can the Ultrafire WF-139 charge one battery at a time?
MstrHnky
i have an ultrafire wf-139, and was wondering if i can charge one battery at a time (only one battery in the unit) or if i have to have both in there together.
thanks for the help.
MstrHnky
thanks. i just picked up two aw rcr123's and one was greenlit, the other still red. i didn't want to leave the green battery in the charger.
thanks again!
Fusion_m8
Melbourne, Australia.
Yes it can.... just to double confirm.:twothumbs
With Li-Ons, its best to take them off charge once the light goes green, do not leave the Li-Ons in there to trickle charge, this can cause the cells to fail prematurely due to over charging above 4.20v
kramer5150
Palo Alto, CA
:eek:oo::eek:oo::eek:oo: I didn't know it did that. Good to know, thanks.
OP, yes you can charge cells one at a time. Its a great charger for the $ IMHO.
lightforce2
Vic Australia
there have been reports that the wf-139 will continue to trickle charge after charging to 4.20v however these may have been older units, my wf-139 will stop all charging current at 4.20v. It pays to check your charger with a multi meter, if available.
Buck
Does this have to be done in current setup, or can you just check the voltage?
