX-1-DIF8':
    Next I tested XR-E with Carclo 1070 and Ledil Ledilstar P SUB, which is a clip-on device for their 35mm optics. I bond it onto a clear glass lens as explained above. The glaring is reduced very well (30mm subjectively).
    The photo belongs to the greenish short-dashed curve 'Ledilstar P SUB':
    Additionally I tested XR-E with Carclo 1070 and a diffuser not looking frosted but structured: OPTX-1-016S from L2optics. The glaring is reduced dramatically (200mm subjectively) but the loss - especially at higher angles - is dramatical too! This belongs to the alternatingly dashed greenish curve 'OPTX-1-016S':
    At the end I tested a selfmade diffuser: XR-E with Carclo 1070 and a plane glass lens etched at the internal side facing the LED. The glaring is nearely absent (200mm subjectively) and the loss is acceptable. This belongs to the not-dashed blue curve 'etched glass':
    Conclusions
    • A domed diffuser is much more difficult to produce and brings no real benefit as I thought before :-o
    • Some 'diffusers' concentrate light to the center too!
    • All diffusers I tested povide increasing losses at high off-axis angles.
    • It is possible to compensate the losses of a diffuser in the range of full beam angle up to 80 deg by using a wide angle reflector: This costs higher losses outside this range.
    • The angular pattern of a bare XR-E can be 'reconstructed' in the range -40 to +40 deg at a comparable level. But outside this range the 'reconstructed' pattern drops below that one of the bare emitter naturally. The etched plane glass is a cheap part for that.
    I decided to use the combination XR-E with Carclo 1070 and a plane glass lens in front of it, etched at the internal side facing the LED. This will give a nice 'diffuse-light' when tilt down about 30 deg.
  18. #108
    Oct 2007
    Germany, Munich
    For those who don't like to scroll so much, here is a picture containing all eight photos.
  19. #109
    Nov 2007
    Nora, Sweden
    Thanks a lot. Those are great pictures and there is a lot of work you have done, and done very well. A bit disappointing the domed diffuser didn't work as well as hoped, but its good to know a cheap alternative works well.
    Losses from the diffuser seems to be a little more than 20%. Maybe this can be improved with a holographic diffusing film for example the LSD.
    What are the numbers on the scales i the pictures? I will try to make a similar picture and plot for the Ledil SSS-W I am considering.
    The Boom-W for SSC P7 also looks quite good with a beam pattern similar to a bare XR-E. But its probably better to use separate optics for the hall light.
    Has anyone found a good cable gland? It would have been nice to have a good waterproof gland, but they all seem to be too bulky. Smallest I've found requires a 12mm hole for a 6mm cable.
    I've previously used rubber grommets but they don't feel secure and have no strain relief.
  20. #110
    For homemade strain relief, I've sometimes used several layers of heat-shrink. Heat shrink also changes the diameter of the cable in small increments, so you can experiment and get an extremely tight fit through your grommet. You can tightly attach a zip-tie around the cable on the inside face, and be fairly sure it won't pull through the grommet.
    The Underwriter's knot is designed to address pull through, but probably wouldn't work well with the kind of cable I expect you're using.
  21. #111
    Oct 2007
    Germany, Munich
    Yes, you are right, 20% at least! Imagine that the wide angle reflector catches all light outside +/- 45 deg, that's a lot. Most of the light catched by the reflector is necessary to compensate the diffuser losses inside this angle, since bare emitter and emitter-reflector-diffuser combination just achieve comparable brightness inside of +/- 45 deg.
    This looks very interesting. Pleasy give some links where such a holographic diffusing film is discussed and where to order some samples.
    There are two scales in the pictures.
    The folding rule is scaled in cm and is centred with its reading "100" in the center of the beam. E.g., if you read "140" this means, this point at the wall is 40 cm out of the center of the beam; the same is true for a reading "60". Since the source was separated by 50 cm from the wall, readings of "50" and "150" are those points at the wall, were the distance at the wall from the center of the spot equals the separation between source and wall. In the first diagram these points are scaled as "-100%" or "100%".
    The yellow paper labels above the folding rule mark the edges of beams with 30 deg, 60 deg and 90 deg full width. The yellow labels "90" correspond to the reading at the edges of a beam with full width of 90 deg and thus both are 45 deg out of axis. The X-axis in the second diagram is scaled in "" (=deg) off axis, that means, the yellow labels "90" correspond to readings on the scale of the second diagram of "-45" and "45.
    Readings "50" and "100" on the folding rule equal scale points "-100%" and "100%" in the first diagram and correspond to "90" on the yellow labels, which are equal to the scale points "-45" and "45" in the second diagram.
    I'm not experienced in building water- and bombproof housings, this is a task for manufacturers commercially producing headlamps. My mission is to improve the light distribution of headlamps only.
  22. #112
    Oct 2007
    Germany, Munich
    Now the aspect of glare
    In post #107 I posted the test results with respect to the achieved light distribution. That is what you will see when you bear the helmetlamp. This post now deals with what your friends will see, when you look to them - quite different point of view!
    In post #107 I also gave a rough subjective estimation of glaring. This was done with the light source 1m apart from my eyes and the eyes beeing in the center of the beam. The XR-E Q5 WC was driven with 100mA.
    In this post I'll try now to document the amount of glaring with photos. That's a difficult task, because the dynamic range of photos is limited.
    The result leads me to assume that the subjective sensation of glare is not "linear". Anyway, the subjective glare and the "measured" brightness and extension of the light source don't comply directly.
    I mounted the LED with its axis tilt downwards by 30 deg and shot the photos from horizontally in front of it. This simulates the situation when you talk to another person face by face. The camera settings for the photos in post #107 were f=1:8, t=1s @ ISO100. The current to the LED was 100mA and the spacing between LED and white wall was 50cm. For these tests here, the settings were f=1:22, t=1/1000s @ 100ISO.
    Even with the camera turned down in this manner it was necessary to reduce the LED-current to 10mA. Nevertheless the pictures are overdriven at the most bright parts. On the other hand, the dark parts are drowned out.
    Here is a picture with the photos of all 8 combination tested. The layout of the photo corresponds to that one in post #108:
    As I stated at the beginning, the subjective sensation of glaring doesn't compare directly to the photos - but you can see how the diffusers work.
    The photo "clear-glass" is a good excample to demonstrate dynamic range of photo and eye: I had no problem to see the reflector in total, althoug the die glared me. on the photo you can see the lower part of the reflector only, that is the area wich is active in the upper beam direction.
  23. #113
    Nov 2007
    Nora, Sweden
    I was not able to make the measurements on the Ledil SSS-W with the photo resistor and ohm meter as I hoped. It was too inaccurate, maybe I will try again later in combination with a diffuser over the resistor.
    Post some beamshots instead. Emitter is a XR-E 50cm from wall.
    The Ledil optics have very high efficiency and doesn't glare much at all, but Im not sure I want to trade 20 degrees more narrow optics for 15% higher output.
    I get significantly higher losses from my etched glass when I place the etched side on the inside (towards the emitter) than on the outside.
    The LSD seems (too) expensive, $80 for a 10x10cm sheet. Samples can be requested here.
  24. #114
    Oct 2007
    Germany, Munich
    Definitly I would not accept further 20 deg reduction of beam angle for 'diffus-light' even when this would result in about 15% increased efficiency.
    The Scurion uses room light with about 160 deg - too wide for the person bearing the helmet lamp. I reduced it to about 90 deg, tht's the absolut minimum, which could be accepted only when the edge is very smooth.
    The lamp will be used in caves and there is a lot of loam. With the rough surface out you may get problems with loam, since it is difficult to clean it only by hand. Therefore I excluded 'rough side out' up to now.
    Visually I didn't experienced this heavy difference. But I will make some relative measurements and post the results soon...
    What will be tested? Not all possible combinations, since some exclude from other reasons.
    With etched, sanded or sandblasted glass lense I can turn them to matt side out without any problem.
    Cheep plastic diffusers like OPTX or LEDILSTAR are thin and not solid enough for a cave lamp. So I need to cover them by an additional glass lens (or a thick polycarbonate lens). The problem with this is, that I get 4 surfaces with backscatter instead of 2.
    I avoided 2 of these backscattering surfaces by bonding the polished surface of the plastic diffuser directly onto the inner side of the glass lens. This works fine, because the refractive index of epoxy is similar to those of glass, polycarbonate and acryl.
    It is not possible to bond the rough side of the diffuser to the glass lens, because the epoxy will fill it up and the diffusion disappears.
    I'm interested how big the difference is objectively?
    Yes, much too expensive for you and me. And at the end - if I can find a manufacturer using our findings and ideas - it will not be used because of price. So I must accept the losses of 20 to 25%.
  25. #115
    Nov 2007
    Nora, Sweden
    Beautiful drawings, but I feel a bit guilty. I didn't mean to give you more work. Just was a little bit surprised when I got more than 5% lower output when I turned the frosted side in (measured with a photoresistor). 5% is hard to notice, but it means you can lower the power consumption of the leds by at least the same %.
    The frosted glass I use is a quite heavy frosted photo filter.
    The first idea is often the best, and this search for lenses and diffusers are a good example. but.. Im still hoping for another solution as I would like a more simple method. It is a lot of work to get a frosted lens in the right dimension, then mount it to the reflector and then make it securely mounted to the headlamp at an angle.
  26. #116
    Oct 2007
    Germany, Munich
    Here is a comparison of rough surface inside and outside
    I tested the thre "winners" of the last test:
    • etched plain glass lens
    • OPTX-1-016S
    • LEDILSTAR P SUB
    In all diagrams there is a grey curve for bare emitter XR-E, which was measured with a plane glass lense (uncoated clear glass), since in caves we can't use the bare emitter without protection. This glass lens takes some % of light (4 to 6%).
    All tests were carried out with the combination XR-E / Carclo 10170 without holder and in front of this either the etched glass or a combination of commercial diffuser and clear glass lens as explained below.
    The etched glass is compared with etched surface inside (facing the LED) and with surface looking outside:
    This is the result with the etched glass lens:
    As you can see, no one orientation is really better than the other, but the effects are different: With the "usual" orientation "etching outside" the brightness in the center is about 12% higher, but with "etching inside" the beam gets considerably wider.
    With both commercial diffusers the effect is comparable. They were tested in combination with a plane glass lens:
    This is the result for OPTIX-1-016S, which is not frosted but has a rectangular texture:
    This is the result for LEDILSTAR P SUB, which is rough-frosted:
    The subjectiv glare is uninfluenced from the orientation of the diffuser.
    At the end I can verify the general rule to use "diffuse side out". But especially if you want to get a very wide smooth pattern, the opposit works better.
  27. #117
    Oct 2007
    Germany, Munich
    Using 1 or 4 dies of MC-E with a Carclo 10195
    As you remember, my "testdevice_2" had four independant LEDs. I announced trying to reduce the device to three LEDs without loss of functionality.
    I was not sure on this, because I didn't know the result of useng one die of MC-E only in a TIR. Now I'm sure, the approach of a 3-LED-Lamp will work!
    I made some photos from that. The optic was 50cm apart from the wall. the yellow labels mark a full beam width of 30deg (+/-15deg). As usual, those photos don't show what you will imagin subjectivly, because the eye has a quite different dynamic as a photo.
    XR-E Q5 WC @100mA with Carclo 10195 (20mm medium frosted) and Holder 10205
    MC-E K WC all four dies @25mA each with Carclo 10195 and Holder 10512
    As you can see, the beam is broader with MC-E than with XR-E (may be full beam witdh is about 10deg wider) and the pattern tends slightly to a rhombus. The LED was mounted diagonal so that one die is on top, one on bottom and two side by side horizontally. But there is no artefact and no donut - esthonishing since Carclo 1095 was developed originally for Rebel, quite the opposit, a small emitter!
    MC-E K WC only the uppermost die @100mA with Carclo 10195 and Holder 10512
    As you can see, the center of the beam is declined downwards by about 10deg now ans seems to be slightly higher than broad. But it is still smooth without edges and rings.
    This could be used to light-up a diffuse light smoothly without anoying edges.
    In the following picture I mounted both photos of MC-E beams together. On the left side the uppermost die is driven allown and on the right side al four are used.
    Conclusion for my project
    1. I can use the combination of Cree MC-E / Carclo 10195/10512 to integrate the strong 'hall-light' (2.8A) with the week 'light-up' (30mA) without the need for a driver-dynamic of 100:1.
    1. For my 'work-light' I want a superposition of 'light-up' and 'diffuse-light' diverging by about 30deg. Since the tested combination with only one die is displaced by about 10, the champfer in the casing for the diffuse-light can be reduced to about 20deg.
    Thus the 'testdevice_3' should look like this...
    ...in theory, but I'm not professional manufacturer and my hand made result will look more improvised!
  28. #118
    Nov 2007
    Nora, Sweden
    Here comes my test of diffusers. (at last)
    The meter was connected to the led with a string som distance to led was constant. I also measured light level every 5 degrees, so I ended up with 200 measurements... PM me if you want the numbers.
    The diffusers were placed tested 7mm in front of the bare emitter. When using the carclo 10170 80 degree reflector it was placed direclty in front of the reflector.
    The lenses and diffusers used were:
    KD multicoated 1,5mmX50mm lens
    KD Sodaglass 1mmX26mm lens
    LSD 5 degrees (light shaping diffuser) from POC
    LSD 30 degrees (light shaping diffuser) from POC
    LSD 80 degrees (light shaping diffuser) from POC
    Fastcar 5L diffuser (unknown manufacturer)
    Fastcar 10L diffuser (unknown manufacturer)
    Frosted Glass (Rowi international photo filter)
    XR-E emitter, Linear scale
    Carclo 10170 on XR-E, Linear scale
    XR-E emitter, logarithmic scale
    Carclo 10170 on XR-E, logarithmic scale
    Now, it is in the area around 40 degrees it gets interesting.
    Notice for example how the Fastcar 5L has the same brightness as the frosted glass at angles between 40 and 50 degrees, while at the same time having 15% higher brightness in lower angles. Not bad at all.
    I also have taken some photos for evaluating anti-glare performance. Unfortunately I was not satisfied with the fastcar diffusers and it seems frosted glass is still a good solution as the LSD:s are horribly expensive.
    And Tobias, good it worked fine with the single-die carclo 10195 setup. Thanks for testing.
    I tried it with the 10194 and it looked really bad. Going to use that setup too. Looks good and makes for less components than driving all the dies at low level.
    Edit:
    Some more information:
    I placed rough side towards the emitter on all diffusers.
    The fastcar 10L was not as effective as frosted glass for reducing glare. Better than LSD5, but the "grain" is quite large. I would estimate the frosted glass is 50% better. It is still much better than a bare emitter/reflector, so if someone wants to trade some glare for better output it may be a good alternative.
    It is 0,3mm thick, and quite though, it would probably hold for a while if placed in front of a 20mm reflector. Not bombproof, but i think it would work.
    I took new close-up pictures to show grain size.
  29. #119
    Oct 2007
    Germany, Munich
    Hi Anders,
    very good work and very informative posting!
    Could you add the secondary grid to the logarithmic diagrams (not only 1, 10, 100 but also 2, 3, 4, 5, 6, 7, 8 and 9) please, this would be better to compare bare emitter to emitter&carclo. Just replace the uploaded diagramms...
    I like your results of 'Carclo - Fastcar 10L' since this combination seem to reduce glare and has losses lower than the frosted glass you tested. What is the subjective effect of glare suppression of this combination, does it match to frosted glass?
    Which orientation of diffuser did you use during test, rough side in or out?
    Your findings are corresponding with my results: A diffuser reducing glare sufficiently will reduce the 'gain' of the Carclo reflector 10170 to about zero, that means you just can achieve the pattern of the bare emitter within a beam of +/-40 and pay for glare suppression with losses outside this angle.
  30. #120
    Nov 2007
    Nora, Sweden
    Thanks. I have added the grid to the diagrams, good suggestion, I was a bit tired yesterday when I posted them and didn't think about it.
    Also added some more information at the end.
    I still think a 20 degree LSD would have been great, but the cost is way to high to justify.
    I am still working on the single pole rotary switch circuit based on the AX2002 drivers. Have some problems with diodes and will post eagle schematics when solved.
