gav6280
Ok I am getting my head around it all now, but im still a newbie. But im up for having a go.
I would like conformation from someone who knows there stuff that the following list of parts will all work together. It would only take a minute to check this for me, as i think i have it right but im not totally sure....
The plan is to build a light with 4 led's running of 4 seprate drivers and 1 battery. With the drivers all wired in paralel to the battery. All hosed in a custom made underwater casing.
From DealExtreme:
sku 01885 - 1050mA Regulated Circuit Board x 10
SKU 01915 - 48.16mm 4-LED Reflector for Cree Emitters
SKU 02394 - Cree XR-E Q5 Emitter on Premium Star (228LM at 1A)
And from batteryspace.com:
Polymer Li-Ion Module: 3.7 V 8000mAh - Prewired with PCB (PL8059156)
http://www.batteryspace.com/index.as...OD&ProdID=3903
And from : www.chilledpc.co.uk
Enzotech Forged Copper Northbridge heatsink
http://www.chilledpc.co.uk/shop/prod...roducts_id=487
I rekon that by very slightly overdriving the Led's and arrangimg them in a set of four i should be looking at around 1000 Lumen right?
Do you think it would be good to silver spray paint the back side of the reflector?
It should be noted that this is for scuba diving. I only need 1 mode on or off....
Thanks in advance for your time... Gavin.
From DealExtreme:
