I have a couple of high-output LED torches that have too hot a hot-spot, a few ring artifacts, and not enough spill for my taste.
Can anyone recommend some self-adhesive vinyl-like orange-peel material that I could cut to fit the lens, which would add moderate diffusion of the beam, and still be heat-resistant against melting onto the lens?
I want to add it to a JetBeam Jet-1 Mk-IBS, for example, to make it more HDS-like, so it needs to be pretty heat-resistant, with 225 lumens...
