un-activated d cells
loving light
ohio
Hi,I just bought a CODE RED flashlight that comes with 4 d cells(at a church rummage sale).The flashlight is just a common plastic rubber construction that uses a PR2 bulb no big deal,but here is where it gets interesting.The batteries are un-mixed,you have to turn the top of them so the liquid(thats in them)mixes.It says that these batteries will last 20 years(if not activated).It sounds like a good idea.The flashlight still had the sticker on it,it was purchased from Radio Shack for $15.88.I am guessing the late 80's.The company that produced it is Energetics corporation Redmond Washington.Anyone with any info?What could the liquid be in them?Thanks.
hopkins
California
my first guess is that the liquid is an electrolyte...but you guessed that already
I'm sure. The chemical makeup is probably an acid but surely not lemon juice;)
Could you post some pictures of the batteries and the light?
It sounds like a real historical item to be preserved!!! Like those original
Barbie dolls that now sell for $1000 each?
TorchBoy
New Zealand
I've seen this sort of thing mentioned on CPF but I really can't remember what they're called. :popcorn:
Fallingwater
Trieste, Italy
This is interesting. Can you provide pictures? The system can't have been much good if such batteries are unavailable today, though.
MorePower
Wisconsin
The liquid is an electrolyte; it's either sodium hydroxide or potassium hydroxide. The cells are fairly low capacity compared to modern alkaline D cells, but will last a long time in storage which is exactly what they are designed for.
hopkins
California
darn .....a base not an acid! Well I had a 50/50 chance a being wrong and I've
got a SLA 6volt on the desk here so...
Tried to search the web for pictures of twist top activated D-cells but no luck.
Please post some pictures of those things if you can.
hopkins
California
well sure, I hope that would have clued me in, but I've reread Loving Light's OP a couple times and he does not mention any chemistry info on the twist top D-cells thus his query.
Maybe he'll cautiously cut one open and test the mystery juice with litmus paper?
(i.e. an acid turns blue litmus paper red and a base turns red litmus paper blue
- for you CPFers who have not had a chemistry class yet)
Morepower sounds like you know about these type of batteries. Any info
we could follow on the web to see these things?
TorchBoy
New Zealand
Re: un-activated D cells
Nah, red cabbage juice all the way! Or FTW as the case may be, depending on your country of vernacular.
MorePower
Wisconsin
Google is your friend; search for "code red" battery
http://www.911emergencykits.com/site/745186/product/L33
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=10996
http://www.quakekare.com/index.asp?PageAction=VIEWPROD&ProdID=47
On further review, the liquid may be plain water which upon activation mixes with solid potassium hydroxide that is dispersed in the zinc powder of the anode.
loving light
ohio
Thanks MorePower!I tried to do a search(but I couldn't find anything).It really sounds like a good ideal,20 year shelf life(better than lithium?).Why do you guy's and girl's think that this never became mainstream?Sounds like a good battery for an Emergency kit.Thanks again to everyone for your help.:twothumbs
Closet_Flashaholic
Between East and West Coasts..
:thinking: - So I wonder if these are "old" stock or of recent manufacture? None of the references make mention of date codes. So the question of the day might be:
20 year life starting from when?. 20 years from 1988 would be about right for these to start showing up for sale. Right about the time their 20 shelf live ends...
MorePower
Wisconsin
They're expensive, they're more difficult to manufacture, and they have relatively low capacity.
Personally, I'd just use normal alkaline cells in an emergency kit, check them every year or so, and replace them every 5 years or so.
Illum
Central Florida, USA
to be anywhere near as productive as manufactured alkalines that mixture has to be well mixed after you turn it....and even then it may act just like zinc oxide cells...probably will work if someone creates a D cell adapter for the fenix E01 or the ARC but doubtful for anything else :candle:
Turbo DV8
Silicon Valley
From one of the websites:
[FONT=Arial, Helvetica, sans-serif]
[FONT=Arial, Helvetica, sans-serif]Introducing a revolutionary breakthrough in batteries! [/FONT]
[/FONT]​
Wow... a revolutionary 20 year old breakthrough! :thinking:
Illum
[FONT=Arial, Helvetica, sans-serif][/FONT]​
well...20 years ago the ability to set wet cells into binary components that's stable enough to sustain itself over a span of 20 years could be considered a breakthrough:)
I wonder how the plastic can contain the electrolyte without it eating through though...possibly a glass vial set to have the tube tip shaved off by a shear when you turn it? :whistle:
MorePower
Wisconsin
There are a number of types of plastic that have good resistance to degradation by alkaline electrolyte.
hopkins
California
If Loving Light is willing to activate one of the Code Red twist top D-cell's
It would be very informative to do some tests on it to see if these thing are
worth buying.
Suggested tests
1. unloaded output voltage after the initial twist and mix shaking.
2. Momentary short circuit max current measurement.
3 output voltage under various loads, 5ohms, 10ohms, 100ohms, 1000ohms.
4. Does additional shaking bring it 'back to life' after some use?
