Klarus
Results 1 to 26 of 26
Thread: Maxflex3
    Default Maxflex3
    Just noticed the new Maxflex at http://www.taskled.com/maxflex.html
    Flashaholic* znomit's Avatar
    Aug 2007
    New Zealand
    Default Re: Maxflex3
    Nice updates:
    "If an optional 3mm or 5mm status LED is connected, the user can configure the status LED to warn when the voltage reaches Medium (status LED lights constant) or Low (status LED flashes). Now with on-board 100 ohm series resistor.
    Onboard pullup resistor on switch input to provide reliable performance of external momentary action switch when used with longer wires.
    Flashaholic Tidra's Avatar
    Nov 2006
    Slovenia - EU
    O man,…. I was really looking forward for some improvement on output voltage so you could drive 7 SSC P4 @ more than 500mA…
    Aug 2007
    New Zealand
    Quote Originally Posted by Tidra View Post
    Maybe you can. My new cree R2s are under 3.3V @ 1A = 23V for 7.
    Not sure when SSC will get these dies.
    Flashaholic* georges80's Avatar
    Oct 2002
    Sunnyvale, CA
    Yes, think about it...
    24V x 700mA = 16.8W output. At 90% efficiency that's 1.7W that you need to get rid of from maxflex to prevent it cooking.
    Also going to higher voltage requires changing components that I'm not willing to do at this stage.
    Besides, the moment I support 7 LEDs folk will want 8 so they can use 2 MC-E's... it never ends...
    Want high voltage and power - use CCHIPO - there is a reason that it is large
    cheers,
    george.
    LED drivers www.TaskLED.com
    I hate PM - so email me - info is in my profile.
    Enlightened dnlwthrn's Avatar
    Oct 2008
    Chicago 'burbs
    Any idea when these will be ready to ship?
    Oct 2002
    Sunnyvale, CA
    Quote Originally Posted by dnlwthrn View Post
    Hopefully within 2 weeks - I'm waiting on my assembly house to finish another batch and ship it to me. Keep an eye on the order page of my website - it will indicate when I have stock of maxflex3.
    cheers,
    george.
    Oct 2008
    Chicago 'burbs
    (bookmarks order page)
    Will do!
    Oct 2006
    England
    Quote Originally Posted by georges80 View Post
    Wanting to run 2 MC-Es isn't that unreasonable given how close it is to doing that (I reckon on max 28V required output - may even be as low as 26.4V). I suspect it might just stop there - at least reasonable wants would. I take the point about heat disippation, but that surely just requires a good heat path from the pad - something which some of us are doing already.
    Still planning on making a modded Maxflex myself to enable driving 2 MC-Es. Just because I can, and will then have something relatively unique! I'm assuming the relevant components are the same as on previous MaxFlex boards (ie a 35V Schottky) - I already have the 50V caps to swap in!
    p.s. hope your family problems worked out OK.
    Oct 2008
    Chicago 'burbs
    Just FYI, chris, my MC-E (in series) is only showing a Vf of just under 12.5V at 500mA (using analog meter on power supply). So you're talking about maybe 27-27.5V for two at 700mA. But check it out before frying anything...
    Oct 2002
    Sunnyvale, CA
    Quote Originally Posted by chris_m View Post
    The issue isn't just getting heat off the PCB to a heatsink, it is also how much heat can come off the switcher IC, to its thermal pad, through the thermal vias to the back of the PCB. That's an area that can't be improved on no matter how good the heatsink is.
    Even as it stands, to run 24V @700mA requires thermal potting compound (not just arctic alumina epoxy) to try and get heat off the top of the package also. I'm talking about being able to run the driver for extended periods of time at that power level.
    On maxFlex3 I have added more thermal vias (12 now versus 9) and also expanded the thermal path a bit on the top of the PCB (switcher IC side). Of course all those things are just helping a few percent more than before - so just an optimization versus a major improvement.
    Anyhow, I don't have any plans at this time to change the design. Maybe when I have some spare hours to play with I'll see how the driver works at 28V with some changed components - it needs to be stable and safe over the long haul otherwise folk will be destroying drivers and I'll be the one having to deal with returns and unhappy emails...
    The switcher IC has a Thermal coefficient of 37C/W and max junction temperature of 125C.
    So at 24V x 700mA we have about 2W of heat being dissipated in the switcher. That's close to 80C rise in package temperature. Assume ambient of 30C in the housing (it would be more than that...) and we have ~110C junction temperature... You can see we're pushing the limits already...
    cheers,
    george.
    Oct 2008
    Chicago 'burbs
    George,
    Do you have a recommended potting compound/process? I saw the warning about potting in the tech notes for the Fatman, and don't know that much about potting compounds...
    Oct 2002
    Sunnyvale, CA
    George,
    Arctic Alumina epoxy is fine - though rather expensive to use a lot. I'd recommend using a combination of heatsink attached to the thermal pad at the bottom of the PCB (the rectangular gold area) AND AA epoxy (or similar quality thermal epoxy that is essentially non-conductive & non-capacitive) to pot the top of the board (the switcher IC area) to another heatsink attachment. Potting on its own isn't enough - it needs to be used as a path to a heatsink that can move heat off the board and radiate it away.
    The potting is required at the higher power levels - say above 1.5W - though it all depends on ambient temperature. If you have maxFlex inside the LED housing and it is 'cooking' then you will have trouble.
    Turning on the thermal protection in the menu system would be a good idea and backup plan to protect the driver.
    cheers,
    george.
    Nov 2007
    yorkshire / England
    cheers,
    george.
    Hi George
    In my opinion this should be a default setting in the UI of all the flexes
    because it is not the first thing new users do ,
    they switch it on at full power .
    Oct 2008
    Chicago 'burbs
    cheers,
    george.
    My current housing design should provide ample heat dissipation. My concern was connecting the board to said housing. I'll have to look at the maxflex (when they are in, and I have one in my hands) to fully understand potting the front. I figured I'd just AA epoxy a small block of Al to the thermal pad and then AA that same block to the inside of the housing.
    Current plan is to run either a triple XR-E or a single MC-E (series wired) off a 7.4V LI-Ion pack. The other will probably run off a Fatman (which I currently have).
    Oct 2006
    England
    I'd probably choose to run at a bit less than 700mA anyway - you don't gain a lot of brightness for cranking it up that last bit from 500mA to 700mA. I think my heat sinking solution of an alu heatsink path attached with Arctic Silver to the heatsink pad would probably work OK for that. Do you really gain much heat dissipation from potting the top (where you have a couple of relatively poor thermal paths in the way) compared to just heatsinking on the pad which has a pretty direct connection to the switch junction?
    Anyway, I've seen others suggesting pushing the thermal capabilities even more within the existing voltage limits - running 1200mA at ~20V to 3 MC-Es wired 2s2p!
    Aug 2007
    New Zealand
    Thats on a bike light where hopefully that light level only gets used now and then for downhills... typical usage much less I hope .... Trout, what do you think?
    Nov 2007
    yorkshire / England
    Quote Originally Posted by znomit View Post
    I have a maxflex running 3 MCE as two paralell strings of 6 emitters
    @ full 1200ma from a 14.8 v 4.8 mah li ion
    the forward voltage of the setup was just under 19 volts .
    it has done 2 rides so far and with the newness at the moment full power got used for most of the ride just to pee off the other riders .
    ( they were short rides ) but when the wow factor is over then low is plenty with full for when needed
    My Maxflex lives in some copper pipe inside my stem with the thermal protection set at 50 the lowest and no problems with it dimming so far so I can only assume it is quite happy
    Oct 2006
    England
    But then so will my planned twin MC-E. Certainly don't plan on using full power on that all the time. Good to hear that something with worse potential thermal issues works fine.
    I've had no problems driving 2 strings of 6 dies with maxflex2. I've used my big light (http://www.candlepowerforums.com/vb/...d.php?t=188209) constantly since February with no issues, and I run it at full power alot! My theory on maxflex cooling is a bit different than the norm and I'd be interested to hear George's opinion. I have the driver AA'd directly to the housing as close to the emitters as possible and I'm depending on the enabled thermal protection to keep the LEDs and driver at a safe temp. The protection is set to 60deg and it doesn't trip unless I'm stopped with the light running full blast. This method of using the thermal capability of the maxflex to regulate LED temperature has been the cause for some discussion on this and MTBR forums, and most seem to think that it is a bad idea. It's worked for me so far and I'd build another light with this setup in a heartbeat. Thoughts, comments, ideas?
    Oct 2002
    Sunnyvale, CA
    Using the built in temperature monitoring of bFlex, nFlex or maxFlex (and now d2Flex) to limit the LED temperature is certainly NOT a bad idea. The primary intention to provide temperature limiting of the driver was specifically to keep the entire "system" within reasonable limits.
    nFlex and bFlex are very different thermally than maxFlex due to the typical usage of the drivers. With maxFlex being a boost, many folk are tempted to drive 5 or 6 LEDs and at full 1200mA output and thus the total power through the driver is much higher than the typical 3 LED configuration (at 1000mA) of nFlex and bFlex. The efficiency of maxFlex can also be several percent less than nFlex/bFlex due to it being a boost converter and thus having much higher input current (and thus losses).
    So, overall maxFlex will typically be running hotter and cooling/temperature control is more critical. The temperature sensing is performed within the uController (calibrated prior to shipping) and there can be a thermal lag between the switcher IC getting toasty and the uController sensing it. In some rare circumstances (higher power situations) this can cause the switcher to overheat before the uController can back down the current since it takes time for the heat to spread across the PCB and warm up the uController. In these rare situations using thermal epoxy on the switcher top side (inductor side) and letting a bit more ooze from the thermal pad/heatsink attach to the uController (the chip next to the golden thermal pad) will help with the heat coupling.
    cheers,
    george.
    Oct 2002
    Sunnyvale, CA
    Ok, so I just got notice from my assembly house that they shipped a decent sized batch of maxflex3 drivers this morning, which means I'll have them in hand tomorrow.
    So, finally the drought will be over!
    cheers,
    george.
    Oct 2008
    Chicago 'burbs
    Order placed.... (gets excited)
    Now I just need to get my order from Cutter to show up... Could be lots of lights being built this winter!
    Nov 2006
    Toronto, Canada
    cheers,
    george.
    I am a visual learner so photos or side by side hands on is how I learn best. Can you provide some photos (more then one please of different angles) if the 'potting' of the IC chip and the thermopad thing? Thanks in advance.
    Zero_Enigma
    I have no experience with thermal-potting resin. However I'm planning to give it a try. Here's a pic (that I posted earlier on MTBR), which shows how I'm proposing to do the first light. Later I'd do a Znomit-style light in a similar manner (if it works of course).
    Basically the plan is to wire up the whole circuit and test it on the bench first. Then once I'm happy it's all working just I'd pour the potting-goop into the sawn-off Berocca can, and leave it to set. Then test it one more time, before sliding the assembly into the housing, and AA'ing them into place. Or maybe I should use Artic-silver grease, so it can be easily disassembled for troubleshooting? Anyway, here's the pic....
    Any thoughts?
    Since my previous post, I've started reading-up on thermal-potting resin, and the more I read the less I liked the sound of it. Then I re-read George's post #13, and now I grok what he's saying about Arctic Alumina being sufficient if you provide an adequate heatsink. Consequently, I've gone right off the potting-resin idea that was shown in the pic. Instead, I'll just just do this:
    • AA bond a small Alu pad, covering the maxFlex's heatsink spot
    • Apply a generous squidge of AA, covering both switcher IC & the Alu pad
    • Stick the lot directly onto a heatsink mounted on the back-cap
    Sounds simpler than the potting idea
