Hi there, welcome to CPF ! :welcome:
hi, i am still new to this whole this so i want to do some research before i start buying stuff.
ok so first off, if a torch says that it accepts 2xcr123a, 2x16340, or 1x17670, which one out of the three would be better? or are they all the same. When i say better i mean most bang for your buck vs best performance out of your torch.
How the torch will react to the various power options will vary from torch to torch just depending on what electronics are used to regulate the LED. BTW you'll only find these types of broad sweeping power options on regulated LED flashlights.
A general rule of thumb is that lights listed as compatible with "2xcr123a, 2x16340, or 1x17670," will have the following characteristics:
1. On 2xCR123 (2 3V primary cells), the light will behave pretty normally, have good long regulated runtime with some dimming thereafter, sometimes followed by a miniscule amount of available light for several hours after the cells are almost completely depleted.
2. On 2x16340, (they are talking about a pair of 3.7V rechargeable "RCR123" cells), the light will have near perfect regulated output but with reduced runtime compared to CR123s. The regulation circuit will allow the higher voltage and simply buck the higher voltage down to the needs of the LED for the chosen output level.
3. On 1x17670, (this is a single 3.7V cell with approximately the length of a pair of CR123s, but rechargeable) The input voltage is very close to the Vf of the LED in this configuration, in this case, the regulator has little to no voltage above the LEDs voltage needs to regulate, so the regulator is *essentially* bypassed and the flashlight operates in direct-drive mode. The output dims as the battery drains. The advantage of this can be that a continuously dimming direct drive setup is the most efficient. The light will slowly get dimmer and dimmer through the run as the voltage of the cell drops, but it will run for a very long time.
Second Ive seen, lets say cr123a batteries, rate them selves at 3.0v @ 650 mah, and 3.7v @ 1000mah, and a bunch more ranging in between. My question is, does more volts mean more power? or more life? or is more mah more power? or just more life.
Try to think of voltage as pressure, and mAH (mili amp hours) as the size of the tank that the pressure is stored in. More mAH translates to longer running time, while more voltage means more work can be done in less time.
In order to compare batteries with different voltages and capacities, just multiply the voltage and the capacity to figure out watt-hours. watt-hours are the sum of what that amount of stored capacity can do with that much voltage behind it. A 1.2V 2250mAH NIMH cell has 2700 mili-watt-hours. A 3.6V 750mAH li-ion cell also has 2700mWH.
Eric
