gav6280
Does anyone know how to work out what diameter tube i would need if i wanted to stack 3 18650 cells in a toblerone shape and then pit them inside the tube with virtually no clerance as i cant stand rattles!!
Would this be possible inside a Mag?
No.Would this be possible inside a Mag?
Hope this helps.
18.2mm is to account that ALL 18650 will work.
Most are 18.0mm but a few (protected) are 18.2mm
MagD will not work.
Only the following custom hosts.
- modamag's Colossus
- HA22 Mammoth
- FM fat body. I know V1 fit not sure about the V2.
Thanks for the info including the tolerances. This is good to know for all those folks who post asking about boring their SF's and wonder about remaing wall thickness. Thx.All of my black protected AWs are a bit more than 18.2mm wide (18.2mm~18.40mm) and protected Tenergy 18650 batteries seems to be even more wider.
YesSlightly off topic, but will a tri-bored Mag D hold three 17670 cells?
Hope this helps.
