Rogue_monkey
Will two sub c's be as long or longer then 1D battery?
Not so quick, my friend. The question at the top of the thread was about sub-C cells.if you do the math (2/3)D * 2 = 1(1/3)D so it is longer than 1D or about 1/3 longer. Easy.
I think a 2/3 C is the same diameter but 2/3 the length of a C cell. So two of them will be longer than 1 D. But two 1/2 D cells will be about the same length as 1 D, so a pack made up of 1/2 D cells is a good way of getting more voltage into a D sized space. I believe the battery pack in a Mag Charger is made up of 5 x 1/2 D cells joined end to end to give a 6 V battery (5 x 1.2 V = 6 V).
