Wikipedia states LR44 maximum height as 5,4mm. 5,4x3=16,2mm. 10180 is 18mm. I think it might fit some devices with a loose spring but not ones with a tighter fitting.
Has anyone tried this yet? I just might order 10180 and a nano charger to try out
You get the cell, I'll contribute the Nano (I have more than one) - PM me with your address.
I'd be a bit concerned that the Nano charging current is rather too high for such a small cell. But then Rob sells them with the Wee lights so presumably he reckons it is safe to charge them in a Nano.
PM sent!
But as Jarl mentioned, the internal resistance will be much MUCH lower. In some devices it might be fine, while others might goThe size is almost the same and voltage too.
:huh2: The capacity has nothing to do with the internal resistance. You could use four LR44s and still have less voltage under load than the 10180. Indeed, my latest keyring torch relies on the internal resistance of LR44 cells to limit maximum current.If I understand your concern consider that LR44s capacity resides between 150-200mah depending on alkaline or silver-oxide the current draw at the most would still be within the safe level of the 10180...unless of course the capacity of the 10180 is below that of LR44s which I find very unlikely
