ab
A Mag 2D 5W HD Luxeon conversion
A couple of the mods I got done over the weekend were a pair of 5W Luxeon HD Mag2D conversions. These lights do not use collimators - they are focusable lights using the Mag reflectors for beam shaping. The light body donor for these lights is a common Mag 2D which has had its' entire floating-bulb holding assembly removed from the switch. The switch body is then trimmed and all of the bulb-holding elements removed. Silver-plated Teflon-jacketed wire is used to connect the switch to a V3U Luxeon Star assembly which is Arctic-Silver epoxied to a heatsink seated in the end of the Mag body. The inferior stock Mag lens has been replaced with one of the excellent UCL lenses from flashlightlens.com.
The light source is a white Luxeon Star HD V3U (not Luxeon emitter but Luxeon Star). V3U is nominally 113.6 to 147.7 lumens, bin 3 for neutral colour, Vf 6.87v to 7.35v. Power is supplied by six AA alkaline or rechargeable NiCad batteries. These are placed in a customized 6AA to 2D battery adapter to directly drive the Luxeon Star.
Output is very flexible since these lights are focusable. Focused down it throws a tight and quite "fat" beam of light. It has tremendous throw and penetration, and a well-diffused and extremely bright corona. Set for a flood beam it can create a very wide bath of light indeed, with the inevitable Mag hole in the centre of the beam.
This light is very bright, particularly from just 18 inches away - also notice the edge of the corona at the bottom of this photo.
The beam is also very bright (and slightly softened around the edges) from 6 feet away
The next three photos are taken from approximately 9 feet distance.
Here is a comparison with my excellent and bright ARC LSL-P...
Here's a comparison with the best 1W Luxeon light I've ever built or seen - a massively overdriven Q2K Luxeon LD with 30mm optics (this light handily beats my Blaster II.) Also in this photo is the LSL-P again...
Finally, how does this light compare to serious incandescents? Here's a comparison between the AB Juiced Up! Mag 2D (6W incandescent in Mag 2D body, UCL lens, etc.) and the AB Mag2D 5W HD. Notice that the 5W HD light is substantially superior.
None of these photos show the huge wash of nicely diffused and bright corona light with this unit. Very useable because of this! This light is reasonably small and convenient to carry, lighter in weight than a stock Mag 2D and extremely powerful. Its' fully focusable output is intense - markedly superior to all other Luxeon-based flashlights I have tried (with the possible exception of Lambda's superb Megaclops units - the Megaclops HD, SE and LE are quite similar to this light in output.) I'm trying not to smile too much!
To be fair, the laws of physics must always be obeyed, and this extreme output is possible only by virtue of serious heatsinking, direct drive (overdrive!), flashlightlens.com's superior UCL lens, a high current battery system, etc.
These are super functional lights and I'm really pleased with them! /ubbthreads/images/graemlins/thumbsup.gif
A.
p.s. - (EDIT: P.S. removed. I will not selling these lights.)
A.
