Miboxer
Page 1 of 2 12 LastLast
Results 1 to 30 of 41
Thread: How do cold temps affect LED?
    Unenlightened
    Jan 2008
    Massachusetts
    Thinking How do cold temps affect LED?
    Hi all,
    New guy to the site so please go easy on me. First question out of the blocks, do extreme cold temps prevent a LED light from working properly? Do factors involve a voltage drop of batt pack? One of the past couple of really cold nights my magcharger with TLE-100EX/Cree would not fire up. The temp was definitely below 20 degrees and the light was in my car all day and night. After starting car and warming the light with the heater, the light worked normally. The batt pack is new and was fully charged.
    Thank you for any feedback
    *Flashaholic* Marduke's Avatar
    Jun 2007
    Huntsville, AL
    Default Re: How do cold temps affect LED?
    Cold won't bother LED's, but most batteries don't like to go much below freezing, and will stop working when the electrolyte freezes.
    Lithium primary is the only chemistry that's good for VERY cold temps.
    Unenlightened
    Jan 2008
    Massachusetts
    OK - I usually have two magchargers in the car at all times for work. Two of them still have incan bulbs and even in the coldest temps have always worked. I really like the Cree, but it is essential that it works when needed. Are there options for batts in the magcharger other than the standard?
    Flashaholic* DaFABRICATA's Avatar
    Jan 2007
    Michigan
    Get rid of that hulking beast and buy a surefire LED light
    They have always worked great in the cold Michigan winters.....no problems!
    Flashlight Modifications available upon request
    "I have to go return some video tapes." -Patrick Bateman
    Unenlightened
    Jan 2008
    Massachusetts
    Thanks for the welcome!
    Due in large part to the info garnered here, I now own several outstanding LED lights. Still attached to the mags for multi use tool - Old habits die hard! Maybe time to retire them.
    Flashaholic* Hitthespot's Avatar
    Oct 2007
    Mentor, Ohio
    LED's dislike the heat more than they do the cold. I'm guessing the LED is not the problem. When you think cold you think batteries but at the temperature you mention I question if it would completely inhibit the battery from functioning, and like you say your Incand work at that temperature. There could be another component between the battery and LED that is the problem. Electrical components can be finicky but again usually from heat. Also at less than 20F many things contract and you could have a mechanical problem and not an electrical one. Especially since you say the light works fine once it warms up. I would definitely see if I could duplicate the problem.
    One thing for sure you have peaked my curiosity. If you figure it out let us know.
    Bill
    "The difference between genius and stupidity is that genius has its limits."
    Albert Einstein
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    Bay Area, CA
    The LED themselves probably won't be too affected by the cold. Heck, the might even be more efficient or can run at a higher current.
    Don't retire the Maglites, mod them.
    Unenlightened
    Jan 2008
    Massachusetts
    I didn't think to consider a possible internal contraction issue. I wish I had tested the light a few nights back with our record -12 degrees. I'm glad to hear from someone suggesting mod the others. Are there many batt/LED options available for these lights? Other than the TLE-100, most mods I see are not for magcharger. If I'm very limited, probably look into other options - great excuse to handle more lights at the SHOT SHOW in a couple of weeks!
    Flashaholic* Federal LG's Avatar
    Nov 2007
    Demiplane of Dread - Ravenloft
    "I LOVE THE SMELL OF LITHIUM BATTERIES IN THE MORNING..." - Kilgore
    Quote Originally Posted by THUMP88 View Post
    I I wish I had tested the light a few nights back with our record -12 degrees.
    ONLY -12 degrees (F?). That warm? lol.
    I wish it was that warm up here. In our neck of the woods, we have highs for days on end of -20 to -25 F in January/February. I'm at -25 F right now, and going down.
    In this type of cold weather (at times -50 F, and that's without windchill) regular batteries of all kinds kinda croak. Lead Acid, NiCad, Alkaline, etc.
    For example, you can take an old alkaline Maglight from the house that was fully bright, put it out in the garage, (or outside) for say, 1/2 an hour or so, and turn it back on. It looks half dead, sometimes worse. Bring it back inside, and warm it back up, and it takes right off again. Same thing with car batteries. (you ever wonder who actually buys those 1000+cca car batteries?)
    That's one of the reasons that I always carry a CR123 flashlight withme, especially when I'm icefishing, or out in the woods. It always works.
    Just to give you an idea how cold -50 F is, do you ever wonder if your car door handle will break off when you open the door? Or why ice isn't slippery any more? Or why a hot cup of coffee, when thrown up into the air, never hits the ground? Or why your tires feel out of round for the first couple of miles in the morning? (They actually are, frozen with a flat spot.)
    Just a couple of thoughts,
    Lightmax
    Flashaholic davidt's Avatar
    Jun 2007
    DFW Texas
    If i remember correctly from my material science class, a semiconductor does stop functioning at EXTREMELY low temperatures. But these temperatures would be unwordly. I think this happens at like some crazy temp of negative 150C or some extremely low temperature.
    Look up "semiconductor freeze out" on google and there is more on this subject.
    At least on earth, semiconductors won't hit these temps in a natural enviroment.
    Jun 2007
    Huntsville, AL
    Quote Originally Posted by davidt View Post
    You can actually get some crazy speeds/efficiencies if they are submerged in liquid nitrogen (as some computer equipment is)
    Dec 2007
    California Republic
    The chemistry of a primary lithium and a rechargeable lithium are different - primary lithiums are right at home in temperatures all the way down to -40, rechargeables not so much. Your battery pack was probably chilled to the point that it was no longer conducting and/or some of the actual chemical components inside became frozen.
    LEDs actually perform *better* in the cold; I recall a post on a thread here not long ago reporting on an LED placed in a lab freezer chilled to -80 degrees, and the light was *notably much brighter*.
    LED + Primary CR123 is the ultimate cold weather setup, by a large margin over other configurations.
    Mar 2002
    Los Angeles, CA
    That reminded me of the science special on PBS tonght, "The quest for absolute zero." I'm guessing flashlights don't work at -273C. (-459F)
    Keep it simple.
    LED lights make a nice handwarmer too.
    Trees don't grow on money either.
    Well, thats not quite it.
    You have to difference between semiconductors and doped semiconducters.
    "normal" Semiconductors are "frozen" at room temperatur (thats part of the definition). Conductance and Valance bands dont overlap, and there is only a tiny fraction of electron/hole pairs created by the bolzmann-tail of the electrons. (thus heating will increase conductivity).
    If you dope semiconductors, you _want_ electrical conductivity at room temperature. So you put atoms in which lie just above the valence band, or just below the conductance band.
    At room temperature, nearly all of them will have donated/accepted their electron and created a conducting hole/electron.
    If you cool down the material enough, this wont work anymore: the occupation of the bands will drop exponentially. But thats only at deep temperatures (like a few meV), and only affects the conductance (which is most important in computers, no mosfets without it..), but doesnt _directly_ affect the light generations in LEDs.
    (otoh, current distribution on the led-die, if created by a doped layer/ect, would of course suffer).
    Jun 2007
    DFW Texas
    Quote Originally Posted by IMSabbel View Post
    Hehe, Yeah sounds good. It's been a while since I learned that stuff.
    Oct 2007
    Mentor, Ohio
    Shrug Re: How do cold temps affect LED?
    Well since it was suppose to get very cold last night here in Mentor, Ohio I decided to place three flashlights in my car. My car sat outside in the driveway all night. Coldest temp recorded last night was 13.1 degrees F.
    When I checked the lights this morning temperature was still 13.4 F.
    Fenix L2D-Q5 2 Duracell Alkalines. Fired right up.
    Surefire E2e 2 Panasonic lithiums. Fired right up.
    Nitecore DI 1 Ultrafire Lithium 14500. Fired right up.
    Bottle of water left in the car. Frozen.
    All lights were so cold they were uncomfortable to hand hold without gloves on.
    Conclusion: As I suspicioned I don't think the batteries was your problem unless there was something wrong with the batteries. Old or defective in some way.
    Bill
    Albert Einstein
    This thread got me thinking. I think I'm gonna go throw one of my lights out in the snow for a couple hours and see how it likes it. Now I just need to pick which one.
    - Chris
    Snowmobiling in -6 degree temps and my 1AA Seouls work fine with alks.
    Flashaholic* Lightguy27's Avatar
    Oct 2007
    Sebring, FL (Central Florida)
    Quote Originally Posted by Lightmax View Post
    Lightmax
    Um, just out of curiosity, where exactly do you live? Oh, and Thump. LED's embrace the cold and the reason light won't work in the cold is the batterys will freeze. A CR123 light will work in the coldest temps. I say get your self a good solid CR123 light will two modes. I suggest the fenix T1, or the surefire L2. Good luck.
    -Evan
    -Evan.....So far, L4, L1, Kroma, G3, E2D, E1B, E1E and a couple of G2's. PT Apex Pro, StreamLight Twin Task 3aa, and a couple of modded Solitaire's.
    Jun 2007
    Huntsville, AL
    Quote Originally Posted by Lightguy27 View Post
    -Evan
    Or a AA light, use NiMH most of the year, and L91's during the coldest months. Eneloops also fair better in cold then most.
    Oct 2007
    Quote Originally Posted by Marduke View Post
    This is true. A conductor or semiconductor that is supercooled with liquid nitrogen losses almost all resistence.
    -Evan
    Dec 2007
    California Republic
    Quote Originally Posted by Hitthespot View Post
    Alkaline batteries and rechargeables are good down to about -15 degrees. No worries for indoor use, but overnight in a car during a midwest "coldest night of the year" event can be just enough to seize them up.
    Flashaholic* KenAnderson's Avatar
    Apr 2007
    Vancouver, WA
    One CPF member froze their light into a block of ice while it was running and then allowed it to run in the ice block until the battery was drained. Didn't hurt it one bit.
    Ken
    HDS EDC 60 Ultimate, Mac's Tri-EDC
    Oct 2007
    Agreed. Energizers e2 Lithiums also work very well in the 0 degree and up range.
    -Evan
    Oct 2007
    Quote Originally Posted by KenAnderson View Post
    Ken
    Freezers are only kept at about 20 degrees F and even with a AA light that wont effect it much, especially while it's on.
    -Evan
    Mar 2002
    Kentucky, USA
    I bet it wasn't the LED or the batteries, but rather the switch and connections.. The metal probably very slightly deformed, I've read about very similar things in a few other threads.
    On that note, my LED's usually vibrate a little outside when it's 5-10F out, but that could be my hand.
    4Sevens Quark 123 R2, Fenix Tk10, NiteCore Defender Q5, Fenix P2D CE (P4) Natural, Fenix L0D Q4 (Copper??), Surefire E1e with McLux head and Luxeon 3, Black 4D Mag with TerraLux SSC Drop-in, Deep Purple Mag AA with TerraLux 1W UV Cree, Arc AAA
    Flashaholic* angelofwar's Avatar
    Nov 2007
    South Carolina
    I've had the LED's in my Foxfury Spec-Op's helmet light act up in the cold before...but I'm thinking it was "frosted connections", or contracting metal??? From the out-side looking in though, it would be natural to blame the light, right?
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    One year while hunting, my L4 slipped out of my jacket pocket in camp on the ground near a leaking 7 gallon water jug. It froze that night and I got up the next morning looking for my light. I found the head submerged in muddy ice but when I depressed the tail switch it lit up brilliantly as ever. I took it into the trailer and ran warm water over it to thaw the ice.
    You really can't beat the combination of LED and lithium batteries for cold weather reliability and performance.
