P60 sized led drop-ins (part 3)
Fizz753
South West Michigan
[Continued from Part 2]
While reading the thread titled "Dealextreme drop in for G2, 6P, etc???" I started making a list of the drop-in's I saw. It got a little out of hand. :sssh:
I thought I would put the list out here instead of buried 10 pages in to the above thread (no offense to the guys and gals in said thread :wave:)
** Don't forget to check out the P60 Flashlight List {host} post as well. (and add to it if you can :) ) **
** BatteryJunction.com **
THRUNITE P60 Style Cree XP-G R5 LED Drop In - 3 mode
http://www.batteryjunction.com/thrunite-3mode-p60-r5.html
$34.95
300 Lumens (1A Drive Current) (Tested 260 OTF per MrGman)
2.7-9V input voltage
Cree XP-G R5 LED
Outer spring is removable for some fitments
Alumium textured/OP reflector with bronze heatsink base
Bezel diameter: 26.5mm
Copper base diameter: 19mm
Height including support spring: 36.7mm
Height excluding support spring: 28.8m
THRUNITE P60 Style Cree XP-G R5 LED Drop In - 1 Mode
http://www.batteryjunction.com/thrunite-p60-r5.html
$32.95
Cree XP-G R5 LED
P60 Style Cree R2 LED Drop In - 1 Mode
http://www.batteryjunction.com/1-mode-led-upgrade-r2.html
Regular Price: $39.95
Sale Price: $19.95
225 Lumens (1.1A Drive Current)
3.6-18V input voltage
Alumium textured/OP reflector with copper heatsink base
Height excluding support spring: 28.8mm
P60 Style Cree R2 LED Drop In - 225 Lumens - 5 Mode
http://www.batteryjunction.com/5-mode-led-upgrade-r2.html
Regular Price: $42.95
Sale Price: $21.95
High/Medium/Low Output PLUS Strobe & SOS Modes
Hi (225 lumens) > Mid (130 lumens) > low (80 lumens) > Strobe > SOS
Cycle level/mode with soft press (most clickies work) to switch level/mode
P60 Style UV UltraViolet LED Drop In Flashlight Upgrade Engine 395-405nm
http://www.batteryjunction.com/p60-uv-buld.html
Regular Price: $34.95
Sale Price: $19.95
3-Watt UV LED Drop-in for Surefire and other P60/P61 etc style lamp and bulb lights.
DC-DC regulated for 3V-9V. Able to take 2 x CR123A,2 X RCR123A 3V or 1 x 18650 3.7V
Wavelength = 395nm - 400 nm
P60 Style 940NM InfaRed IR Drop In
http://www.batteryjunction.com/infrared-ir-p60-drop-in.html
Regular Price: $49.95
Sale Price: $24.95
940NM output
6-8.4V input voltage
Surefire P60L LED Assembly
http://www.batteryjunction.com/surefire-p60l.html
Price: $49.00
Max Output: 80 lumens; Runtime: Up to 12 hours, depending on flashlight model
Precision reflector helps create a smooth, flawless, user-friendly beam
Fits in SC1 Spares Carrier for field deployment
** Lumens Factory **
http://www.lumensfactory.com/cart.php?cat_id=2&sub_cat_id=7
D26-LED High Output Single Mode LED Reflector Module (3.6V-13V)
$24.00 - 3.6V to 13V Regulated Input for Maximum Flexibility - High Output Cree XR-E, R2 LED
Maximum Current Output at 1000mA - High Colour Temperature (Cool White, 5000K-10000K according to Cree)
High Temperature Resistant Orange Peel Coating - Every Reflector Module is Pre-Focused for the Ultimate Spot
D26-LED Selected Warmer Tint Version (Limited Quantity) (3.6V-13V)
$28.00 - 3.6V-13V Regulated Input - Maximum Current Output at 1000mA - High Output Cree XR-E, R2 LED
Selected using Integrated Photometric Sphere to have Warmer Colour Temperature (5000K-5500K)
D26-LED 3.6V Special LED Module (Selected Tint)
$28.00 - High Output Single Mode, Cree XR-E, R2 LED
Designed for 3.6V Rechargeable Applications, Input 2.4V to 4.2V (general voltage range of one 3.6V li-ion rechargeable battery)
Maximum Current Output at 1200mA Constant Output at 1000-1200mA, Warmer Colour Temperature (5000K-5500K)
D26-LED 3 Mode (Low-Mid-High, Memory) LED Module (3V-3.7V)
$28.00 - Cree XR-E, R2 LED, Warmer Colour Temperature (5000K-5500K)
3V-3.7V Regulated Input, 3 Mode (Low-Mid-High with Memory, 5%-30%-100%)
Orange Peel
D26-LED 3 Mode (Low-Mid-High, Memory) (6V-13V)
6V to 13V Regulated Input, Orange Peel
** Dealextreme **
Ultrafire Cree, Regulator, Reflector 1x18650 2xCR123A Lamp Assembly
http://www.dealextreme.com/details.dx/sku.13143
$10.40 accepted voltage: 3.6V ~ 9.0V 900mAh regulator board Orange-peel aluminum reflector
3W Cree, Regulator, Reflector 1x18650 2xCR123A Module Set
http://www.dealextreme.com/details.dx/sku.14247
$12.80 accepted voltage: 3.6V ~ 9.0V 900mAh regulator board Orange-peel aluminum reflector
DX 3W Cree Module CM1
http://www.dealextreme.com/details.dx/sku.32314
$10.82 3.2V~9.0V Input
Beamshots + review at: http://www.light-reviews.com/cm1/
SSC 42180-T 3W Emitter Reflector Driver Module
http://www.dealextreme.com/details.dx/sku.44068
$13.79 Input voltage: 3.7V ~ 8.0V Current: 900mA
3W Cree Drop-in Module (supports Surefire 6P)
http://www.dealextreme.com/details.dx/sku.60590
$7.73 3V~18V, textured aluminum reflector
Cree 5-Mode Emitter Reflector and Driver Module
http://www.dealextreme.com/details.dx/sku.42696
$9.97 Typical driving voltage: 3.7V (maximum voltage: 4.2V. Do not exceed.)
Cree Drop-in Module for Surefire 6P
http://www.dealextreme.com/details.dx/sku.60776
$7.73 Voltage Range: 2.9V ~ 9V
Cree Drop-in Module
http://www.dealextreme.com/details.dx/sku.71862
$12.48 Ultrafire 4-Mode 3.7V~6V
KLC8 LED Emitter with Driver and Reflector Module Set
http://www.dealextreme.com/details.dx/sku.88935
$9.90 (3.7V~6.5V Input)
Q5-WC 3-Mode 0~100% LED Drop-In Module
http://www.dealextreme.com/details.dx/sku.111074
$16.90 3-Mode: 0~100% (adjustable) > Strobe > SOS 3.7V
Review: http://www.light-reviews.com/dx_sku_11074/
Cree Q5 LED Drop-in Module
http://www.dealextreme.com/details.dx/sku.112621
$8.69 Input Voltage Range: 3.7V~18V Maximum Output: 200 Lumens
Cree Q5 LED 5-Mode Drop-in Module
http://www.dealextreme.com/details.dx/sku.113622
$12.96 3.6V~7.2V Input, Current and lumens are rated by the manufacturer
1. Low 25mA, 80LM
2. Mid 550mA, 120LM
3. High 950mA, 200LM
4. Strobe 800mA, 250LM
5. SOS 800mA, 200LM
Cree R2 Drop-In 1-Mode LED Module
http://www.dealextreme.com/details.dx/sku.118346
$9.10, Input: 3.7V~18V, Output: 117~225 Lumens (manufacturer rated)
Cree P4 1-Mode LED Drop-In Module
http://www.dealextreme.com/details.dx/sku.118150
$9.53 Input: 3V~12V
Cree Q2 LED Drop-In Module for WF-502B and Similar Flashlights
http://www.dealextreme.com/details.dx/sku.125061
$11.29, 3.6V~12V Input, Single mode regulated circuitry
Cree XR-E R2-WC 5-Mode 250-Lumen LED Drop-in
http://www.dealextreme.com/details.dx/sku.137658
$10.56 Input: 3.6V - 8.4V, Reflector: Textured, Memory: Unknown
Modes: High (250 lumens) > Mid (150 lumens) > low (80~100 lumens) > Strobe > SOS
Cree XR-E Q5 1-Mode Drop-in LED
http://www.dealextreme.com/details.dx/sku.138802
$11.80 Input: 3.7V - 12V, Textured aluminum reflector
Cree R2-WC 250-Lumen 5-Mode Memory Drop-in LED
http://www.dealextreme.com/details.dx/sku.144492
$11.73 - Input voltage range: 3.0V~8.4V - - Maximum brightness: 250 lumens (manufacturer rated)
5-Mode driver circuitry with mode memory: Hi > Mid > Lo > Strobe > SOS - Alumium textured/OP reflector
Cree R2-WC 3-Mode + 0~100% LED Drop-in
http://www.dealextreme.com/details.dx/sku.1759003
$11.39, Input: 3.6V~8.4V, Cree XR-E R2-WC LED,
200 lumens (manufacturer rated), Aluminum textured reflector
P4-WC 3-Mode 0~100% LED Drop-In Module
http://www.dealextreme.com/details.dx/sku.111075
$13.85 - Voltage Input: 3V ~ 15V, Cree P4 (color WC) Emitter (190 Lumens max)
DX says 3 Mode: 0~100% (adjustable) > Strobe > SOS. However users are reporting that it's now a 5-mode (Lo, Med, Hi, Strobe, SOS).
Cree MC-E LED 3-Mode 410-Lumen Drop-in Module w/Copper Heatsink Base
http://www.dealextreme.com/details.dx/sku.212037
$23.49 - Emitter Type: Cree MC-E - BIN: K-WC - Voltage Input: 2.7V~4.2V
Mode Arrangement: Hi (2800mA, 410LM) > Lo (1000mA, 100LM) > Strobe (1500mA, 200LM)
Update: Reacently tested by MrGman over in the Actual Lumens readings in 6" dia. Lab Sphere IS with SC 5500 control thread. Readings were:
DX_MC-E High - 385 lumens turn-on - 345 lumens warm. Low 150 lumens warm.
Cree XPE-WC-R2 5-Mode LED Drop-in
http://www.dealextreme.com/details.dx/sku.253369
$11.66 - XPE-WC R2, Voltage Input 2.6~4.2V, 4.2V max
Hi 280LM 1200mA > Mid 200LM 800mA > Low 120LM 500mA > Fast Strobe 200LM 1000mA > SOS 250LM 1200mA
__
** BugOutGearUSA **
http://www.bugoutgearusa.com/
Cree R2 Drop-In Module
http://www.bugoutgearusa.com/crq5drmo.html
$47.95
Approx. 240 Lumen
Cree R2 LED Driven at 950mAH
3+ Hours Total Runtime
Regulated
Input Voltage: 4.5V - 12V
Shock/Recoil Proof
10,000 Hour LED Life
Aluminum Reflector
Brass Heat Sink
Improved Beam Pattern
__
** Kaidomain **
UltraFire SST-50 3.7V~4.2V
http://www.kaidomain.com/ProductDetails.aspx?ProductID=110277
$51.16
3-Mode OP/SMO Aluminum Reflector
Cree Q5 Drop-In 1-Mode LED Module
http://www.kaidomain.com/ProductDetails.aspx?ProductId=12775
$9.34 Voltage Range: 3V~18V
http://www.kaidomain.com/ProductDetails.aspx?ProductId=13769
$9.49 Voltage Range: 3.7V~18V, Output: 117~225 Lumens (manufacturer rated)
CREE XR-E P4, 6P Drop-in Module
http://www.kaidomain.com/ProductDetails.aspx?ProductId=14634
$8.94 Voltage Range: 2.7V - 6V
Runtime:
About 1.7 hours on two 3.0V CR123A cells
About 2.5 hours on 17670 Li-ion cell
About 3.5 hours on 18650 Li-ion cell
K2 LED Drop-in (26mm)
http://www.kaidomain.com/ProductDetails.aspx?ProductId=45880
$6.90
CREE MC-E K bin 26.5mm 3.7V~4.2V OP Aluminum Lamp
http://www.kaidomain.com/ProductDetails.aspx?ProductId=71614
$25.99
CREE Q5 3.7~4.2V 5-Mode Drop-in
http://www.kaidomain.com/ProductDetails.aspx?ProductId=64736
$9.44
CREE R2 3.7~4.2V 1-Mode Drop
http://www.kaidomain.com/ProductDetails.aspx?ProductId=64835
$7.97 - 180 Lumens
Solar Force CREE R2-M Model 5 (26.5mm) 3.7V Lamp
http://www.kaidomain.com/ProductDetails.aspx?ProductId=59236
$20.50
CREE P4 One Mode (3.7V~4.2V) Lamp
http://www.kaidomain.com/ProductDetails.aspx?ProductId=50091
$7.45
SolarForce CREE R2-M Model 5 (26.5mm) Lamp Drop-in
http://www.kaidomain.com/ProductDetails.aspx?ProductId=50086
$20.15 - Modes:Low/Mid/High/Strobe/SOS - Voltage input range 3.0V~8.4V
Voltage & Current (DC Power Supply) 3.0V~110mA,8.4V~580mA - Lumen: 230
Solar Force CREE R2 (26.5mm) Lamp 1-mode Drop-in
http://www.kaidomain.com/ProductDetails.aspx?ProductId=51085
$19.36 - Reflector: OP Aluminum - Lumen: 230 - Voltage input range 3.0V~8.4V
3.7V~4.2V CREE XPG R5 WC LED 5-mode Lamp
http://kaidomain.com/ProductDetails.aspx?ProductId=102064
$14.86
CREE XPG R5
200lumen/90minutes
Modes High/Mid/Low/Strobe/SOS
CREE XPE-Q3 5A Warm White 5-mode LED
http://www.kaidomain.com/ProductDetails.aspx?ProductId=93770
$10.00
3.7*4.2 voltage
OP Aluminum reflector
** Malkoff Devices - http://www.malkoffdevices.com/ **
http://www.malkoffdevices.com/shop/dropin-mod-dropins-to-fit-surefire-c-1_14.html
M60 Mod to fit Surefire
$55.00 - Input voltage 3.8V - 9V, Current Draw 750ma at 6 volts, Led is a Cree XRE 7090
Runtime is 1 1/2+ hours on 2 CR123 primary batteries, solid brass heatsink construction
Utilizes a Cree 8 degree optic.
M60F 20 Degree Flood
output is 220+ lumens, The optic produces an outstanding room lighting beam.
Throw is typically limited to approximately 120+/- feet. Utilizes a Cree 20 degree optic
M60L (Low Output)
$55.00 - Input voltage 3.8V - 9V, Current Draw 350ma at 6 volts, Led is a Cree XRE 7090
Runtime is 4 1/2+ hours on 2 CR123 primary batteries, solid brass heatsink construction
output is 140+/- lumens, Utilizes a Cree 8 degree optic
M60LF (Low output - Flood)
$55.00 - Input voltage 3.8V - 9V, Current Draw 350ma at 6 volts, Led is a Cree XRE 7090 Q5 WG tint
output is 140+/- lumens, The optic produces an outstanding room lighting beam.
Throw is typically limited to approximately 100+/- feet. Utilizes a Khatod 25 degree optic
M60LL (Low Low output)
$55.00 - Input voltage 3.8V - 9V, Current Draw 170ma at 6 volts, Led is a Cree XRE 7090
Runtime is 8 +/- hours on 2 CR123 primary batteries, solid brass heatsink construction
output is 80 +/- lumens, Utilizes a Cree 8 degree optic
M30 to fit a Surefire
$55.00 Input voltage is 1-5.5 volts, The output is approximately 235+ lumens at 3.3v+ and 160+ lumens at 3v.
The runtime is 1 1/4+ hours on one CR123 primary battery. The LED is a Cree XRE 7090.
This design utilizes a Cree 8 degree optic.
M30W (warm tint beam)
$55.00 The input voltage is 1-5.5 volts. The output is approximately 170 lumens at 3.3v+ and 120 lumens at 3v.
M60W (warm tint beam)
$55.00 The input voltage is 3.8 - 9 volts. Below 3.8 volts it will drop out of regulation and run direct drive.
The output is approximately 170 lumens. Runtime is 1 1/2+ hours on 2 CR123's. This design utilizes a Cree 8 degree optic.
M60WF (warm tint, flood)
The output is approximately 170 lumens. The runtime is 1 1/2+ hours on 2 CR123's. This design utilizes a Cree 20 degree optic.
__
** Wolf Eyes drop-ins ** http://www.pts-flashlights.com/products/productList.aspx?uid=1-25-114-147 **
Wolf Eyes - D26 3.7-13V Cree R2 WC LED Drop-in
http://www.pts-flashlights.com/products/product.aspx?pid=1-25-114-147-6518
$63.99
Cree R2 WC bin HO 3.7V-13V D26
Output: 280 lumens
Voltage: 3.7V-13V
Wolf Eyes - D26 3.7-6V Cree R2 WC LED 2-Mode High & Low
http://www.pts-flashlights.com/products/product.aspx?pid=1-25-114-147-6524
$68.99
Digital Cree R2 WC Bin LED HO 3.7V-6V D26 lamp assembly.
Output: 280 lumens
Voltage: 3.7V-6V
Wolf Eyes - D26 3.7-6V Cree R2 WC LED 2-Mode Tactical Strobe
http://www.pts-flashlights.com/products/product.aspx?pid=1-25-114-147-6520
$69.99
Output: 280 lumens
Voltage: 3.7V-6V
Wolf Eyes - D26 3.7-6V Cree R2 WC LED 4-Mode
http://www.pts-flashlights.com/products/product.aspx?pid=1-25-114-147-6526
$68.99
Output: 280 lumens
Voltage: 3.7V-6V
Circuit sequence: 100% (280 lumens), 20% and 2% for low.
D26 3.7-6V Cree R2 WC LED Drop-in *Low VF*
http://www.pts-flashlights.com/products/product.aspx?pid=1-25-114-147-6516
$59.99
Output: 280 lumens
Voltage: 3.7V-6V
__
** Lighthound.com ** -
Lighthound Cree Drop-In
http://www.lighthound.com/index.asp?...OD&ProdID=2605
$19.99 accepted voltage: 3V ~ 12.6V up to 240 lumens
LOP (Light Orange Peel) textured aluminum reflector
UNIQ Cree Q5 Drop-In
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=3513
$17.99, 3.7 - 15V Input, 1000mA, Textured aluminum reflector
Solarforce LC-1 Drop-In with Cree R2 LED - Single Mode
http://www.lighthound.com/Solarforce-LC-1-Drop-In-with-Cree-R2-LED--Single-Mode_p_1633.html
$19.99 - Cree LED and an aluminum reflector (light orange-peel-textured reflective coating)
Single Level Constant Output, Input voltage: 3V-12.6V
Compatible with the Solarforce L2 and Surefire's P-series flashlights
Solarforce LC-5 Drop-In with Cree R2 LED - Five Modes with Memory
http://www.lighthound.com/Solarforc...ee-R2-LED--Five-Modes-with-Memory_p_1634.html
$24.99 - Cree LED and an aluminum reflector (light orange-peel-textured reflective coating)
3 Levels+Flashing+SOS-signaling, Input voltage: 3V-8.4V
__
**Dereelight drop ins**
1S(1-stage) cree XR-E module
- Input Range: 2.8~4.2V
- Output Range: 1.2A
- Battery Type: 1x18650,1x17670
- Features: Constant output at it's fully input range
Over discharge protection
1SM-2(1-stage multi power) Cree XR-E Q5 module (16V max)
- Input Range: 3~16V
- Output Range: 1A
- Battery Type: 1x18650, CR123A's, RCR123's
- Features: Constant output at 4.5~16V. Recommended use 2xCR123A,3xCR123A or more.
3SD(3-stage digital) Cree XR-E Q5 module
- Battery Type: 1x18650, 1x17670
Three stage output,100%-50%-5%
Memory function
Change level by push switch
3SM(3-stage Muti-power digital) Cree XR-E module
- Input Range: 3~9V
- Output Range: 1.0A
- Battery Type: 1x18650, 2xCR123A, 2xRCR123
- Features: Constant output using CR123's
Memory function
** OpticsHQ P60 Head and tailcap **
LED Drop-In and Multi-Function Tailcap Kit
http://www.opticshq.com/page/Optics/PROD/Surefire-HID/ACC-DTC-KIT
$89.99
Working voltage: 4.2-18.0v
Maximum output at the emitter approximately 220+ lumens about 2-3 hours
[FONT=Verdana,Arial,Helvetica][SIZE=-1]More than 6 hours at low output[/SIZE][/FONT]
Fits the following SureFire Lights: G2, G3, 6P, 6PD, 9P, Z2, G2Z, C2, C3, M2
LED Drop-In and Multi-Function (Reverse) Tailcap Kit
http://www.opticshq.com/page/Optics/PROD/Surefire-HID/ACC-DTC-R-KIT
$89.99
* G & P *
G&P Q5 230 Lumens CREE LED Flashlight Torch Lamp GP751
$41.99 Input: 4.5v - 9v
G&P Q5 LONG FOCUS 230Lm CREE LED Flashlight Lamp GP751L
(Ebay links are dead at the time of update.)
* Solarforce *
http://www.solarforce.hk/PRD/main.jsp
LC-1 (LED module)
Features:
Module consists of a Cree LED and an aluminum reflector (light orange-peel-textured reflective coating)
Single, or 5 modes (3 Levels+Flashing+SOS-signaling)
- Models available:
I. LC-1 (R2 or Q5, single mode, 3V - 18V)
II. LC-1 (R2 or Q5, 5 modes, 4.2V - 8.4V)
III. LC-1 (R2 or Q5, 5 modes, 3.7V only)
LC-IR (Infra-red LED module)
Features:
Module consists of a IR LED and an aluminum reflector (mirror-like reflective coating)
LC-UV (Ultra-violet LED module)
Features:
Module consists of an UV LED and an aluminum reflector (mirror-like reflective coating)
Input voltage: 3 - 4.2V
At the time of this update Lighthound has these in stock:
-=Surefire P60L LED Reflector Assembly=-
Max 80 lumens, Runtime up to 12 hours depending on flashlight model.
(stores listed in no particular order)
$49.00 - http://www.lapolicegear.com/sup6ledreas.html
$49.00 - http://supremeco.com.hk/catalog/product_info.php?cPath=1_26_30&products_id=4755
$49.00 - http://www.surefire.com/maxexp/main/co_disp/displ/carfnbr/254/prrfnbr/24502/P60L-LED-Assembly
** Assorted forum posts that you might find useful**
DealExtreme 1343, 1447, and Wolf-Eyes 130 Lumen Cree Module P60 Cree drop-in modules Runtimes!
REVIEW - CREE DROP IN from EBAY***VERY NICE***
Wolf Eyes cree drop-in
The post that started it Dealextreme drop in for G2, 6P, etc???
And many posts I probably missed.
Thanks everyone! :)
jzelek
Whats the Brightest P60 LED drop in Module?
Hi everyone, I have a Malkoff M60 drop in for my Surefire 6P (Bored for a AW 18650).
Is this still the brightest P60 LED module you can buy or is there something new thats brighter using a R2 Bin?:grin2:
kramer5150
Palo Alto, CA
Re: Whats the Brightest P60 LED drop in Module?
nope the M60 is the brightest... however if you can get him to make you an SSC-P7 direct drive that will blow it away. I had the recent opportunity to play around with one of these in an 18650-drilled 6P and it was VERY bright, almost a pure flood. Like carrying a 100 watt lightbulb
AMRaider
USA
+1 for the Malkoff M60.
I have found Malkoff's M60 to be excellent. There may be brighter drop-in modules out now, but you would need sophisticated equipment to actually see any difference. By the way, the current M60 (optic) has excellent throw.
Gunner12
Bay Area, CA
If you want output, see if you can get someone to make you a Seoul P7 or Cree MC-E drop-in. Think 4 P4s or XR-Es in one package. Each one will probably receive less current then a single P4 or XR-E but you get more output overall, and a wider, floodier beam.
harddrive
Australia
A Dereelight 1S drop in drives the Q5 (or R2 if they are still in stock) at 1.2A on a single 18650/17670 battery. I found my dereelight to be brighter than my M60. (overall output and throw judged by my naked eye)
Also I believe that the malkoff M30 with a 17670 in your 6P would be slightly brighter than the M60.
Essentially it all comes down to what emitter is used and how hard it is being driven. Assuming all use a Q5, the Dereelight will be brightest, M30 next, M60 after that.
The other thing is "brightness" to some means overall output and to others they want a really bright hot spot and max throw. A Dereelight drop in with smooth reflector has a much brighter hot spot and further throw than a M60. It has less spill and more ringy beam too.
Like the other guys mentioned a P7 or MCE dropin will kill all the above for overall output but not throw.
jzelek
I just purchased a Dereelight 3SD Cree XR-E WC R2 (SMO & OP) driven at 1.2 amps (18650) from FlashCrazy.
I'll let you know how it compares to the Malkoff M60 (RCR 123s).:popcorn:
I really wanted a M30 (18650) but I haven't seen it in stock for a couple of months now.
Fizz753
South West Michigan
Wow, part 3 already. :)
Anyway the list has been updated, prices fixed some links updated etc. Enjoy.
And as always if you spot an error or something missing let me know and I'll get it fixed. :)
rejeme
Thanks CampingLED. I removed the outer spring and it fit like charm. Anybody else notice that the DX17593 acts funny when the batteries are low?
bigchelis
Prunedale, CA
Please Add the Malkoff P7 drop-in. He makes a few now upon request, but next year I don't see how it wouldn't be added to his website as one of his many options.
MSRC93
I just ordered a Malkoff M60, Still trying to find a host light for it. Hmm. Maybe a 6P?
Can anybody post up some pics of the 6P M60 setups?
Any pointers, tips, tricks? I just ordered the bulb, how long does there shipping normally take?
Wolf359
United Kingdom
i would suggest looking at the solarforce L2 as a P60 host i have found there build quality very good at a reasonable price
kramer5150
Palo Alto, CA
There is a P60 host thread floating around if you search for it, its not a sticky but it never really seems to die out completely. It would be off topic to recommend hosts in this thread... so I'll refrain.
glenda17
I received the DX Trustfire TR-C2 MCE P60 today. It pulls 1.8A from a 18650. It has good output but no where near a P7 Aurora, it also has the crumby cree rings. The tint is very indcandescent like. The hot spot isn't as strong as the UF501B R2, it is sort of a floody light with poor beam quality. The host is of nice quality. It has memory High-Low-Strobe. Not bad for under $35.
Winx
Tampere, Finland
Dereelight 3SD Q5 burned (almost)
My 3SD burned last night when I was jogging with my girlfriend. It had brownish center even when it was new but yesterday it got really brown. I guessed right when I looked at the emitter: brown spot...
I don't think it was because of overheating. It was -9°C outside and 6P's body has always been warm after some use. The module is 9 months old so it doesn't have warranty. I already ordered WF-501B camo with R2 WC from DX and replace emitter from it. Cheapest option was Q5 WC with 14mm base from Shiningbeam or Solarforce R2 drop-in, but maybe I'll find some use for UF camo body :).
Picture number 4 is underexposed to show how the beam looks in a real life.
kramer5150
Palo Alto, CA
I just did a similar transfusion last night. Pulling the R2-WC from my DX:14442 and transplanting it into a Husky XR-E spotlight. This one is the most pale-white of all my R2 emitters, and because of that it makes it appear brighter. RIP 14442:cool:
I couldn't get the emitter board out of the brass pill though. Not sure what DX uses for thermal adhesive but its solid. I just removed the DC board from the 14442, scraped off the residual solder, and placed the entire brass pill on the stove. The solder melted before the thermal adhesive degraded. So I just pulled the emitter straight from that.
:twothumbs
Pöbel
Germany
i wouldn't recommend on buying that. The host is nice quality but has virtually no heatsinking. MC-E at 1,4A gets rather hot for an P60 host WITH good heatsinking.
The dropin itself isn't great either. The pill has really thin walls, the driver seems to be direct drive with pwm for the 2 levels.
It's better to build your own pill. Use kai's 2 mode driver with 3 7135 chips and add a 4th. this will give 1,4A.
dezertdog
The M60 is not designed to run on 1 cell (3.7 volts), you should be using the M30 with an 18650. Running the M60 on 1 cell puts it in direct drive mode and you are only getting ~160 lumens instead of the rated ~235. Call up Gene and see if you can send it back and get the M30, or start using 2 cells (7.4 volts).
From their site:
M60
"The input voltage is 3.8 - 9 volts. Below 3.8 volts it will drop out of regulation and run direct drive."
M30
"It was designed specifically to fit SureFire 3P, 6P, 6Z, C2, M2 and G2 flashlights WITH A SINGLE LITHIUM RECHARGEABLE CELL."
"The input voltage is 1-5.5 volts."
