Echo63
ok guys, a little while ago my surefire L4 died, and instead of sending it to surefire to be fixed, i decided to sacrifice it to the gods of learning
i opened it up and found that the rattling noise that i used to hear from the head, was the heatsink/head screws coming loose - here is a photos showing where they should be
the screw bouncing around the inside of the head managed to break the plastic of the ends of the inductor
Im fairly sure the Lux V has died, 2 bars in one of the die's flicker when power is applied, i think the heatsink had backed out of the head a little, breaking the thermal path to the outside world, and cooking the LED
my questions to you all are
1. will this broken bit affect the functioning of the circuit ? - it still seems to work , when i apply 3.7v to the bottom contacts i get 9v out the top
2. can i run a Cree (as described in post #23 of this thread
http://www.candlepowerforums.com/vb/...hp?t=162146#23 ) from a 17670 without frying it ? or am i better off finding a new Lux V to put in
Thanks in Advance for the help
E63
E63
