Angryfox
View Poll Results: Which D battery do you think is better?
Voters
8. You may not vote on this poll
  • Powerizer
    2 25.00%
  • Tenergy
    6 75.00%
Results 1 to 10 of 10
Thread: Powerizer or Tenergy D cells?
    Flashaholic* lasercrazy's Avatar
    Mar 2004
    NJ, USA
    Help Powerizer or Tenergy D cells?
    I need a bunch of rechargeable D cells for a project I'm working on. I've narrowed it down to these to cells but which one is better?
    http://www.batteryspace.com/index.as...ROD&ProdID=709
    http://www.batteryjunction.com/1dni10reba.html
    These will be under a constant 10-15 amp load.
    Favorite lights: XeRay 75W BarnBurner | Vec Twin 55W HID mod w/ LSD D pack | Amondotech Iluminator with 12D cell pack | Modded 2MCP vector | 2C ROP Low | 6D Quad Lux 3 Mod | 2C lux5 mod | Camo 3D red mod | 3D ssc Mod | Costco 2AA: R/B, Blue, Cyan, R/O | Aleph 19 UV | 193mw PGL 3 | Ssc Garrity hl mod
    Default Re: Powerizer or Tenergy D cells?
    I've got Tenergy's 10,000 mA/hr D-cells, but not Powerizers, so I can't make a comparison between those two. I do have Accupower's LSD 10,000 mA/hr D cells called 'Evolution' that I got from Thomas Distributor and the Evolutions are a bit better and much more expensive at about $11-12 each. I don't have a rig to test D cells to measure their acutual capacity but the Tenergy's are a 'mild okay'. Like many batteries that are over rated I am not sure if I am getting a full 10,000 mA/hr possibly more like 7500 mA/hr and that observation is based on side by side comparisons with batteries that have been tested and measured and used in a D cell adapter.
    I haven't made any load measurements but I am sure they can discharge at 1C to 2C without a hitch.
    I probably will only be buying LSD D cells from now on for the simple reason is that these large non-LSD cells are so expensive at approx. $8 a pop, that I don't want to have a whole set of them discharge before they get used. Charging these full capacity NiMh cells is a time consuming thing and to recondition them can tie up a charger for a day and a half.
    www.overstock.com has these C and D Accupower LSD for better price. It's really a good deal with frequent offer like free shipping or 10% off total order.
    Theone
    Flashaholic* NA8's Avatar
    Jun 2007
    Quote Originally Posted by theone View Post
    Theone
    Good deal on the C size, the D size isn't that much cheaper than Thomas Dist. and it's quite different looking.
    Note the overstock model number is -1 and the Thomas model numer is -2 on the C battery pack. Whatever that means
    *Flashaholic*
    Apr 2004
    Lost In Space
    some old 8000-9000ma sanyos :-) or them new (accu) LSDs
    but those werent in your choices :-(
    you know why i dont have any powerizers? because they all failed after about 30-40 cycles, and i tossed them, but if i remember right silver got some good tests out of them.
    the tenergy to me is just going to do the same thing.
    them old sanyo , slightly lower powered tanks were built to the hilt, took major discharge loads and worked almost as good as the newer higher capacity stuff, even YEARS later. WHEN used in a high current situation.
    with a heavy discharge load like your talking about , you would probably prefer a lesser capacity battery that handels more juice .
    its just like when doing hotwire junk , and using 1650-1800-2000 MA AAs , they might not have the capacity, but that is BECAUSE they are built like tanks.
    Mar 2004
    NJ, USA
    Quote Originally Posted by VidPro View Post
    I was looking into the LSD cells and if need be I'll get them. Do you have a link to the Sanyo cells?
    *Flashaholic* Mr Happy's Avatar
    Nov 2007
    Southern California
    I've noticed that I can comfortably fit four Eneloops side by side in an unmodified Maglite. So a 4AA to D parallel adapter filled with Eneloops would be one option for getting an effectively 7000 mAh D cell.
    However when currents reach 10-15 amps at low voltage you start suffering significant resistance losses in the circuit. Under those circumstances there is a good argument for a redesign that moves to higher voltages and lower currents. If you use instead a 4AA to D series adapter the current becomes 2.5-4.0 amps for the same delivered power. Reducing current by a factor of 4 reduces resistance losses by a factor of 16.
    For this reason, I think AA to D series adapters are usually to be preferred over parallel adapters.
    *Flashaholic*
    Apr 2004
    Lost In Space
    Quote Originally Posted by lasercrazy View Post
    nope i do not, i got them locally from a battery pack maker guy, and i dont even remember which one. hey they worked for that long :-) and at some .8-1C discharge load.
    Mar 2004
    NJ, USA
    I decided to just get the quality LSD cell from TD. Silverfox, feel free to lock this thread.
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Lasercrazy,
    Done.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
