Malkoff
Page 1 of 9 12345678 ... LastLast
Results 1 to 30 of 250
Thread: Standlight circuits (Will this circuit work?)
    Default Standlight circuits (Will this circuit work?)
    Hi,
    I've been trying to soak up all the material on this forum, and reading from Martin's site with all it's excellent circuits for dynamo lights. I'd like to try building a fairly simple dual Cree headlight, but with hopefully with a standlight.
    I haven't looked at circuit diagrams since I was a kid building crystal radios, so please forgive me if my questions are too obvious. Reading the forum messages, it sounds like you need to add a supercap in parallel to one of the led's for the standlight to work. But I've also read that you need to put a resistor in there as well, and on another site there was a diagram with a zener diode as a shunt to protect the goldcap from too much voltage.
    What is the simplest way to get this working? Is it as simple as this?
    Or does there need to be more between the Goldcap and the LED? What are the drawbacks to this design? I'd like to get a minute or two of light from the standlight when stopped and I would usually ride this bike at around 10mph for commuting. I'm planning on driving this first light from a bottle dynamo if that makes a difference.
    Thanks!
    Last edited by syc; 11-26-2008 at 12:03 PM. Reason: Trying to make the title more descriptive
    Flashaholic* MrAl's Avatar
    Sep 2001
    New Jersey
    Default Re: Will this circuit work?
    Hi there,
    I dont see any current limit resistor in there.
    Also, if you are going to use this circuit, a good idea
    is to use a reverse protection diode across the top Cree.
    Many LEDs are not designed to take too much reverse
    voltage, and actually zero reverse voltage is the best.
    A reverse diode will bring this down to 0.7 volts and
    that is usually close enough.
    So that's two things to add then:
    A current limit resistor
    A reverse diode across the top LED
    What we dont know is how much current your generator
    puts out while pedaling at full speed.
    Take care,
    Al
    LED's vs Bulbs, the battle is on.
    My bumper sticker: "I Brake for LED's"
    To err is human, to theorize divine.
    Got Light?
    I think this message was mistakenly moved to this forum - the circuit is for a dynamo powered light, with a bridge rectifier. There's not batteries involved and the current of the dynamos are limited to around .5 amps.
    Sep 2001
    New Jersey
    Hi again,
    Ok, then a reverse protection diode should do it.
    Take care,
    Al
    Got Light?
    *Flashaholic* Mr Happy's Avatar
    Nov 2007
    Southern California
    I was going to say you might need a zener diode too, but as long as the Crees are always in circuit and never switched out, they themselves will act as a shunt to protect the capacitor. The maximum voltage across the capacitor should not exceed the highest forward voltage of a Cree, which should always be less than 5 V.
    Be thoughtful about the maximum current from the dynamo however. If you should be cycling fast or going down a hill you might be able to generate more dynamo current than you expect.
    Thanks - I am trying to understand the reason for the reverse protection diode. Is it to prevent the goldcap from discharging the wrong way through the top led? So in that case, does it go in series right below the top led, but before the junction with the 2nd led and the goldcap. Or do you mean in series before the top led and after the smoothing cap?
    Or, when you say across, do you mean it is parallel to the first led?
    Once I get an idea what you mean, I'll upload another sketch and you can tell me if I'm understanding you properly.
    Thanks!
    Nov 2007
    Southern California
    I think the reverse protection diode is indeed to prevent the Goldcap from discharging the wrong way through the top LED. However, when I look at your circuit I don't see any discharge path for this to happen, so it seems to me you would be safe as things are (except for the possibility of excess current blowing up the Crees if you happen to pedal too fast).
    I will wait for MrAl to comment further as he made the original suggestion.
    Quote Originally Posted by Mr Happy View Post
    From what I've read, the Crees are in the neighborhood of 3.2V - 3.7V
    This page has some tests of similar dynamos:
    http://www.pilom.com/BicycleElectronics/Dynamo.htm
    I don't think I'll be traveling over 40kph/25mph on this particular bike (even on a downhill roll), so based on his description, I may get very little over 3W until I put in a voltage doubler.
    Nov 2007
    Southern California
    Incidentally a minute or two of light from a Cree and a 1 F capacitor is a lot to hope for. I think you are likely to see only a few seconds with this setup.
    Note that the original circuit you linked to was using small LEDs and current limiting resistors rather than a big fat Cree.
    Nov 2007
    Southern California
    Quote Originally Posted by syc View Post
    Those are interesting tests and make fascinating reading.
    Be aware however that he was testing with a high voltage and low current load. When the dynamo power was 6 W, the current at the dynamo terminals was about 500 mA and the dynamo voltage was therefore about 12 V.
    When you have the LEDs sinking the dynamo current the voltage will be unable to rise above the Vf of the LEDs and so the current could easily become higher than 500 mA. Whether this does or does not happen to a harmful extent will depend on the characteristics of the particular dynamo.
    Also note that a voltage doubler in the circuit will not increase the output power but reduce it. It is a voltage doubler, not a power doubler. (A power doubler would be a wonderful thing but is sadly outside the currently understood laws of physics.)
    Another thing to mention is that the Vf of an LED is not a single value, but varies with the current. As you increase the current through the LED the Vf increases until you exceed some maximum current when the LED is destroyed. For many high power LEDs the maximum Vf at LED destruction will not be much higher than 4 V.
    Thanks for the feedback. It sounds like I should either discard the standlight idea, or else just hook up a very small led to the supercap. If I did that, would I need a resistor like they have in that page with the rear light design?
    With respect to the overloading the LED's, it sounds like this passage from that page answers the question:
    Question: Why does a standard 3 W light system with the Dymotec6 not burn out the bulbs at 50 km/h ? This is because at such high speed, the matching of the load is off (current is too high) so that it can't drain maximum power.
    Question: Where goes the lost energy when the load doesn't drain the maximum possible power ? It's not lost. The dynamo spins with less effort. Try and short-circuit the dynamo at full speed, the current of the driving motor will drop a lot.
    Nov 2007
    Southern California
    Yes I read that, and you might be OK. But remember he is talking about incandescent bulbs and not LEDs in that statement. Bulbs and LEDs have different voltage/current characteristics. Simplified a bit, it can be said that bulbs burn out if you exceed the maximum voltage, but LEDs burn out if you exceed the maximum current.
    Take special note where he says "the matching of the load is off (current is too high)". This could be a sign for caution, since high current is exactly what destroys LEDs. To be really safe, it might be advisable to include some kind of current limiting in the LED circuit.
    Sep 2001
    New Jersey
    Hi again,
    The circuit has at least two basic modes of operation.
    One is when the generator is supplying power, the other
    is when the cap is supplying power.
    When the generator is supplying power, no problem.
    When the cap is supplying power the top LED is mildly
    reverse biased. This is because the diodes at the generator
    can conduct a little in reverse, which puts a pseudo ground
    at the anode of the top LED. With the ground at the anode
    and some positive voltage at the cathode, the top LED
    becomes reverse biased. Now the reverse biasing *might*
    not hurt anything if the LED can take a reverse bias equal
    to it's own forward voltage, but it may not want to take this
    voltage for very long because many LEDs are not meant to
    be run at all in reverse bias, especially on a regular basis,
    even if it's a voltage equal to it's forward drop which for
    some LEDs could be as low as 3v.
    Put the reverse protection diode across the top LED, and
    this potential problem goes away. The LED will see a max
    of 0.7v with a standard si diode or 0.5 with a Schottky.
    The way i see it, it's better to be safe then blow out the LED.
    Now there is the counter point where the reverse conduction
    of the diodes at the generator is lower than the reverse
    conduction of the reverse biased top LED, meaning that the
    reverse voltage that actually gets across the LED is less
    than the total reverse voltage. This is true, but then that
    is a static measurement too. The capacitances come into play
    also which means the dynamics of the current and voltage
    have to be examined. Doing this it gets a little more difficult
    to analyze, but in general the capacitance of the rectifier
    diodes will be higher than the capacitance of the LED, meaning
    the dynamic current (transient response) at least puts
    more reverse voltage across the LED than in the purely static
    case, which again means that a reverse diode is certainly a
    good idea.
    Take care,
    Al
    Got Light?
    Aug 2002
    London
    The original circuit is fine and will work as it is, providing the super cap is rated at more than 3.6V.
    With due respect to Mr Al, who does some great stuff, Cree XR-Es are rated at 5V reverse bias so no amount of reverse leakage in the bridge rectifier is going to hurt the LEDs in this circuit.
    There is no need for a zener anywhere.
    Ditch the 1,000uF completely, it is a waste of volume, although will reduce flickering a bit if operating from a hub dynamo.
    I use a hub without that capacitor, it is fine above 10k/h 6mph
    The standlight may dim really quickly depending on the supercap.
    Not all supercaps are equal.
    They vary dramatically in internal resistance depending on their design
    Low impedance types will charge quickly, but start bright and very quickly go dim.
    High impedance types will charge slowly - a minute or so - start dim and get dimmer but glow a long time.
    You are not going to get a very long standby with such a simple circuit.
    Small modifications could make it run dim, but predictably and longer.
    Also, do not go over the rated supercap voltage as it is pretty close - under 0.5V - from the damage voltage.
    Why isn't this thread in the bicycle light section?
    Good luck
    Steve
    Flashaholic* Steve K's Avatar
    Jun 2002
    Peoria, IL
    Just a quick vote to agree with Steve, a.k.a. Bandgap. We've both been working with hub dynamos for close to a decade or more, and they work well with the current high power LEDs. Current is limited to 500mA, so no regulation is needed. As for a protection diode.... probably not needed, but couldn't hurt. Adding a 1N4148 is cheap and doesn't take up much space.
    I hear a lot about people using supercaps wired across the LED as a standlight, but my limited experience wasn't very good. The supercap can only charge up to the LED's Vf, so any discharge at all will bring its voltage below the nominal Vf. As the voltage drops, the LED current will decrease, so a reduced amount of light will be available for some period of time.
    I'd recommend trying a supercap and seeing if it is good enough. Certainly, it's better than nothing. And if it's not good enough, come back here and we'll discuss ways to improve things. :-)
    My preference at this time is to charge a single AA nicad cell, and use a small Zetex boost converter to drive the LED at a low current. The primary advantage is that it can run quite a while from the AA nicad. The disadvantage is the complexity and issues related to rechargeable batteries.
    I'd recommend that folks calculate the energy stored by the cap or battery, calculate how much energy can be extracted, and how much energy is needed (power times the desired run time). This can give you a good estimate on whether a design is viable or not.
    and as always, don't be afraid to try new ideas, and have fun!
    regards,
    Steve K.
    Sep 2001
    New Jersey
    Hello there,
    Yes, in this case the LED has a reverse rating, but i think i
    would want to be careful anyway. If i was going to connect
    two LEDs to a generator, i would want reverse protection
    diodes across both of them. With the caps in the circuit
    however just the top one would suffice.
    Now that i take another more close look at this circuit i see
    that there could be a better way to run the lower LED.
    Charge the cap directly, with maybe a 4.7v zener across it,
    then run the lower LED in series but also with the collector
    of a PNP (through 5 ohms) where the PNP turns on when the
    generator stops turning. This is just one example, where
    the lower LED would run longer due to better utilization
    of the energy storage capability of the super cap.
    Another idea of course would be to run the lower LED with
    a converter circuit, which would utilize more of the cap
    energy storage too.
    Take care,
    Al
    Got Light?
    Thanks everyone for your replies!
    Quote Originally Posted by Steve K View Post
    That's pretty much what I'll do - though I'm tempted to track down a breadboard from one of my friends and prototype it to see if the bottle dynamo can power both LEDs at a reasonable speed.
    I'll probably build this circuit:
    Would adding a resistor between the goldcap and the Cree limit the rate at which the goldcap is discharged? I only really hope for the standlight to be a "be seen" light, so limiting the amount of current to around the minimum to get some light out of the led is fine.
    Flashaholic FrontRanger's Avatar
    Oct 2007
    Colorado, USA
    Not to rain on your parade, syc, but have you considered just mounting a flashlight on your bars? To make a repair in the dark, you need a light source that isn't dynamo-powered. And if you're carrying one of those around anyway, why not use it as a standlight? With this reasoning in mind, I ditched the standlight idea and augment my dynamo headlamp with an L2D.
    Hi, sorry for my very bad english, i am spanish. I have made something similar to this. I have not the circuit at hand at this time. But i will made some concerns to your circuit.
    1. The goldcap you have suggested is not sufficient. This goldcaps are designed for ultralow current applications (memories, etc...). If you plan to use a goldcap you must use the bigger ones, maybe 10F and 2,5v. Obviously it is not possible to power a white led with one (the 2,5v...) and it is neccesary to put 2 or more in series (the resulting capacity is reduced). In my project, i used a yellow powerled (2,2 Vf vs 3,5 of the white) and the 5mm ones in an dynamo-converted battery tail light in series-parallel (the half 5mm reds in parallel, the other half in parallel and in series with other ones, and this group in series with the yellow power led), powered by a 3 goldcaps "battery" of 10F each one, connected in series. This gave me a 6,4 Vf, pretty close to the 7,5 V of the battery maximum V and far from overcharge it. There is a limiting resistor "before" the goldcaps to prevent no lighting until the goldcaps are charged, and another one "after" the goldcaps to ensure some backup time.
    2. I putted the white powerleds in series after being rectified by a diode bridge, like you, but there is a more efficient way but more expensive: putting 2 in series and another 2 in series in reversal with other ones, and not using a rectifier. In this image, you have a similar (and much earlier circuit with 5mm leds) circuit wich can give you ideas, the final circuit does not have the backup whites. If finally you put the white poweleds after a rectifier, don't use a pre-made one, with silicon diodes, make one with germanium (or shotky barrier) diodes, with have a lower Vf.
    3. I have not used a zener. In earlier stages of the development i considered it, but after a few testing i refused. It is not neccesary and introduces some important losses. The current of the dynamo is similar to self-regulated and with a SSC's P4, capable of driving one amp (wich the dynamo is not capable of generating) it's not possible of burning the leds. With a good design it is not possible to have a voltage greater than the 7,5 V of wich the 3 series goldcaps is capable.
    Sorry of no providing you the final circuit but i am sure you can make a similar one with my explainings.
    I have built lots of dynamo lights using the circuit you have drawn! It works very well exactly as you have it! The standlight will provide sufficient light to be seen for around 5 minutes, more if you use a 1.5F 5.5V goldcap. There is no resistor needed in between the Cree and the goldcap. If you want an even better standlight use two gold caps in series in place of the smoothing capacitor. Since you are using a bottle dynamo flickering at low speed will still be minimal. This arrangement will keep both LEDs lit when you stop for even better visibility. If you do this you should use some voltage balancing resistors (10K ohms or so) across each goldcap to make sure the caps discharge fully overnight, this will prevent the caps from charging unevenly.
    Aug 2002
    London
    Quote Originally Posted by StevelKnievel View Post
    ....If you want an even better standlight use two gold caps in series in place of the smoothing capacitor.....If you do this you should use some voltage balancing resistors (10K ohms or so) across each goldcap to make sure the caps discharge fully overnight, this will prevent the caps from charging unevenly.
    Nice to hear some experience. I have only ever used supercaps with a rear light.
    How about connecting the mid-point of the caps to the midpoint of the leds and not needing the resistors.
    And isomax, not all GoldCaps are the same.
    Some have high internal impedance so charge and discharge slowly - 'uA' types
    others have low internal impedance so charge and discharge quickly - 'A' types
    and there are 'mA' types in the middle
    see http://www.panasonic.com/industrial/...e/cap_gold.htm
    It is mostly the same for other super-cap brands.
    Does anyone want 4 (or 5) component circuit that will charge your super cap quickly, and control the current into the bottom led? It will waste 5mA (1%)
    If you stay at 20mA in standby, you will get a dim light, but it will be last for a predictable and useful time.
    I would draw it and scan it now, but I can't remember how to post pictures here.
    Steve
    Aug 2002
    London
    ... I'm tempted to track down a breadboard from one of my friends and prototype it to see if the bottle dynamo can power both LEDs at a reasonable speed
    How about soldering the components to the pins of the supercap and taping them to the outside of it.
    Would proably last for years in a plastic bag!
    It will work fine with a bottle dynamo.
    Good luck
    Steve
    Quote Originally Posted by Bandgap View Post
    I would be interested, since I haven't seen many circuits around for standlights which don't seem to involve a lot of components. If you don't have a place to host your circuit image and link to it, I can upload it to my flickr account and link to it for you in this thread.
    Steve (seems to be a Steve-fest in this thread!)
    Flashaholic* hopkins's Avatar
    Nov 2007
    California
    Always liked generators on bikes except when stopped. Then the cars can't see
    you! I'd have to see some beam shots of the Cree being driven by the supercap
    at 1sec,15seconds, 60seconds to believe it'd put out enough to keep a driver
    from left turning in front of you just as you started across the intersection.
    Going from a stop to 1-2mph you're in the middle of the turn area just then and not generating a lot of light at that low speed? My idea here drives one Cree
    from a battery while stopped so you can be seen easier.
    Here's a couple shots of one of my bigger dyno lights. Not beamshots exactly, but it's something. I've actually been wanting to take some shots facing the bike in timed intervals to see just how fast the standlight dims and at what point it is to dim to be safe.
    This light has 6 Q5s that are running off of 4 1.5F 5.5v supercaps in series. When it's fully charged it gives enough light see and be seen. This picture was taken after the light was charged by riding around for a minute or so and then disconnected from the bike. By the time I took the pic the standlight had been on for maybe 30 seconds to a minute. Just using my eyes to judge it stays roughly this bright for about 3 minutes before it starts to get noticeably dimmer. After 7 to 8 minutes the light is pretty dim, but still visible from a good distance. 15 minutes and it's just barely glowing.
    That's good to know! I won't be using this particular light in remote areas, its just for a commuter for around town and back and forth from work. Given how many led's you have versus the supercaps, I think 1F or 1.5F for a single Cree should be fine.
    By the way, that's a really nice light! I remember coming across it in the archives and trying to track down some more info on it, such as a component list and circuit diagram. Can I ask what supercaps you used and the ESR? The 5.5V 1.5F supercaps I found all seem to be about 30 ohms.
    Now, if only DX would stop pushing the shipdate of my order further and further into the future. Hopefully I'll get the parts before the winter commute truly kicks in.
    Quote Originally Posted by isomax
    Hi, sorry for my very bad english, i am spanish....
    Thanks for the diagram and the design suggestions. I am not particularly good at soldering, so I would rather go with a design that has fewer components, and I suspect that using power LEDs as the rectifier diodes would result in a lot more noticeable flickering.
    Quote Originally Posted by frontranger
    This will be used to commute in town, and its rarely more than 2 or 3 blocks to a good streetlight. That being said, I usually carry a Luxeon III flashlight with me for emergencies, though I'd rather not go through the hassle of mounting and unmounting it all the time.
    Quote Originally Posted by MyAl
    that there could be a better way to run the lower LED....
    Thanks for the design tips, but the design is starting to go beyond my meager grasp of electronics! This is my first light, and I'd like to keep it as simple as possible as a learning exercise, that will also turn out to be really useful for my commutes. At this point, keeping the design simple is likely to help me avoid some error in the execution.
    Nov 2007
    California
    Hi Stevel - good demo pics. That should do the job for seeing and being seen.
    Wonder how much drag the generator (alternator?) makes when riding?
    At least one lower gear for flatland spinning when its on for night rides?
    All those Leds got to draw a good bit of current.
    Cheers
    hopkins
    It uses Martin's (pilom.com) manually switched voltage doubler/full wave rectifier setup. On the voltage doubler setting the light should be consuming around 6-7 watts and the full wave rectifier setting should be taking around 12 watts, but full wave isn't really necessary and it doesn't come up to power until over 20 mph. The dude who owns this light has it on his 29" singlespeed mountain bike with a Schmidt dynamo hub and he still hauls a$$! (He was super fast to begin with.) He says he doesn't notice the drag, but he does notice the heavier front wheel compared to a regular hub.
    Sep 2001
    New Jersey
    Ok, no problem. If you decide later on to improve the design let me know.
    Be sure to include a diagram of the circuit too.
    Good luck with it...
    Take care,
    Al
    Got Light?
    Flashaholic* Calina's Avatar
    Jul 2006
    Longueuil, Québec
    That would be great; if not for the benefit of the O.P., at least for the benefit of other members.
    Health is merely the slowest possible rate at which one can die.
