I have no idea what the title should be...
I've had a need for a dual light setup like my primary soldering station. I have a second microscope station now and it is in dire need of lighting.
I've been working on this setup now since early December and I now have a partially working prototype.
Here is a picture of it at the microscope station. The battery assembly is sitting on the base plate for the boom. It's hard to see in the picture as the microscope is directly in front of it in this picture.
Here is the view of the light assembly completed.
It took me a long time to come up with fitting all the parts inside the small box. The rotary switch, power on/off switch, two loc line adaptors, converter board and interconnections were a real challenge on this project.
I finally found a nice power connector that fits inside the box allowing me to take the box apart allowing troubleshooting and service of the internal parts.
Another view of the with the connector mated.
The lights are the PR cans that Don and I made as a limited run and have seen little usage. I made a custom heat sink to mount three Rebels on them.
A real bummer is the microprocessor seems to have noise coupling into it and the three level control is currently not working. Also, on this prototype I left off accidentally the battery voltage monitoring circuit so the low battery status indicator is not in this prototype.
Currently the only thing working is the on/off switch and the converter is running at max power which is set for 0.5A. With both tri-rebels in parallel that means each LED is getting 1/2 that or ~250mA. Still plenty bright.
Here is a picture of the top of the box before mounting the loc-line.
The converter is a new buck converter.
Wayne
Wayne
