in_the_dark
- Joined
- Feb 26, 2008
- Messages
- 35
I've searched a couple times with not luck finding comments on the dimming issue I'm having. On the low and middle setting the 120E seems to work fine but once on the high setting it will flicker then dim three times and after that it will stay on what appears to be the low setting. (flicker/dim - flicker/dim - flicker/dim - stabilize)
I've swapped batteries, and followed the battery reset detect instructions even though I only use SF primaries. Any thoughts?
How are they to deal with? Do they normally answer email or is better to call? So far I've sent two unanswered emails regarding the problem. They are great to deal with, it just took a call!!! Thanks to the very helpful gentleman at Novatac my light is back in top shape. Many thanks to Novatac!!!!
Thanks in advance!!
in_the_dark
Thanks in advance!!
in_the_dark
