The Fenix-Store
Results 1 to 6 of 6
Thread: what the heck would you do??!
    Flashaholic cruisemissile's Avatar
    Oct 2008
    sunny FLA
    Default what the heck would you do??!
    alright, I am presented with a dilemma on which setup to buy next
    1) a Surefire 6P in Satin Grey ($47 at wholesalemarineproducts) plus a 200 lumen Malkoff drop in ($50) OR
    2) A Gladius (in OD or Tan for $89 http://www.streichers.com/ProductDet...WK&Prod=BH-752)
    the SF would be timeless and classic and with malkoff give me a strong light.
    but the Gladius has different modes and that sexy ceramic coating. plus, at 89bucks, much cheaper than when they first came out.
    SF E2DL ..SF E1B ...Novatac 120T... Laser Devices OP-6/9 (LED)Pentagonlight L2+L3 ..Lumapower Incendio ...Fenix P1DCE
    parnass's Avatar
    Nov 2005
    Illinois, USA
    Default Re: what the heck would you do??!
    I used to have a Gladius. Keep in mind that the anti roll spikes on the Gladius make it difficult to find a holster which fits. Pocket carry of the Gladius can be uncomfortable.
    Retired engineer, author. Running Linux.
    Dec 2007
    New Castle Co., DE
    Easy. Buy both!
    My .02 FWIW YMMV
    I would get the 6P with Malkoff. If you want a low mode, then add a McC2S switch from The Sandwich Shoppe. For strobe, you can either cycle the tailcap manually or use a "wrist wobble" technique (basically wiggle the light back and forth, which achieves a strobe-like effect).
    If that is still insufficient, you can get the OpticsHQ/TLS reverse multifunction tailcap and drop-in, and you will have all of the functionality of the Gladius (with a much brighter max mode). The main downside, IMO, of the TLS tailcap is that it appears to have a much higher power draw than the Gladius electronics when the light is turned off.
    IMO, the 6P is sort of an "open architecture" light and you won't be locked into a proprietary design that is harder to upgrade/customize. You also have greater flexibility in using Li-ions with the 6P vs. Gladius.
    *Flashaholic* Sgt. LED's Avatar
    Sep 2007
    Chesapeake, Ohio
    Surefire! You can upgrade it's engine anytime the mood srtikes you or when new emitters come onto the scene without buying a new light.
    The Gladius sexy ceramic coating is not attractive in the least when it starts coming of.
    Flashaholic* bullfrog's Avatar
    Jun 2008
    Manhattan & the Catskills
    Quote Originally Posted by Sgt. LED View Post
    +1 gazillion
    Just like the sarge said, IMHO, the 6P could realistically (but we are never realistic, are we?) be the last light you buy as the "upgradability" and lego options are endless.
    Its a light for life between legos and the Surefire guarantee.
    ...as for me, when you want a good laugh, you will find me, in a fine state, fat and flourishing, a true hog of Epicurus' herd...
    Running Collection List
    HERE
