CandlePowerForumsUser
- Joined
- Mar 11, 2007
- Messages
- 302
Hello Sandwich Shoppe.
I'm looking for a Converter to drive a single SSC P4 emitter.
I want somewhere 1.2 to 1.3 amps. Also I need the driver to support at least 9volts. Looks like SOB may fit the bill.
I used the current sense resistor calculator and came up with:
Computed a two resistors solution:
r1=, r2=0.04 which equals 1.25
that is 4% off the desired 1.3 Amps.
However, it doesn't look like .04 is in the drop down.
What can I do to get near 1.2 amps?
Thanks
Thanks
