I'm trying to hack an auxiliary input into my car stereo. My car is a 93 Saab 9000. The goal is to keep the stock setup. The origin of this hack is a similar hack for the radio in the 9000's successor -- the Saab 9-5, and you can find instructions for that HERE.
So the idea is that you hijack the audio signal between the cassette player head and the processor/amp in the car stereo. You effectively loose the cassette player, unless you install a switch, blah blah blah.
Not a few ground rules before we go on...not to appear crabby or anything, I just want to stay on topic
1 - I realize I could just install an after-market stereo. This, however, seems easier and cheaper for sure. The car's audio setup is a little complicated, and so adding an after-market stereo requires well over $100, and it's hardly plug and play. I should be able to do this mod for rougly the cost of an audio cable, so a substantial savings. An after-market stereo would surely sound better, but only if I upgraded all the speakers to match the new head unit. cha-CHING!
2 - I also realize that hard-wired FM modulators are a good option, and if I can't get this working that's probably the way I'll go. But I am going to do this mod on my dad's car (It's well documented for his, and proven to work) and so I wanted to try it this way on mine too.
Next up, here is a picture of my stereo (Click to make it bigger). Or rather, the cassette circuit board on my stereo.
Ok -- here's where I've gotten so far. I thought I could hook into the solder pads called "R-Out" and "L-Out" -- but those solder pads have a capacitor dangling off them on the other side, and I didn't know what leg of the capacitor I'd need my audio to pick up on. So I started looking at that "1 4 3 2 G" thing. That's a ribbon cable that goes straight to the cassette deck head. I decided to jack in there.
So I hooked my grounded audio cable in at ponts "1" "2". 1 is the left audio channel, 2 is the right audio channel, and then I hooked the ground for the audio cable to The point on the far left of the picture called "ZERO II" (It would probably work with "G" as well, but that's not where I have it.)
now the dilemma!
It doesn't really work. I have to turn the iPod all the way down, and then it's still really loud. If I turn the iPod up just a little, it distorts like wild.
As I type this I realize that perhaps it is because the level that a cassette head should be putting out is tiny. I probably need to intercept the audio signal elsewhere on the board, where the level that the car radio would be expecting to see would be similar to the headphone output level of an iPod.
But I'm a little lost. :duh2: so...what do you think?
now the dilemma!
