Anglepoise
Thanks to the excellent threads in this section, I am gradually learning about modding hotwires.
I am not up to speed on electronics but can use a soldering iron.
Now about NTC use. We want an ohm of resistance when cold so the bulbs
do not flash. Got that. The selected NTC must drop its resistance when hot so we get maximum voltage to the warmed up filament and best light output.
Got that.
Now where it gets confusing to me is how much the resistance will drop.
There seems to be a wide tolerance in the NTC ( SL12-1R010) .
So if I select a NTC that is one ohm cold and 0.060 ohms hot, what will these readings be with two NTC in parallel??. Also I have read about fixed resistors in the circuit as well,yet the author of the post did not explain the benefit of an NTC and fixed resistor in parallel.
Thanks
Got that.
Thanks
