bigchelis
Whats the formula to calculate a rough estimate of run time?
With nickel hydride batteries?
With Lio-ion batteries?
Thanks,
bigchelis
Thanks,
bigchelis
I remembered reading this before and searched it without success. What if you use multiple cells. In you're example say it was 3 cells would it be 6000 divided by load of 500mAh in which case run time would be about 12 hours right?Hello Bigchelis,
If you take the battery capacity and divide it by the load, you will end up with an estimate of run time.
For example, if your battery capacity is 2000 mAh and your load is 500 mA, you should get a run time of around 4 hours.
Tom
