Sold/Expired SSC P7 Buck Converter
Dino Ironman
Hallo Der Wichtel
Please could you send me details of how I can order two of your 4 mode drivers.
Could you also confirm how much extra the postage will be to Switzerland.
It looks like a great product by the way, I'm very impressed by the spec.
I too am a newbie with insufficient post count.
Regards
Dino Ironman
Der Wichtel
Germany
SSC P7/ Cree MC-E Buck Converter ( New Version)
Seoul P7 / Cree MC-E Buck Converter
more detailed information: Full Datasheet
the specs:
Current Regulator:
- Output Current: 2.8A
- Min. Input Voltage: 4.2V or Vf of LED. ( changes to direct drive if the input voltage is too low. Driver shuts off under 4.2V)
- Max. Input Voltage: 20V
- up to 4 LEDs
- Diameter: 25mm
- Height: about 11mm
Connection:
Vin: positive Input
GND: negative Input
L+: positive Output ( anode of the LED)
L-: negative Output ( cathode of the LED)
Driver Versions:
Single Mode: Only 100%
Version A (4-mode): 100%; 70%; 25%; 3%
Version B (6-mode): 100%; 70%; 25%; 3%; Fade in & Fade out; Strobe
Version A/B Driver needs a momentary switch which must be connected to "S3" and GND.[Click here]
Version B Driver in action:
http://www.youtube.com/watch?v=FOuQortrgUY
Fits in D and C Cell Mag-Lites.
Price:
Single Mode : 20 Euro
Version A (4-mode): 25 Euro
Version B (6-mode): 25 Euro
Germany: 2.20€
International: 3.45€
For registered mail please add 2.15€. If something gets lost with registered mail, I'll refund the money or send the ordered parts again.
If you want one please pm me or contact me via email
This component is for expierienced user only, so please inform yourself before ordering.
I can't replace defective components. Sure is that all drivers are being tested before shipping.
Here is the original Thread:
https://www.candlepowerforums.com/threads/199533
Thanks
Update 2.1.2010:
Unfortunately Deutsche Post has rised up the shipping cost within Europe to 3.40€.
I really don't understand why they are doing this since this would be nearly twice as much as other European countries.... :thumbsdow
Update 28.10.2009:
Since I got some feedback in the past about difficulties in soldering the cables to the LED, I changed those to silicon cables which are more heat resistant and more flexible and therefore easier to solder.
Update 19.10.2009:
- Driver with modes are available
Update 14.08.2009:
- New Drivers available: Smaller, Higher Efficiency, Constant Current
UPDATE 5.1.09
Shipping costs changed to 3€ for europe and 6€ for the rest of the world
UPDATE 9.09.08:
Drivers and dimmers (9€) are available now.
UPDATE 18.08.08:
First batch are all sold.
The next batch will be finished in two weeks.
Furthermore I will offer two versions because I got some replys that setting the voltage is not that easy.
First version will be the version as before with a voltage range up to 10.5V.
For all those who wants to drive one emitter the second version is better suited which has a voltage range up to 4.2V.
Update 7.10.08:
sry but currently no more driver boards are available.
The drivers will be available in one week or so if I can handle the new bigger solder iron for soldering smd parts.
The dimmers are out as well ....
Update 26.10.2008:
Drivers are available again
cnjl3
Deep in the heart of Texas
Well, just wanted to tell you that I am very happy with your P7 driver.
I am using a 2D MAG with H22a P7 heatsink powered with 2 D-size Li-ions as shown here:
I did add a little bit more thermal goo to the missing areas shown above.
I used a Uni-bit to cut open a Litho123 Heavy Stipple reflector because I really dont like the beam you get with a standard MAG plastic reflector.
I am very happy with the results. I am not too good with beam shots and by now everyone has seen "plenty" of P7 beam shots.
Thanks!:thumbsup:
Halibut
Costa Mesa, CA
you should place the d2dimm after the converter
I tried putting the D2DIM in front of the converter, but couldn't get this to work without some serious flickering at the highest setting. Do you think putting the converter first will do anything to solve this problem? I'd be willing to try it!
-Dan
cnjl3
I looks like you can get one here:
https://www.candlepowerforums.com/threads/171150
It is the #7 reflector and I like it because it gives a "wall" of light.
Now for "throw" purposes - I guess I like my Q5 Aspherical MAG 1D size Li-ion - but I also like my MAG 1C size Li-ion Cree XR-E Flupic because of its multiple modes.
Geez, I guess you can never have enough lights.
:D
Looks very good.
Where did you get this reflector?
Is it still somewhere available?
Der Wichtel
Germany
-Dan
Yes you must put that after the driver. Otherwise you will get problems like flickering in your case.
Here is a video of my pwm dimmer
http://de.youtube.com/watch?v=pp84xr0N2gw
Doh!Nut
West London
Hi
I am looking at using 3*P7 from 14.4v (four Li-Ion 18650).
Is this driver OK for this? 80% of 14.4 = 11.5v - should leave enough for 3 led.
I think I read somewhere that this driver is a voltage limiter, is that correct?
How do you set the desired current? It would be for a Dive light where I would need to keep good controll of the burn times.
Any more information would be appreciated
Nick
Der Wichtel
Germany
Hi Nick,
since I got some questions because of the 3 P7 I will test it.
However I had only the chance to test with 2x P7.
2x P7 are no problem.
I will do some testing with a 30W halogen bulb which should give nearly same conditions as with 3x P7.
Chodes
Australia
Received package today - thanks.
Will be busy next few days, I'll report back once I have a completed installation.
GhostReaction
Singapore
Pardon my dumb question as a total electronic noob.
Will I see magic smoke if I drive a single P7 with 4pcs 18650 on your converter.
I wanna shove it up the elephant I just bought from Fivemega
