Illuminated
Since this is such a great bicycle tail light, I was compelled to show it here.
Seven (7) LED's, super-small and amazingly bright. Quality construction, waterproof, uses 2AAA's, and comes with an excellent quick-release bracket. Non-metallic bracket attaches securely to various tube diameters "hose clamp style", and features tilt angle adjustment for optimum visibility from the rear. The light itself has a belt/pocket clip for use w/o bracket if desired.
The light has two operating modes which are easily accessed via a rubber sealed button on the rear of the body. Steady Mode is *very* bright and Vista-Lite claims a 10-hour run time. Flashing Mode at 0.5 Hz [EDIT: approx. 4 flashes/sec ~ 240Hz] is an attention-getter and conserves power for supposedly 100 hours of run time.
Before I started using NiMH AAA's, I would get an entire season of use from one set of alkalines using mostly the flashing mode (??? hours). More recently I just swap-in fresh NiMH's every other ride (just to be safe) and run in steady mode for maximum visibility. Battery changes are easy though it requires removing (2) screws with a small phillips. Screws are machine thread (not self-tapping) and run in metal inserts inside the light. O-rings are used for protection from the elements.
Shown here next to an AA cell for size reference...
...and most common mounting method on the bike...
...in operation as viewed from 20 feet...
...and again from 80 feet.
Pics were taken in bright twilight conditions though they make it appear slightly lighter than it actually was.
Drivers I know have often commented on how visible this light is from considerable distances. I've been using this for several years and it has *never* let me down. I suppose I could even say that I trust my life to it when I'm on the bike at night...
The bottom line? Highly recommended by this user for the $15-$20 invested.
I only wish I lived in a more bike-friendly area... /ubbthreads/images/graemlins/icon23.gif
John
John
