Never eat a potpie from the center. Start at the edges, and eat around them as you slowly work towards the center. This also prevents the edges of the pie from getting cold before you finish eating.
Yep --
Those are things I learned about eating Pot Pies, at a VERY early age !
How true, how true !
As a side note . . . .
When you "test" your food, to see if it has Cooled Down enough to eat it,
you probably shouldn't use your Tongue for the task !
_
Ditto for Pop Tarts. Learned a long time ago that the jam filling can be MUCH hotter than the crust.![]()
On the same line...
Hot sugar can be MUCH hotter than boiling water. And it sticks to your skin.
Making candy can be more dangerous than making flashlights.
Daniel
I have got to plan my procrastination better!
Certain brands of burnable CDs had a manufacturing defect that caused a version of disc rot called CD Bronzing. I'd heard of "CD Rot" before but I never thought about it much until I pulled out a disc of holiday music the other day and found that it was hit by the bronzing problem, causing the tracks closer to the outer edge of the disc to have errors.
Luckily I still have the original (stamped) discs that I compiled this music from so I can easily burn another one. However if you have any burned CDs with important information on them, check them once in awhile for CD rot and make a new copy from it before the old one becomes unreadable.
**Update**
This was a "Prodisc Diamond True Silver" CD-R. I bought a pack of these several years ago because I liked the idea of a disc that looked like a professionally stamped disc (no yellow-green or blue tint on the recordable side) but now I'm sticking with only the big name recordables.
As I cyclist, I was reminded on the first day of the year that when dogs (and sometimes people) are crossing the road from your side to the other, if you happen to surprise them as you're approaching, they tend to turn around and run back in the direction from which they came... I hit a dog because I didn't shout at it (a habbit developed out of necessity) as I tried passing behind it. (There was about 3ft between the side of the road and the dog, more than enough space for a cyclist.)
Oh Yeah. Do not take apart a disposable camera (with flash) and attempt to look through the lens to magnify something without first removing the battery and discharging the capacitor.
Plastic sunglasses (optic nerve halogyn) SINK in sea water!
When was the last time you washed your feet?
Don't look at your wristwatch whilst holding a hot cup of coffee , the screaming frightens all the other MacDonalds customers.
I bet you are all going through the action of looking at your watch now.
p.s... It is safer for you to have the watch face on the inside of the wrist ... That way you scald someone else.
You've just tried it again haven't you ?
In the past we have had a light which flickered, in the present we have a light which flames, and in the future there will be a light which shines over all the land and sea.
- Winston Churchill
If you unscrew the cap on a bottle of eye drops and it falls on the floor, no problem - just clean it with alcohol to sterilize it. But make sure the alcohol has evaporated completely before replacing the cap on the bottle, or some alcohol will seep into the eye drop fluid. And the next time you use it, it will hurt.
Finish smoking your cigarette before changing the fuel filter on the car.
when working with CCFL inverters, do not pinch the wires going to the CCFLs, you will swear the insulator jackets are defective.
Don't use an old wine bottle cork on Champagne to try and store it.
Finning does help dissipate heat. This is why the fins are removed before cooking fish. Otherwise it will throw off the heat and not reach the proper cooking temperature. --Duglite
Clean the floor?
McGizmo Haiku Review Mac's Tri EDC Review MY LIGHTS!! Why buy a cheap bright light when a dim expensive one will do?
I was teasing you guys.![]()
When leaving a restroom in a hurry to get back to the office, take the time to check yourself in the mirror before walking out the door. You know, so you won't be walking around in public with a length of toilet paper hanging out the back of your pants.
Learned this one this past Monday.![]()
That's like the quintessential foible in any comedy, but I've never understood how it happens. How the heck does a chunk of tp even get in your pants, and then how do you not notice that? I fear ever doing this myself, and now will be more paranoid knowing it doesn't only happen in movies.
At the risk of providing too much information, a strip that's supposed to fall into the toilet misses it's mark and catches on the back edge of your pants or underpants. This has happened to me twice in my life - once a couple of decades ago and again a few days ago. Lesson learned: never assume that something will always land where you drop it.
Money spent on car audio, over the long term, is not unlike taking hundred-dollar bills and running them through a shredder.
- Winston Churchill
Much as I love Surefire build quality, the plastic lens retaining rings suck and don't hold up to drops...the bezel edge WILL bend. So just buy the steel ring and install it right away before you drop the light on its head and then strip an Oveready removal tool trying to put the steel one on later after the damage is done.![]()
Never expose the meaty part of your hand (between the thumb and forefinger) to a parrot you don't know.
- Winston Churchill
This thread makes me miss Rick (Sigman)... I hope you're well, wherever you are Rick!![]()
