I have a freshly built quad Cree M@g with a Shark and Remora. On *high* it's putting .9 amps to the LED's. I'd like to have a little more, as I can run the light on low and medium most of the time, and only use the high setting for short bursts.
The way I checked the current is:
Measured voltage at the LED output with the light running.
Desoldered the LED wires to the light engine, set the power supply at 14.8 volts, connected the leads, and measured current. I assume this is a decent way to get a semi-accurate reading on voltage/current?
Anyway, can't I piggyback another resistor on top of the existing sense resistor to raise the output on high to 1.2 amps or so?
Thanks,
Greg
Thanks,
Greg
