I would be thankful for some advice on trying to fix a M@G 85. I have two identical lights 3C host with three AW cells, KIU switch mod. The problem I am having with one light is it will not light for 5 or more clicks, sometimes more. I have searched and found the thread on the tailcap spring mod and also the one with hose inside a hose, would one of these help this situation or am I looking at a switch or other problem? I am aware of the overcurrent protection built into the cells on cold start but this light did not require multiple taps when new.
Darien
Are you refering to the tail cap mod I published with the braid around a snubber made from reinforced hose?
If you are, you have reduced the resistance. Reduced resistance trips the protection circuit in some protected cells. The AW cells are not all alike some are more sensitive than others.
With the above tailcap mod and a 5761 you cannot single click an AW C cell. I added an NTC to fix that problem.
Have you swapped the batteries around to determine if the problem is the protection circuit of one set or the light?
If your problem is tripping the protection circuit because of reduced resistance than you need to add resistance. The Ametherm AL12 1R010 always has a remaining resistance after soft start. That or reverting to the standard tail cap and spring or adding a plain resistor will help. Resistance does use up lumens however.
Low resistance is what a short circuit is and that is what protection circuits protect against.
Hope this helps isolate the problem. Good luck.
