RMSK, Inc.
Results 1 to 11 of 11
Thread: li-ion 3.6 or 3.7 volts what is the difference
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    England, United Kingdom
    Question li-ion 3.6 or 3.7 volts what is the difference
    Hi.
    My digital camera takes a 3.7volt battery , but i have seen lots on ebay with 3.6volts on them.
    WHY.
    Regards
    John.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
    Nov 2005
    Stockholm.Sweden
    Default Re: li-ion 3.6 or 3.7 volts what is the difference
    Hello TinderBo.
    When Li-Ion first hit the market they have a mid point voltage of 3,6, they were charged to a maximum of 4.1 volt.
    Li-Ion cells after -95 has a nominal voltage of 3,7 Volt and they should be charged to 4,2 Volt.
    Nowadays 3.6 and 3.7 volt cells are the same.
    Anders
    *Flashaholic* Marduke's Avatar
    Jun 2007
    Huntsville, AL
    Petrol, gasoline, same thing. They are interchangeable.
    Jan 2006
    Hi.
    I read that charging a 3.7 lin-ion to 4.2 will reduce it`s life, and that 4.0 will prolong it`s life at a loss of some capacity.
    But if you charge a 3.6 in a 3.7 charger will not the 3.6 be more likely to be overcharged as you don`t know what the chargers max charge voltage is.
    So would it not be best to just stick to 3.7 volt battery`s , or is overcharge protection built into the battery`s
    Thanks
    John.
    Quote Originally Posted by Anders View Post
    Hello TinderBo.
    Anders
    Jun 2007
    Huntsville, AL
    Quote Originally Posted by TinderBox (UK) View Post
    Hi.
    Thanks
    John.
    They are virtually the identical battery. It's just a difference of what nominal voltage the manufacturer sticks on the label.
    Nov 2005
    Stockholm.Sweden
    Hi.
    Thanks
    John.
    You.ll right about the first sentence, if you charge them to 4,1 or less than 4,2 Volt you'll prolong their life.
    The true 3,6 volts that would be charged to 4,1 Volt is no more in service life, they don't produce them no more.
    Anders
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Hello Anders,
    In general you are correct, however, Saft is still making 3.6 V Li-Ion cells and is recommending charging them to 4.1 volts. I don't believe these are available to the general public as they are intended for space and military applications.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    Nov 2005
    Stockholm.Sweden
    Hello Tom.
    Aha, didn't know that, thanks Tom.
    I don't think they sell cells in "our" sizes like 16340 17640 16340 and so on.
    http://www.saftbatteries.com/Technol...1/Default.aspx
    Anders
    Flashaholic* bluecrow76's Avatar
    Jul 2006
    Tiger Town
    Ohgeez Re: li-ion 3.6 or 3.7 volts what is the difference
    EDITED: Good questions! I have a handful of Ultrafire 3.6V cells that I've always wondered if I could charge them in my Ultrafire WF-139 chargers.
    EDC: Surefire e2l, Novatac P7/d2flex
    Flashaholic* 45/70's Avatar
    Oct 2005
    Rural Ohio
    I don't think they sell cells in "our" sizes.......
    She sells sea shells on the sea shore;
    The shells that she sells are sea shells I'm sure.
    So if she sells sea shells on the sea shore,
    I'm sure that the shells are sea shore shells
    Don't know about Saft sizes, but I'm sure this babe could set us up will some sizable sea shells, for sure.
    I've always thought 3.6 and 3.7 Volt cells were the same, just rated differently. Interesting.
    bluecrow, are you sure that's not 3.0-3.7 Volt? I have a 138, and it's 3.0 Volt for LiFePO4 and 3.6 for LiCO.
    Dave
    Jul 2006
    Tiger Town
    Quote Originally Posted by 45/70 View Post
    You're absolutely right. I was thinking of some blue Ultrafire 3.6V cells and wrote about my Powerex 3.0V cells instead! Updating my above post shortly. Thanks!
