adamlau
Having successfully installed three of these properly (o-ring installed after guts tightly placed through retaining ring), I have noticed certain quirks:
1. You lose the ability to release the switch for off after first use of the switch on high. Once fully depressed for high, releasing the switch results in low and not off. Perhaps a stronger spring mechanism is required in order to break electrical contact. Depressing the switch for momentary low properly allows for off.
2. The rounded cap of the assembly may not be long enough. When the switch is fully depressed, it does not spring back to its previous state as the O-ring only prevents the assembly from falling through the retaining ring and nothing more. The result is a mushy tailcap as a result of the cavity formed between the rounded cap and rubber boot. A longer assembly may help alleviate this particular quirk. The only resolution I have found is to fully thread the tailcap down in order to push the assembly up towards the rubber boot. The problem is that this procedure must be done after every use.
3. There should be a way to clearly demark the respective ohm values of the resistor boards. After disassembly, I was left reassembling and testing to determine which board was what. An etching on the board itself would help prevent this.
Installing the guts with the retaining ring reversed helps increase the rounded cap protrusion into the rubber boot area, resulting is less of a mushy feel. Installation and removal of the assembly become more difficult, however. A larger diameter O-ring would help compensate for overbored retaining rings. In any event, the above issues inherently remain unresolved. Comments? Suggestions?
