Malkoff
Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: Luxim Plasma Bulb Claims 140 Lumens/Watt
    *Flashaholic* PhotonWrangler's Avatar
    Oct 2003
    In a handbasket
    Default New "LiFi" electrodeless HID lamp
    Panasonic has announced that they're going to be using a new electrodeless HID technology in a series of projection TV sets. This new lamp is being called "LiFi" (Light Fidelity).
    It looks interesting. It uses a microwave source to energize the gas mixture in the light capsule.
    So my question is this: How much microwave energy are these things going to radiate? I'm sure the pump wavelength has been optimized for maximum energy transfer to the particular mixture of gas, but still - that's gotta take a lot of microwave energy to produce enough light for an RPTV.
    Every microwave oven I've ever been around had some measurable amount of leakage. Am I to believe that these TV sets won't?
    Will my TV set be able to pop my popcorn as I watch?
    Veni vidi velcro
    Flashaholic* yuandrew's Avatar
    Apr 2003
    Chino Hills, CA
    Default Re: New "LiFi" electrodeless HID lamp
    That article is from January of this year. The lamp is being developed by Luxim
    http://www.luxim.com/
    The entire light engine (including the driver electronics and magnetron tube) consumes 250 watts. I looked up the ratings and found it to produce 4400 ANSI lumens in typical projector applications.
    Anyway, go buy yourself any of the following model Panasonic Rear Projection TVs that were just released yesterday; they are using these light engine.
    PT-50LCZ70 50" 1080p LiFi HDTV
    PT-56LCZ70 56" 1080p LiFi HDTV
    PT-61LCZ70 61" 1080p LiFi HDTV
    Flashaholic* chesterqw's Avatar
    May 2005
    singapore,jurong
    250 watts for 4400lumens...
    17.6lumens/watt
    oh well... not for flashaholics but for "long life"
    if killing was legal, i would have killed countless number of people...
    Flashaholic* matrixshaman's Avatar
    Jan 2005
    Outside the Matrix
    Yep - Microwave and your MTV. LiFi = Life Finite. No thanks.
    Underground Shelter Info: www.matrixkey.com Total darkness available 24/7
    There is no important work, there are only a series of moments to demonstrate your mastery and impeccability. Almine
    Obviously they expect that the public cannot understand that this is NOT A HID! It is a RF excited plasma. Not the same thing. Lamps similar to these have been used in the semiconductor industry for photoresist ashing for over 15 years.
    Thurmond
    Resistance is Futile. You Will be Modded!!
    Infinity (CMG that is) and Beyond!!
    *Flashaholic* James S's Avatar
    Aug 2002
    on an island surrounded by reality
    so what is the "fill material" then? Is this like those microwave sulphur ball lights that we were so jazzed about years ago but which never quite made mainstream?
    I want to see emissions on these as I can't have one if it's going to mess up my WiFi I'm betting that it runs on 2.5Ghz but I suppose we could be getting it all wrong and it might be like those new RF bulbs that run around 300mhz?
    There isn't much information on their websites as of yet.
    -James
    E=sqrt((mc^2)^2+(pc)^2)
    Apr 2003
    Chino Hills, CA
    I saw two Panasonic LCD rear projection LiFi sets (a 50" and a 65" model) at my Fry's electronics. I decided to look in the back of the TV where the light engine would usually be located. There is a "Bay Window" style vent on the lower right side of the TV with a fan behind it blowing out the warm air from the light engine and you could see the heat-sink on the bottom of the LiFi unit past the fan.
    As usual, a bit of light from the source leaks out around where it shines into the color filters and LCD elements so the area under the heat sink was lit up with a bluish-white glow. Just to test how it warms up, I turned off the TV which caused the picture to go out and the "Power" LED to flash red but when I looked in the back of the TV right after, the light engine was still lit so turning the TV back on would cause the picture to come back instantly. I turned it off again and watched the back of the TV; the light engine remained on for about a minute before it completely turned off but the fan continued to run for another two minutes before it stopped and the flashing red LED on the front went steady. I waited another three minutes to let the light engine cool further before I turned it back on and watched the back of the TV. First the fan started followed by two relays clicking and a faint buzzing sound. Then the lamp started with a dim greenish white color which got brighter over the next 8 seconds and was followed by a half second flash of blue (think blue LED) which gave way to bluish white that continued on to pure white at full brightness.
    I didn't really compare the colors too much to the conventional Toshiba DLP set sitting next to it but it did appear richer in many darker scenes.
    Oct 2003
    In a handbasket
    Wow. Thanks for the report, Yuandrew! So these have actually made it to retail shelves. Now what would it take to convert that light engine to a flashlight? (Besides some major RF shielding!)
    Apr 2003
    Chino Hills, CA
    The entire light engine unit already seems to be RF shielded. I think all you need to do is find out what voltage and control logic is needed for operation so you can construct a power supply then enclose the both the unit and your power supply in a case which could be easily carried.
    Apr 2003
    Chino Hills, CA
    Well, someone is holding onto one of these.
    http://www.proavmagazine.com/industr...ticleID=602992
    There are also other light sources shown used for projection; including the LED(s) used in the Samsung LED DLP sets and a diagram for Mitsubishi's LASER diode based DLP
    Default Luxim Plasma Bulb Claims 140 Lumens/Watt
    http://www.news.com/Luxims-tiny-but-...3-6234653.html
    How do we fit this into a flashlight???
    Flashaholic* Szemhazai's Avatar
    Jan 2006
    Wroclaw - Poland
    Bringing back from the dead..
    They announce new version of their system 144 lum/w - somebody knows some more details ?
    Enlightened member of pl.rec.rowery
    Light-Test - bike light’s & Headlamps comparison site. - In polish but picture says everything
    Flashaholic* WadeF's Avatar
    Apr 2007
    Perkasie, PA
    Default Re: New Plasma LED
    Pretty wild. They said 140 lumens per watt, and they were running it at 250w, so was it putting out around 35,000 lumens?
    Facebook: Wade Fulp - Follow me on Twitter! @flashlightguy and my main feed @WadeFulp Google+ PROFILE
    Dec 2006
    Montreal, Canada
    It burns at over 5700°C, I don't think I want that thing anywhere close to my hand!
    Jul 2005
    Ottawa, Canada
    And what kind of battery pack would you need to power the thing?
    Jul 2007
    Central Europe
    It is not a LED
    Looks alike Sulphur plasma http://www.sulphurplasma.com/sulphur-plasma.htm
    Damn!! Gimme one!!!
    Flashaholic* 2xTrinity's Avatar
    Dec 2006
    Arizona
    17.6lumens/watt
    ANSI lumens is a meausre of light output from the projector, not from the bulb. So that's after losses in the reflector, optics, and color filters. If that's true, that's EXTREMELY efficient for a projector. Most waste over 90% of the light input, even when the screen is displaying 100% white pixels. I doubt this lamp is putting out 200lm/w, so they must be using particularly efficient optics in the projector.
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    MA
    LED?
    It sounds more like a Sulfur Plasma to me.
    Flashaholic a4d's Avatar
    Dec 2007
    here and there
    Now just wait for "RA" to put one in a light.
    "Better To Have It And Not Need It, Then Need It And Not Have It." (Paul White.) -->'///>(
    I work on the things that create the light when there is no light.
    Flashaholic* Federal LG's Avatar
    Nov 2007
    Demiplane of Dread - Ravenloft
    "I LOVE THE SMELL OF LITHIUM BATTERIES IN THE MORNING..." - Kilgore
    Oct 2002
    Baden.at
    Default
    +1
    but I want the 5, 10 and 15 W version, too
    PS: can anyone with more background than me explain if this is a hoax, or not?
    How can this thing work "without electrical contacts"
    Dec 2006
    MA
    If it is like the Sulfur Plasma lamp, then Wikipedia has a decent explanation. Electrodeless lamps link might help too.
    I don't have any background, just providing links.
    Oct 2003
    In a handbasket
    Quote Originally Posted by yellow View Post
    If you placed one of those glass plasma capsules in a microwave oven and turned it on, it would light up. Same idea.
    Flashaholic Tachikoma's Avatar
    Apr 2007
    Italy
    Default Is there a 400w LED?
    http://gizmodo.com/369372/luxims-250...away-400w-leds
    I didn't even know 400wLEDs existed
    Oct 2003
    In a handbasket
    Default Re: Is there a 400w LED?
    Oh good grief.
    I've heard that fact-checking is becoming a lost art in the race to be the first to get a scoop. Sometimes it results in embarrassing gaffes like this one.
    Sep 2007
    Finland Turku
    Quote Originally Posted by PhotonWrangler View Post
    Oh good grief.
    Thats pretty sad, how they write like they know what is going on.
    I would guess they meant HID, if they even know what it is.
    And diff_lock said, Let there be light: and there was light.
    Oct 2003
    In a handbasket
    Quote Originally Posted by diff_lock2 View Post
    The video demo clearly mentioned a comparison to an HID streetlight; you can see that it's an arc lamp and not an LED. Even if they didn't know what HID is, they could've studied the video before writing about it.
    Flashaholic* Gryloc's Avatar
    Jan 2006
    Cincinnati, Ohio & North Lewisburg, Ohio
    Even though that story is just silly and confusing, I found out that there are super high power LEDs. I got a strange email today from this Jiangsu Bright Optoelectronic Technology Co. It sent me to this link:
    http://www.eleclight.cn/index.htm
    There, you will see a large selection of high power LED packages, including a 500W emitter! Just click on the 50-500W link. I think this is the same company that makes the 10W, 20W, and 50W LEDs you see on DX. They claim 40lm/W with the 500W emitter, and 45lm/W with the 200W emitter. Even though these things are not terribly efficient, the fact that they make these super high power emitters is nuts! I am kind of curious about the pricing of these things, and their availability. If you want to know more about them, and how they found me through my high power LED Yahoo group, just PM me. I think they thought that I produced products featuring high power LEDs, and that I would be interested in buying their stuff. It is hard to tell with the very broken English, though.
    Sorry if this does not pertain to the above article and this thread, but I thought that it would be interesting to share...
    -Tony
    EDIT: Actually, check out the news page of the Luxim website:
    http://www.lifi.com/dynamic/events.php
    Look for the two stories mentioning the efficiency and the flux of this new light bulb. Though they do not indicate the bulb being the size of a tictac, they should be describing the same thing as funny the Gizmoto article above.
    So, when will we see small scale mini-tictacs that can be used in converted maglites that outshines those 10W HID lights? When will CPF member Ra get a hold of one of these and puts it into his famous Maxablaster lantern? That would be nice. He will burn your retinas out from 8 miles away instead of 4...
    Unenlightened
    Nov 2006
    Bay Area, CA
    Default New Plasma Lightbulb!
    (Admin, you may move this to a more appropriate place--sorry, got amazed and wanted to share asap)
    now this is pretty cool! Maybe future of flashlights as well?
    http://www.cnettv.com/9742-1_53-32509.html
    Fred
