Fitorch
Page 52 of 52 FirstFirst ... 2424546474849505152
Results 1,531 to 1,550 of 1550
Thread: P60 sized led drop-ins (part 3)
  1. #1531
    Oct 2013
    Russia
    Default Re: P60 sized led drop-ins (part 3)
    Quote Originally Posted by archimedes View Post
    Was not available as a turnkey dropin, but you may want to search for @ahorton aspheric P60 builds ....
    Thank you! Now I vaguely remember that those lenses were sold also as kits...
  2. #1532
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Quote Originally Posted by ma tumba View Post
    Glad to help and, yes, that's right.
    ... is the archimedes peak
  3. #1533
    KITROBASKIN's Avatar
    Mar 2013
    New Mexico, USA
    Illumn.com sells the 27.2mm Ahorton spacer and the Ahorton lens in the USA. Look under flashlight parts.
  4. #1534
    Oct 2013
    Russia
    Quote Originally Posted by KITROBASKIN View Post
    Thank you, that is a great lead!
  5. #1535
    Unenlightened
    Sep 2017
    I bought a P60 sized led drop in for my old Surefire G2 from Battery Junction a few months ago; it is the single mode 335 lumen model from SZX. It works fine except that the flashlight occasionally needs to be whacked against something to light it up. I figured out the problem is that the bezel assembly leaves the drop in slightly loose when it's screwed down fully. Put in the drop in, screw the front end on - and it rattles when you shake it.
    Troubleshooting the problem last night I figured out that an o-ring between the lens and the drop in would tighten everything up, remove the rattle, and make the light work without the whacks. The ideal o-ring is a number 22 (1-1/8" OD, 1/16" width). Well, my hardware store had the number 21 and the number 23, but not even a bin for the 22. The helpful hardware guy showed me some unnumbered o-rings and I picked one with an 1-1/8" OD and 3/32" width. Works great: no rattle, no whacks, the light works every time.
    I guess I could sand a bit off the bottom of the bezel assembly to get the same result (the light is a yellow Nitrolon model), but I don't like to mess with the original parts unless there's no other way.
  6. #1536
    Malkoff all the way! I've got an m60, m61, m61n, m61l, and m61nl. They rock!
  7. #1537
    Are there any MG-T2 Drop ins on the market?
  8. #1538
    Flashaholic* DellSuperman's Avatar
    Dec 2012
    Singapore
    Quote Originally Posted by EricJames View Post
    Vinh made them some time back but the lack of a proper reflector makes it tedious to build.
    Im not sure who else makes them as they are not one of those lumen powerhouse or pencil beam kinda of emitters. But they do have pretty nice tint.
    Found this: http://www.fstoplights.com/ijk-local...s-4000k-5000k/
    A Singapore based online shop...
  9. #1539
    Helo everybody, what kind of drop in for ultrafire c-602 can i use?
  10. #1540
    I wonder if there is an aspheric p60 drop in that provides a truly pencil beam, similar to that of saabluster's lights?
    I'm a bit late to this, but alternatively to the Ahorton kit, Solarforce manufactures and lists a housing/lens that should screw onto your pill setup on any P60 build. I'll find the link when I get home.
  11. #1541
    I picked up three SureFire G2s recently in the hope of turning them into beater lights for the kids to use while camping. Other than Malkoff, what other options do I have for single mode drop-ins?
  12. #1542
    Aug 2011
    Fredneck, Md.
    Customlites offers single mode, and Vihn's can be programmed for one mode. I'm sure there are others, but those are the first to come to mind
  13. #1543
    Flashaholic* Kid9P's Avatar
    Apr 2006
    NJ
    Hey guys,
    I own a few Malkoffís and love them.
    Iím building a couple of beater lights for the kids to use camping.
    They prefer throwers for the big open fields.
    A few years back, XPG2ís on smooth reflectors threw amazingly well.
    Looking for similar throw without quick heat up on high.
    Anything out there you guys can recommend?
    Hoping one of those new ledís would fit the bill.
  14. #1544
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Oslon Black Flat ?
    XP-L HI ?
  15. #1545
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    Quote Originally Posted by kamagong View Post
    PflexPro also do single mode drop ins.
    P
  16. #1546
    Apr 2006
    NJ
    Oslon Black Flat ?
    XP-L HI ?
    Do you know who offers the Olson drop in ?
  17. #1547
    Apr 2006
    NJ
    Do you know of a PflexPro model thatís specifically a thrower?
  18. #1548
    Flashaholic marco.weiss's Avatar
    Dec 2016
    Brazil
    sportac with xpl-hi (cool or neutral) is another good option.
  19. #1549
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Quote Originally Posted by Kid9P View Post
    Maybe @vinhnguyen54 ? Unless you were building your own ....
  20. #1550
    Mar 2013
    New Mexico, USA
    PFlexPRO offers the L2 with an XPL HI that can throw a rated 800 meters, and the C8 has quite a bit of throw in a relatively compact size, but if you want a P60 dropin for throw, his XPL HI is more of a general purpose, shorter range thrower because of the small reflector. He does not dedome LED's because of the degradation in tint, but a dedomed XP-G2 in a P60 has a nice little beam with appropriate faint spill. mtnelectronics did one for me a few years ago.
