SunwayLED
Results 1 to 9 of 9
Thread: **Help-My Maglite does not work**
    Default **Help-My Maglite does not work**
    My 5 D - Cell Maglite stopped working. I have new batteries in it and the bulb looks fine. I suspect that it's the switch. My maglite is 8 years old but its in very good condition. Will maglite replace or fix it? Any one have experience with Maglite's repair department? Should I send it back to them?
    Banned
    Oct 2002
    Monstropolis
    Default Re: **Help-My Maglite does not work**
    Replace the bulb to be doubly sure it isn't it. It may look fine but if you just replaced batteries it may have flashed the bulb. 5D - weigh up whether or not its worth your time sending it back to Maglite or just buy a new one.
    Dec 2002
    Taxachusetts, USA
    You can actually visually determine that the bulb isn't broken? I guess what I'm getting at is I'm not able to see that very easily because the wound spring filament is so fine, and doesn't always fall out of place very far when it might have just a teeny space where it has burned apart.
    Have you tried another bulb just for kicks?
    [edit] Oh, duh. That basically exactly what Onyx said. Sorry. I was in a rush and only read the 1st post.
    Flashaholic* chamenos's Avatar
    Aug 2002
    Singapore
    the switch of maglites may cause the bulb to start flickering after time, but its not likely to fail. it most probably is your bulb. it could be your switch assembly though, if water has leaked in recently. happened to a 2D maglite of mine recently.
    Flashaholic ab's Avatar
    Dec 2002
    West Coast, Canada
    Mag will definitely fix your flashlight. They may be many things but one thing they certainly are is good about their warranty.
    Check their website for details.
    Good luck!
    A.
    Flashaholic bj's Avatar
    Feb 2003
    bowie, md
    After having your light for so long, you may have forgotten there's a spare bulb in foam in the tailcap. Unless you've used it and not replaced it, trying another bulb should be a piece of cake.
    brian
    I inserted new batteries and a new maglite bulb in it and it still doesn't work. I'm going to send it back to maglite. Will they fix it or replace it? I hope they replace it.
    Dec 2002
    West Coast, Canada
    I've sent them Mag D-body flashlights that have literally seen 15+ years of extremely severe service - anodizing almost completely worn off, bodies dented and beaten into mere shadows of their former selves, etc. Mag hasn't replaced any of these, but has repaired every one.
    I'd expect your light gets repaired rather than replaced.
    [img]/ubbthreads/images/graemlins/smile.gif[/img]
    A.
    Thanks for the feedback. what's the turn around time on a repair?
