gallonoffuel
Well, it finally happened. I half suspected it would, just not so soon.
This morning, getting out of my truck to go into work, I felt some resistance and then a *snap* *ching ching*. The pocket clip on my Nitecore Extreme snapped just below the mounting screws. I've had this light for a month. I'm going to check out the break under a microscope, but my first impression is that the steel clip looks to be like it was cast. The break surface is very rough with craters and some shiny spots. Looks just like a broken piece of cast iron.
Anyway, as a temporary solution, I've replaced the clip with a stainless one from my Cabelas XPG Light/Knife combo. While looking around the web for replacement clips, I was reading the specs on the ones KnifeKits.com sells. They have one that is identical to the one from the Cabela's knife. Its the 'Model 8 Designer Clip'. I ordered a bunch of clips with the same specs for mounting, and will be trying a number of them to see which one I like the best. I got a few 'flush' fitting type, and a few that let the knife/light 'drop' further down into the pocket.
So what are your experiences with pocket clips and replacing them? Since the Cabela's knife clip fit the NEI, I'd imagine MOST flashlight clips are a standard folding knife clip with a standard spec. Once my order comes in, I'll be able to verify this.
